planelover
A380 Landing Gear
Wed Dec 26, 2001 7:39 am
Howdy,
Does anybody know what the design for the main landing gear on an A380 is? I saw a picture that had 6 wheel on 2 of the main (can't remember if they were outboard or not), and 4 on the other 2. Is this the way it really is designed? I would have thought that it would have more wheels than that. That's only 4 more than a 747. Are the wheels that much bigger? Does anybody have any good diagrams/pictures or anything like that for this?
Thought I'd ask.  Smile/happy/getting dizzy
Klaus
RE: A380 Landing Gear
Wed Dec 26, 2001 8:12 am
As far as I know, the actual construction of the landing gear has just been contracted out, so I wouldn´t expect many details yet; But Airbus has a few PDF files on the A380 on their Site at http://www.airbus.com/products/A380_family.asp.
The PDF document "A380 landing gear footprint & ACNs" has the dimensions (in mm, I think) and some more info. The 6-wheeled bogies are the inboard (aft) ones. As far as I´ve heard, those will also be steerable.
Sinlock
Wed Dec 26, 2001 9:45 am
These numbers are very loose.
The A-380 will be at about the same displacement as the 747-400LR.
400LR is about 910,000lbs displaceing a footprint of 91000lbs per tire.
A-380 will displace 1,300,000 on 14 wheels at 92800lbs per tire.
At one point there was going to be a 3 wheel nose gear but it was thought it would create a shimmy in the nose gear in high sideload condisions. "crosswind landings"
widebody
Thu Dec 27, 2001 2:16 am
Two three axle body gears, two two-axle wing mounted gears, and one one-axle nose gear.......
boeing767-300
Thu Dec 27, 2001 6:30 am
If all the early estimates are correct then the A380 has only two more axles(4 tyres) 2x 3 & 2 x 2 axle bogies for 20 tyres total as opposed to 744 at 16.4 x 4 2 axle bogies.
That is 400 ton for the 16 wheel main gear of a 744 and an extra 50% weight @ 590 ton for 20 wheel main gear of the A380. Could be a little thin on main gear at MTOW.
Since when has a totally new project ever come under budget or not encountered numerous unforseen problems. The A380 project will be no different. 12 billion developement costs may be a little conservative. I look forward to seeing one fly. It may be later rather than sooner.
Users browsing this forum: Google Adsense [Bot], heavymetal, lollyj, sharles and 18 guests
