UPS763
GE Engine Difference
Fri Nov 30, 2001 9:38 am
I have question regarding American Airlines 767-200s.
Thier 767-200s have GE CF6-80A
While thier 767-200ERs have GE CF6-80A2
What is the difference in the powerplants.
Matt
N1641
RE: GE Engine Difference
Fri Nov 30, 2001 10:01 am
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/8a26f06798d57424862568d3005635e5/$FILE/E13NE.pdf
that link should work, if not try
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/MainFrame?OpenFrameSet
rmm
Fri Nov 30, 2001 11:27 am
The difference from memory is 2000lbs of thrust achieved by
a fuel control unit change. A310's use a similar system only
-80A1 and -80A3
Rmm
310_engineer
Fri Nov 30, 2001 9:26 pm
It's not really a fuel control change.
The difference between the two engines is a different pin-programming plug on the ECU.
Mike
rmm
Fri Nov 30, 2001 11:13 pm
I'll have to dig up my 80A course notes on this one. I thought
EEC pin programming was 80C2.
Rmm
