TechRep
CRJ700 Fuel Leaks Lead To Emergency AD
Tue Apr 16, 2002 7:31 am
Anyone assosiated with the Bombardier CRJ700, can you tell me if this fuel leaking from a transfer coupling is in fact a 'Wiggins Fitting'? I am sure the AD is long completed I was just curious.
Transport Canada last month notified the FAA of a potentially dangerous fuel system defect in Bombardier’s new CRJ700 regional jet, prompting the U.S. agency to issue an emergency AD for the model. According to Transport Canada, CRJ700s may experience uncommanded fuel transfer between the wing tanks and the center tank, creating a condition in which the center tank can overfill and leak. The problem could also cause fuel to leak from the center tank vent system, resulting in fuel starvation. Bombardier said it would correct the problem, apparently caused by a loose fuel transfer coupling, on all 31 CRJ700s in service by the end of last month. The AD requires operators to increase normal mission fuel requirements by 3,000 lb to compensate for potential fuel leaks, and to limit operation of the airplane to flights within 60 min of a “suitable” alternative airport.
TechRep
mikeclod
RE: CRJ700 Fuel Leaks Lead To Emergency AD
Tue Apr 16, 2002 1:38 pm
Couldn't tell you about the coupling, but Horizon is still following this notice.
Mikeclod
Users browsing this forum: ucdtim17 and 1 guest
