cosync
Nose Whell Fairing On Socata
Fri Mar 01, 2002 3:33 pm
on socatas the noswheel cobver is so huge that i reckon there would be less drag without it. its so fat.
Click for large version
Photo © Frank Schaefer
HAL
RE: Nose Whell Fairing On Socata
Sat Mar 02, 2002 5:07 pm
The job of fairings is to keep the acceleration of air around the plane to a minimum as it slips by. If you take a look at recently designed airplanes, you'll notice the fairings have gotten a lot bigger, especially in the wing/fuselage area. Take a look at some of the newer business jets like the Cessna citationjet or Raytheon (Beech) Premier jet. They have HUGE bellies, but those fairings help smooth the airflow around the plane, causing less drag and therefore more speed for the same fuel. Of course there's a balancing act, as too much surface area increases drag. That's what computers are for these days - figuring out just how to design the aircraft for minimum drag. Small fairings may look better, but don't help as much.
One smooth landing is skill. Two in a row is luck. Three in a row and someone is lying.
Users browsing this forum: Nicoeddf, Noris and 14 guests
