cdfmxtech
Split Controls: What The Heck Is This About!
Tue Feb 12, 2002 3:34 pm
What the hell is going on HERE??!!
Why is the Captains control wheel in a roll, and the FO wheel asleep??!!
Some kind of jammed controls demo??
Click for large version
Photo © Lars Wahlstrom
A/c train
RE: Split Controls: What The Heck Is This About!
Tue Feb 12, 2002 5:56 pm
RUSSIAN PLANE...................... need anyone say more???,
regards
a/c
wingscrubber
Tue Feb 12, 2002 6:14 pm
the captains control column has most likely been disconnected for maintenance. That's the most logical reason I can think of.
-Pete
Resident TechOps Troll
FredT
Tue Feb 12, 2002 7:42 pm
Considering where it was taken, I don't find it likely that rerigging the controls would be done. However, there's normally a disconnect function available should one control column jam. When excessive force is applied to a column in a control axis with the other column resisting, it disconnects the columns typically giving each column control of the control surfaces on that side. On the types I'm familiar with, they connect automatically once they agree again but can be permanently disconnected (requring a reset on the ground) manually.
Fred
PPGMD
Wed Feb 13, 2002 3:34 am
"If its ugly, its British. If its weird its French. If its ugly and weird, its Russian."
Nothing personal just like that quote and I think the last part is apporiate here.
At worst, you screw up and die.
avt007
Wed Feb 13, 2002 4:29 am
The dash 8 has pitch and roll disconnects, and they are great for maintenance. By moving one yoke like that, access to the panel is improved, and it doesn`t spring back to neutral while you are working.
WhiskeyNovembr
Wed Feb 13, 2002 9:03 am
PPGMD,
Does that quote apply to women as well?  Big grin
Users browsing this forum: Google [Bot], Moebius and 17 guests
