Mr Spaceman
Round Objects On Belly Of TU-154?
Wed Dec 19, 2001 6:50 am
Hi guys.
In the photo below of the Tupolev TU-154 you can see 3 dark round objects with small holes in them on the belly of the aircraft. What are these things? I don't believe I've ever seen these circular objects on the fuselage of any Boeing or Airbus airliners. They look like drains. Could they be that simple?
Also, you can clearly see the large air intakes on the leading edge of each wing near the root. What system in the aircraft are these used for? Could they be the intakes for air conditioning Heat Exchangers? (I'm sorry if these intakes have already been disscused).
Click for large version
Photo © MR
Chris  Smile
A/c train
RE: Round Objects On Belly Of TU-154?
Wed Dec 19, 2001 7:09 am
As to the round objects my guess would be static points, as to the intakes, im not sure.
regards
a/c
christianbothe
Wed Dec 19, 2001 1:16 pm
Air conditioning heat exchange is correct. The objects on the underside of the wing some feet aft of the intakes are the outlets for that system.
 Smile/happy/getting dizzy christian
airplay
Wed Dec 19, 2001 1:25 pm
The round objects look alot like radio altimeter antennas. They usually come in pairs though so unless there's a fourth one, they are probably something else.
Mr Spaceman
Thu Dec 20, 2001 4:11 am
Hello Gentlemen. Thanks for your replies.
OK, Christianbothe says the intakes on the Tu-154's wing roots are infact for the aircraft's AC Heat Exchangers and that the fairings you can see behind these intakes are part of the exhaust for the AC packs. This is what I suspected, because most (if not all) North American built airliners have their Environmental Control Systems in the belly of the aircraft, between the wings near the landing gear bays. Different countries build different designs, however, I didn't think these intakes were fuel tank vents.
Both A/c train & Airplay have the round objects along the belly of the TU-154 up in the air. Are they Static Ports? Or are they Radio Altimeter Antennes? Obviously I don't know...and I'm thinking that any confusion over the apearance of these objects could be contributed to the fact that we don't get to see the underside of a Russian built airliner to often.
I've watched thousands of airliners fly over my head while on very short final, and have never spotted these round objects on their bellies. Perhaps they were there, but were painted the same colour as the airliner's belly...however, I doubt it.
Here's a photo of an Airbus A319's belly. I don't see any round objects. But, the pix is blurry and the nosegear is in the way.
Photo © Christian Albrecht
Chris  Smile
vc10
Thu Dec 20, 2001 4:45 am
Airplay.
I think you are correct, when you say they radio altimeter aerials, but ATC transponder's also have aerials like these so it could be a combination of both.
If ever you can catch aview of the Concorde's underside around the nose leg you will find four similar round aerials ---two for the radio altimeter and two for the ATC transponder.
Mr Spaceman
Thu Dec 20, 2001 7:05 am
Hi guys.
Here's some photos of the underside of the concorde, which show the round circles that are used for both radio altimeters and ATC transponders...as mentioned by Vc10.
Photo © Philippe Noret
Photo © Don Boyd
Photo © Tony Rogers
Chris  Smile
Seseal
Thu Dec 20, 2001 6:02 pm
The round objects, 3 of them which can be seen on the shot, 4 total (another one is located a bit forward and not seen) are RA antennas, 2 xmitting + 2 receiving. I know that for sure. regards.
Mr Spaceman
Fri Dec 21, 2001 12:49 am
Hello Seseal. Thank You for your reply. Obviously you are talking about the TU-154, and being from Russia...you would know. Thanks again sir.
Take Care,
Chris  Smile
Wasilenko
Fri Dec 21, 2001 9:52 am
I'm not exactly sure but I think that these black spots are the hard points. If you take a look at the following pictures you will see that there is one support leg which is located aproximately in the area of the spots.
Photo © Uldis Pelna
Photo © Uldis Pelna
Wasilenko
Users browsing this forum: WPvsMW and 1 guest
