Trent_800
What Causes Engine Vibration
Thu Mar 28, 2002 12:54 am
What causes Engine Vibration? Is it off balance fanblades or somthing else
FredT
RE: What Causes Engine Vibration
Thu Mar 28, 2002 1:13 am
Lots of things. We can start making a list, see how many things we can think of? I'll start with
1) Unbalanced rotors
2) Bent shafts
3) Bearings with defects
I assume you mean jet engines/gas generator related vibrations? If you add turboprops, engine accessories and so on, there's a sh*tload of other potential sources. If you throw recips into the mix.... well, they're vibrating rather severely to begin with but you can still detect lots of things about to go wrong by monitoring vibrations in the right part of the spectrum.
Fred
air2gxs
Thu Mar 28, 2002 12:47 pm
Don't forget accessories on the gearbox. Hydraulic pumps, CSDs/IDGs and fuelpumps can also cause a vibration felt throughout the airframe but not on the AVM.
ThirtyEcho
Thu Mar 28, 2002 3:55 pm
Vibration in a turbine engine is caused by loose or bent things; bad vibration is caused by big loose or bent things. Vibration in a piston engine is caused by normal operation; lack of vibration in a piston engine is usually caused by fuel starvation.
XFSUgimpLB41X
Fri Mar 29, 2002 1:21 am
Plus there are certain frequencies that things in the airplane like to resonate at... as the engine passes through the frequencies you can hear the airplane amplify them.
Chicks dig winglets.
Users browsing this forum: SAAFNAV and 11 guests
