norseman
What Is The "N" In N1 Or N2?
Wed Feb 06, 2002 10:54 am
I was discussing turbine engine operations with a captain today, when we both pondered what the "N" in N1 or N2 stands for. I am having a hard time finding any information on this. I know that N1 indicates low pressure compressor speed, and N2 indicates high-pressure compressor speed, but what does "N" stand for? Any insight?
airplay
RE: What Is The "N" In N1 Or N2?
Wed Feb 06, 2002 11:29 am
The International System of Units was developed in an effort to standardize measurement in scientific circles. The "SI" system really represents a modern form of the metric system.
The generally accepted SI symbol for rotational frequency is "n". Rotational frequency is normally expressed in "radians per second". "n" rotational speeds in turbine engines are predetermined maximum rotational speeds of specific shafts. Indicated rotational frequency is typcially expressed in percent of "n".
Why "n" instead of some other symbol? You could ask the same question about pi....
 Smile
delta-flyer
Wed Feb 06, 2002 11:42 am
N has always been used for rpm (i.e. Number of revs...) as opposed to the Greek letter omega for for angular velocity in radians per second.
Pete
"In God we trust, everyone else bring data"
IMissPiedmont
Wed Feb 06, 2002 12:24 pm
In other words, the N itself doesn't mean anything. It's just a letter. One of the aviation oddities as most every other letter means something starting with that letter.
The day you stop learning is the day you should die.
norseman
Wed Feb 06, 2002 12:48 pm
Thanks a lot guys. The captain I was talking with said he has never gotten a good answer about "N". I even asked some guys in maintenance and their answer was "Uh, well you see...Um, It's probably..."
I knew you guys would come through!
Norseman
AJ
Wed Feb 06, 2002 12:51 pm
Similar to air pressure being denoted by 'Q', as in Qnh, Qfe etc etc.
Odd.
Bobsmuggle
Wed Feb 06, 2002 9:55 pm
QNH, QFE etc are from the old morse and alike days. QNH is short for "Question - Nil Height" which would be interpreted as "I have a question, what is the nil height"
AJ
Thu Feb 07, 2002 6:03 am
Well done Bob, I thought that info had been lost into history.
Likewise at my company runway heading is still called QDM.
airplay
Thu Feb 07, 2002 11:13 am
Yes....Omega is the primary SI symbol for angular velocity. "n" is an alternate.
I did a bit more research (asked some of my engine buddies) and found that the "n" I was referring to is not the same as the "N" used in N1 and N2 engine indications.
N is the symbol for "specific speed". Specific speed is defined as "the speed of an ideal pump geometrically similar to the actual pump, which when running at this speed will raise a unit of volume, in a unit of time through a unit of head".
Here are some links that explain what specific speed is:
http://www.negia.net/~nelik/ns.htm
http://www.tasonline.co.za/toolbox/pump/powns.htm
http://www.mcnallyinstitute.com/07-html/7-03.html
Again....I have no idea why they chose "N".
Bobsmuggle
AJ
Thu Feb 07, 2002 9:50 pm
I have never heard QDM before... would that mean Question - Direction Magnetic???
Users browsing this forum: Redbellyguppy, TailDragging and 1 guest
