Elliott
ELT Test
Sun Apr 21, 2002 1:55 am
Hi all
I am looking for the procedure of ELT checks. There is a specific date/time each month for testing purpose.
Can anyone advise me for the full procedure or a related link?
Many thanks in advance
Elliott Kefalas kefalasi@aia.gr
Airfield Services Division
Athens INTL Airport
TurbineBeaver
RE: ELT Test
Sun Apr 21, 2002 2:11 am
Anytime of the day at 5 minutes after the hour.
TB
PPGMD
RE: ELT Test
Sun Apr 21, 2002 2:35 am
Just listen to 121.5 and turn the ELT on during the first 5 minutes of the hour.
At worst, you screw up and die.
Contact_tower
RE: ELT Test
Sun Apr 21, 2002 3:39 am
And maximum 3 sweeps......  Smile
Elliott
RE: ELT Test
Mon Apr 22, 2002 11:56 am
Many thanks in advance for your help.
Elliott
PW4084
RE: ELT Test
Tue Apr 23, 2002 1:55 pm
And in addition to the prearranged time discussed above, ELTs can be tested other times if arrangements are made with the 'nearest FAA Control Tower or FSS'
AIM 6-2-5
PW4084
Contact_tower
RE: ELT Test
Wed Apr 24, 2002 5:17 am
"And in addition to the prearranged time discussed above, ELTs can be tested other times if arrangements are made with the 'nearest FAA Control Tower or FSS' "
Do not apply outside the US..............
FredT
RE: ELT Test
Wed Apr 24, 2002 5:40 am
And as always, but even more than usual when testing ELTs, do not follow procedures given on a.net or anywhere on the net. Check the regs/procedures applying to your operation firsthand.
I don't think whatever CAA you're under would look very kindly if you ring the alarm bell and try to explain it with "well, this bloke on a.net said..." Got a license? How much is it worth to you?  Smile
Fred
PW4084
RE: ELT Test
Wed Apr 24, 2002 2:59 pm
Good Point FredT
PW4084
Sinlock
RE: ELT Test
Thu Apr 25, 2002 9:50 pm
I do not know what the laws are in Greece.
But here in the U.S. only a A&P can sign-off on a ELT test/check.
RE: ELT Test
Thu Apr 25, 2002 10:21 pm
FYI, the ELT must be tested every 12 calendar months, and the battery must be replaced A) after 24 calendar months, B) after 1 cumulative hour of use, or C) after half of it's life span.
wilcharl
RE: ELT Test
Fri Apr 26, 2002 1:49 am
and to remember that
121.5
12 calander months 1 hour of use .5 =1/2 (half its life)
Mr Spaceman
RE: ELT Test
Sat Apr 27, 2002 12:05 am
Hi guys.
I'm curious, are there aircraft out there with an ELT "test" switch in the cockpit that the pilot can use for this test?
In a Cessna 150, to gain access to the ELT so you can manually turn it on, you have to remove the aft interior cabin wall to reach the ELT's manual transmiter switch. (a good way to put your back out!) Or there's an exterior access panel as well.
This process seems like a pain...compared to a cockpit switch.
PS. You can also test your ELT by landing REALLY hard and then tuning your COM to 121.5  Big grin
Chris  Smile
PPGMD
RE: ELT Test
Sun Apr 28, 2002 2:39 am
Most plane have the test switch in the cockpit these days.
RE: ELT Test
Mon Apr 29, 2002 2:59 am
In Addition to 121.5 Mhz,Do the Military Forces use 243Mhz,or another Distress frequency.
regds
HAWK.
TurbineBeaver
Wilcharl
Wed May 01, 2002 8:08 am
Wilcharl,
That is a pretty little nifty method to remember it! I'm sure I'll never forget it now!
TB
FlightTest
RE: ELT Test
Wed May 01, 2002 10:19 am
Funny that this topic comes up. Security came into our hanger last night right at quitting time looking for an ELT that was sounding off. After checking all of our aircraft, we sent them on thei way still searching. They ended up finding one going off in a BeechJet over in corporate transportation that was going through inspection. Oops...
flyn
RE: ELT Test
Wed May 01, 2002 4:58 pm
That would be my luck crash write on the hour
Users browsing this forum: Dispatcher9999, drdisque, LH707330 and 23 guests
