RyDawg82
MD-80 Landing Lights
Mon Dec 10, 2001 9:38 am
Hello....
I have noticed while flying on Alaska Airlines MD-80 aircraft that immediatly before the wing landing lamps *that fold down* are deploy'd the overhead flight attendant chime sounds twice then the lamps fold out, I noticed this on all Alaska Airlines MD-80 flights....Any particualar reason? Ry
sxmarbury33
RE: MD-80 Landing Lights
Mon Dec 10, 2001 9:57 am
Well below 10k ft you need landing lights on and below 10k most things need to be near ready for landing in the cabin and the chimes are the pilot telling the FA's they are below 10000 ft and that their is a sterile cockpit and that they need to have cabin secured soon.
RyDawg82
Mon Dec 10, 2001 10:12 am
But this happend's despite the altitude, and is always at the exact moment the landing lights are brought down on approach........
mcomess
Mon Dec 10, 2001 10:45 am
Its probably part of their descent or prelanding checklist. For example, "altimeters reset, cabin crew notified (chimes), landing light on, approach briefing complete, etc," so that as long as the crew is following the checklist, the sequence will always be the same.
sxmarbury33
Mon Dec 10, 2001 12:58 pm
Ok well the landing lights are FAA required to be on below ten thousand feet. Also it is Faa regulation that their is a sterile cockpit and all electronic devises have to be off below ten thousand. So the dings assosiated with the lights are to signal that the fa;s cant come in the cockpit and that they need to make sure all pax have stowed electronics. Mcomess is right too because on most planes the ten thousand checks are like that.
cdfmxtech
Mon Dec 10, 2001 10:54 pm
PART OF THE CHECKLIST
TWAalltheway
Tue Dec 18, 2001 9:19 am
Hey,
For some reason, in the past, when I have flown on TWA MD-80's, when the fuel is turned on during the engine start sequence, the chime sounds, and the lights flicker for a second. So i sorta have to agree with Rydawg82.
TWA all the way!
FBU 4EVER!
Fri Dec 21, 2001 7:55 pm
The chime sounding during engine start on an MD-80 happens when the engine reaches idle speed and electrical power changes automatically from the relevant APU BUS to the AC BUS.This is represents a huge transfer of electrical power,and the cabin lights tend to flicker as it happens,indeed,on some of our planes (SAS),even the EFIS screens might go blank for a brief moment!
McD standard is for the wing and nose landing lights to be manually controlled by the pilots according to their Company's Operating Procedures.These may vary from company to company.We in SAS extend the wing lights (but do not turn them on) when we are given the "thumb up" (Clear Signal) by the mechanic or person in charge for the ground equipment and push-back procedure.The nose Taxi Light,adjacent to the Nose Landing Light,is lit at this time,so are the Ground Flood Lights located on either side of the fuselage,forward of the wing.
All three Landing Lights are lit just before Take-off roll is started and turned off and retracted when the gears have been retracted.The GND. FLD. LTS remain on until passing FL100 (10,000 feet approx.) and are turned on again when passing this altitude during approach.Landing Lights are usually extended when slats and flaps are extended,and switched on when passing 1000 feet descending on the approach or when landing clearance has been received.
I haven't heard of any modification on the MD-80 series where the landing lights operate automatically at any phase of flight,except during an engine failure during take-off,when the lights turn off and retract when the gear handle is raised to the UP position.
"Luck and superstition wins all the time"!
AA737-823
Sun Dec 23, 2001 1:48 pm
Where are these landing lights that extend and retract? I have never seen them. I know that on classic 732s and 733-4-5s they are in one of the flap canoes, but have never seen them on an MD-80 type...
So where are they?
Randy
M80
Sun Dec 23, 2001 6:21 pm
Hi Randy
The wing landing lights are located at the wingtips.
Check out the two photos:
Click for large version
Photo © Ryan Pastorino
Photo © Jorgos Tsambikakis
In these pics the lights are folded in the up position (inside the wing itself) but you can see the circle shaped light facing towards ground.
Kalle
FBU 4EVER!
Kalle
Mon Dec 24, 2001 12:03 am
Exactly,Kalle!
There should be several other MD-80/90 and DC-9 photos in the photo sections.At least some of the SAS machines will have their lights extended if they are taxying.
Users browsing this forum: HighBypass, KanaHawaii, StereoTechque, TailDragging, zaphod42 and 2 guests
