Blackbird
DC-8 Ailerons
Thu Nov 22, 2001 4:19 am
Does the DC-8 have inboard/outboard Ailerons?
Because I can't see any inboards. The outboards appear a bit further inboards than normal, I guess to keep them away from the tips. It almost looks like theres an aileron, and outboard of that is another panel. Is it a flap or something? Or is that a second part of the aileron (the panel divided in two?)
air2gxs
RE: DC-8 Ailerons
Thu Nov 22, 2001 7:28 pm
There is actually an inboard and outboard aileron. They are bussed together with a spring-loaded torque tube. The outboard is a low speed aileron and the in board a high speed.
As speed increases, the airload on the surface increases and restricts the movement of the outboard aileron via the torque tube. As speed decrease the opposite occurs. Thus you have "4" ailerons with only 2 powerpacks.
Buzz
RE: DC-8 Ailerons
Thu Nov 22, 2001 9:36 pm
Hi Blackbird, Buzz here. Air2gxs has it right. THe ailerons are NOT like a Boeing ship. If you get the chance to ride in one on a bumpy final approach you'll see everything working.
g'day and Good Thanksgiving
Buzz Fuselsausage: Line Mechanic by night, DC-3 Crew Chief by choice.
