steven
ARINC-429
Thu Nov 29, 2001 11:30 pm
What is ARINC-429 and what is it used for?
OPNLguy
RE: ARINC-429
Fri Nov 30, 2001 12:11 am
The simple answer is that it's an established standard, sort of like an ISA-standard or PCI-standard is for personal computers. There are various ARINC standards...for various things...
http://www.arinc.com/cgi-bin/store/arinc/scan/MM=8d415d6b9dbad9bb834acc8b79e46e69:10:19:10?mv_session_id=TtJqBYyH&mv_nextpage=results
Tons of other stuff on the ARINC site as well...
Aerokid
RE: ARINC-429
Fri Nov 30, 2001 12:55 am
Arinc 429 (Arinc = Aircraft Radio INCorporated, a governing body concerned with the standardization of avionics) is a standard databus for data exchange between the various instruments/avionics/LRU's onboard an aircraft. Arinc 429 has a limited transfer speed of 100 kbit/s and there can only be one transmitter, and a maximum of 20 receivers.
There's also an advanced version, Arinc 629 (used on modern airliners like the 777 or 330/340). Arinc 629 has a maximum speed of up to 2Mbit per second and allows bidirectional data transfer for all connected stations.
GR.
Aerokid
RE: ARINC-429
Fri Nov 30, 2001 1:28 am
BTW, ask den Roland, he will be more than happy to explain it to you.  Nuts
BTW2, welcome to the forum.  Big thumbs up
GR.
jsuen
RE: ARINC-429
Fri Nov 30, 2001 2:53 am
http://www.condoreng.com/support/downloads/tutorials/ARINCTutorial.PDF
This is rather detailed.
Users browsing this forum: AAlaxfan, David_itl, DrPaul, GoCougs, PITingres, StereoTechque, tjwgrr and 31 guests
