TWAMD-80
Thrust Reverser Controls On The A320
Thu Apr 04, 2002 2:37 pm
Just recently I noticed on the A320 family of aircraft that unlike some other airliners,
Click for large version
Photo © Jorge Albanese
there doesn't appear to be any thrust reverser levers on the throttle levers
Photo © Robert Balogh
Are the thrust reversers controlled by the pilots or is it automatic on the A320? Thanks for any replies! Smile
TWAMD-80
Two A-4's, left ten o'clock level continue left turn!
david b.
RE: Thrust Reverser Controls On The A320
Thu Apr 04, 2002 3:09 pm
Photo © Stephan Tophoven
According to the pic, the handles has to be pulled back to idle, then to reverse, just past idle. Is there a safety built in? I dont know, but I dont think there needs to be. The FBW computer should keep the reversers from deploying unless the engines are idle and/or the ship is below a certian altitude.
Teenage-know-it-alls should be shot on sight
Panman
Thu Apr 04, 2002 10:28 pm
If you look on the 2nd photo of the original post you can clearly see the reverser switches about halfway down the front of the throttle. They are flat and pointing forwards. It might look to some like it's on the throttle quadrant between the levers but it is the reverse switch for the starboard engine.
Panman
Users browsing this forum: StereoTechque, Wacker1000 and 1 guest
