modesto2
"Offset Approved..."
Sun Dec 16, 2001 6:25 am
I was listening to my scanner last night at LAX. An American Eagle Saab 340 departed 24L and tower cleared it for take-off and added "offset approved." What does this phrase mean? If it makes any difference, the aircraft departed behind a JAL 747. Thank you.
mightyfalcon
RE: "Offset Approved..."
Sun Dec 16, 2001 7:17 am
Hi Modesto2,
The offset procedure is used both for approach and area air traffic control, although for different reasons.
In the case you've witnessed, approving the Saab to fly on an offset track (from the original one flown by the JAL 747) is just a mean of keeping him out of the turbulence of the preceding heavy 747. His departure track will be parallel to the jumbo's by x Nm. The distance from the original track can be either specified by the controler or proposed by the pilot and then authorised or not by the controller.
En-route, the offset is mainly used when you have 2 flights, following the same airway for some time and too close to each other to provide them with the same cruising level. Later on, their routes are going to split so, not to penalise the traffic at the lowest level, we "push" one of them on an offset track (5,8 or 10 Nm to the original one) in order to get them both the same level.
Let's say the original route is: xxxxx-yyyyy-zzzzz. The traffic on the offset track will then fly on a stricly parrallel route 5Nm (for instance) off xxxxx-yyyyy-zzzzz.
Hope I have answered your questions.
MightyFalcon
The sky has no limit...
modesto2
Sun Dec 16, 2001 7:24 am
MightlyFalcon, you have confirmed my suspicions. In this particular case, would the Saab execute the take-off with the offset? Or would the pilots make a slight turn AFTER takeoff? Thanks for the insight.
mightyfalcon
Sun Dec 16, 2001 7:41 am
I wouldn't like to give you wrong figures about the approach offset procedure but I can tell you how this is performed en-route: Either the ATC gives a heading to split or he let the pilot do the standard procedure which is a 45 degree turn to join the offset track.
In the case you described, the Saab turned L/R short after take-off. One thing is sure, the Saab used the same runway than the 747, of course.
Oh, By The Way...
Sun Dec 16, 2001 2:16 pm
Most, if not all, FMS's have offset capability built into their programs. The pilot simply selects the NM offset (left or right) and plugs it into the box. It's a capability that is becoming more and more important - particually in non-radar international or foreign airspace. Pilots will intentionally put a bit of offset into their FMS's. In these days of GPS and RVSM accuracy it's getting to be pretty easy to be at EXACTLY the wrong place, at EXACTLY the wrong altitude, at Exactly the wrong time - if you get my drift.
However, Modesto, I doubt if it were anything as formal as this the other night. It's normal to offset slightly upwind (less than a mile) when following any aircraft where wake turbulence would be an issue. The pilot simply asks to offset slightly and ATC normally will be accomodating.
ben88
Mon Dec 17, 2001 5:50 am
The Saab would have turned immediately after take off. If offset is approved they don't have to respect the "no turns until coastline" regulation at LAX.
Will_ATL
Thu Dec 20, 2001 1:24 pm
Is an offset the same thing as a deviation? Usually deviations seem to be to avoid weather. And I may be wrong, but I thought deviations were expressed in degrees rather than kms.
mightyfalcon
Fri Dec 21, 2001 5:39 am
Will_ATL,
An offset and a deviation are two different things, used for different purposes.
Once again, an offset is just a track strictly parallel to the original one and very unusually used for weather deviation. Furthermore, we're not using km as a distance unit in aeronautics but Nm (nautical miles).
Deviations are used for weather avoidance, of course but mostly to provide enough separation between crossing traffic at the same level or climbing/descending through the level of another one. Deviations are expressed in degrees.
