VgnAtl747
Bracket Over Wheels? What For?
Sun Dec 09, 2001 11:16 am
Click for large version
Photo © Terry Shepherd
I've always wondered what this bracket type device over the back of the wheels is used for... anybody know?
Work Hard. Fly Right. Continental Airlines
Twotterwrench
RE: Bracket Over Wheels? What For?
Sun Dec 09, 2001 11:28 am
Gravel deflector
IMissPiedmont
Sun Dec 09, 2001 11:30 am
It's called a gravel kit. Common on MD-80s because they throw lots of debris into the wing and engines. It simply defelcts the debris way from sensitive areas.
The day you stop learning is the day you should die.
roadrunner165
Sun Dec 09, 2001 11:34 am
I'm not positive..But I believe it is used for pushback from the gate. Most older aircraft have these types of brackets on the front wheels. Please correct me if I'm wrong.
Adam
roadrunner165
Sun Dec 09, 2001 11:39 am
Sorry about that reply.. My stupid brother got my password. And he is trying to make me look stupid.
Adam
VgnAtl747
Sun Dec 09, 2001 12:21 pm
Thanks for the quick replies... I figured it was something more technical than a deflector... thanks again.
L-188
Sun Dec 09, 2001 5:40 pm
Sorry but it is just a spray bar to keep water kicked up by the wheels from going into the engines.
This way MD-80 operators don't have to buy chined tires that do the same thing but are more expensive.
747Teach
Mon Dec 10, 2001 10:28 pm
VgnAtl747: The DC-9 Maintenance manual, Chapter 32-20-1 states: "To prevent water spray being directed to the engine air inlet as the aircraft rolls through standing water, a water deflector is installed aft, inboard, and outboard of the nosegear wheels. The water deflector deflects the spray towards the ground preventing an excess of water spray to the engine air inlets." Regards,
FBU 4EVER!
Wed Dec 12, 2001 10:03 pm
In SAS,the deflectors also deflects sand and gravel since we operate at snow-covered and sanded runways during winter.They're also effective against slush.There are also,at least on our machines,deflectors mounted on the mainwheels,too,a T-shaped device protruding out between the twin mainwheel tires.
"Luck and superstition wins all the time"!
avionic
Thu Dec 13, 2001 1:16 am
As Fbu states, the spray deflector bar also has a protective effect against gravel and minor FOD. In addition, a burst tire, would not inflict maximum damage on for example the flap or engines, when we talk about the main gears.....For info, the spray deflector, have a little rubber protrusion marking the wear limit before replacement for maintenance......  Smile
Users browsing this forum: oldannyboy and 1 guest
