Mr Spaceman
BizJets & Airliners Use Same Engine?
Sat Mar 23, 2002 5:15 am
Hi guys.
I recently read about production of the new Falcon 7X corporate jet which will be powered by three 6,100-pound thrust Pratt & Whitney PW 307A engines, which are a derivative of the successful PW 300 series already in service on other bizjets and airliners (unfortunately, these aircraft are not mentioned).
My question is about the PW 300 engine. I find it very interesting to learn that a jet engine is being used on both bizjets & airliners. Mainly because of the difference in weight between the two types of aircraft.
Does someone out there know what bizjets & airliners are using the PW 300 engines? Also, how much thrust do these engines create?
Logic tells me that the size of these bizjets & airliners must be similar if they use the same engine. Perhaps we're talking about the larger Gulfstreams, Global Express's, and Challenger bizjets and the smaller Canadair Regional Jets & Embraer ERJ 145 short range regional airliners. Just a guess.
Any help is appreciated.
Chris  Smile
flyf15
RE: BizJets & Airliners Use Same Engine?
Sat Mar 23, 2002 6:30 am
The PW300 series (PW306B to be exact) is used on the Do328JET.  Big thumbs up
cv640
Sat Mar 23, 2002 6:57 am
The 717, Gulfstream V, and the Global Express all use the same engines.
Mr Spaceman
Sat Mar 23, 2002 8:19 am
Hi guys.
Thanks for your replies.
>Flyf15, do you know how many pounds of thrust the Dornier 328's engines produce? Is it around 6,100 lbs like the PW 307 engine? I couldn't find a Dornier website with aircraft info.
Click for large version
Photo © Pierre Lacombe
>CV640, Thanks for your info. The engines you are talking about deliver a lot more thrust than the ones on the Falcon bizjets.
GV, engine.....BMW RollsRoyce BR710-A1-10 (14,750 lbs thrust).
Photo © Ryan Gaddis
Global Express, engine.....BMW RollsRoyce BR710-A-220 (14,750 lbs thrust).
Photo © Darcy Stevens
B-717, engine.....BMW RollsRoyce BR-715-A1-30 (18,500 lbs thrust).
Photo © George Canciani
*This info is from the aircraft company's websites.
Chris  Smile
flyf15
Sat Mar 23, 2002 9:41 am
The PW306B does not quite pump out the astonishing 6100lbs/thrust of the PW307. Rather, it has a rating of 6050lbs/thrust.  Smile/happy/getting dizzy
IMissPiedmont
Sat Mar 23, 2002 11:50 am
Let's not forget the RR Tays used on the UPS 727-100s. These are pretty nuch the same engine as used on the Gulfstream.
The day you stop learning is the day you should die.
cv640
Sat Mar 23, 2002 10:27 pm
Also used on the Fokker 100s and 70s
L-188
Sat Mar 23, 2002 10:47 pm
Somebody beat me to the Tay family.
Don't leave out it's little brother the Spey. It was used on the G-II and G-III, as well as the BAC-111, Trident, Fokker-28, and was the proposed original engine for the 727.
erj-145mech
Sun Mar 24, 2002 10:44 am
The Rolls-Royce (Allison) AE3007 is used on the Cessna Citation X as well as the Embraer 135/140/145. The Citation is quite a bit smaller, but faster than the ERJ's. The ERJ is around .78M vs the .98 for the Cessna.
IMissPiedmont
RE: Erj-145mech
Sun Mar 24, 2002 11:13 am
.98 Mach? I know the Citation X is fast, but I wasn't aware that it was that fast.
cv640
Sun Mar 24, 2002 1:29 pm
Its MMo is actually .92, it has been dived to .98 in testing. I've heard it has almost no range when cruising at .92 though, so have to weigh everything in place.
Ziggy
Tue Mar 26, 2002 12:02 am
Looking off of Cessna's website for the X, they say that at .91M and a little less than 1000lbs of payload that is has a range of 3500nm with 45min reserve.
The reason I looked that up, because I heard of them doing a round the world cruise to test the X with it's speeds. I thought I read that most of the trip was done at .92M
Ziggy  Big thumbs up
musang
Tue Mar 26, 2002 2:43 am
The Avro RJXs, both now idle at Woodford awaiting their fate (converting to RJ standard would be too expensive so dismantling is likely!), have the same powerplant as a bizjet, but I can't remember which one.
Regards - Musang
Users browsing this forum: Yahoo [Bot] and 1 guest
