sushka
L1011 And A320 Takeoff Roll
Fri Apr 26, 2002 1:13 am
Hello, does anyone know how long a normal takeoff roll for an L1011-500 and an A320-200 is at 1000 MSL at standard temp with a 4 knot headwind?
Thanks for any help!!  Big thumbs up
Pershoyu Spravoyu Litaki!
OldMan
RE: L1011 And A320 Takeoff Roll
Fri Apr 26, 2002 8:34 am
The take off roll shall not exceed the length of the runway....Oldman
Metalbird
Fri Apr 26, 2002 9:19 am
Airbus A320-200 , 214 version at mtow (74 tons) (max thrust) normal takeoff roll is 4000 feet, no headwind, at sea level, I see this happen daily at the airport were I work, Horta International Airport (LPHR).
The runway lenght is 5600 feet.
Lockeed I d´ont know, but I think that it is less than 7000 feet, depending in the thrust of the engines and the mtow version.
MetalBird
411A
Fri Apr 26, 2002 11:10 am
Well then Sushka, specify a takeoff weight for the big three engine Lockheed and will give an accurate answer...have all the numbers here. With over ten thousand command hours in the big bird, I should know...but hey if I don't, our Dir Ops (with over 15,000 hours in type) certainly should....
jhooper
Thu May 02, 2002 10:22 am
Check out this video clip of this Delta L-1011 departing Honolulu bound for LAX. Anyone want to estimate how much runway she used?
http://airside.paradise.net.nz/video/deltal1011honoluluto.wmv
Last year 1,944 New Yorkers saw something and said something.
cedarjet
Thu May 02, 2002 11:36 pm
The L1011 (and DC 10) were reasonably sprightly, since they were designed to get in and out of La Guadia.
Leej
Fri May 03, 2002 5:17 pm
Jhooper
I reckon she rotated after about 8500ft? Was quite a leisurely takeoff. As I cannot find any data for that runway, it's just a guess.
ATA L1011
RE: Cedarjet
Sat May 04, 2002 5:27 am
Oh Cedar they were great when lightly loaded like when they departed LGA. Let me tell you when you get a heavy 1011-100 is a dog and they use alot of runway just like that video demonstrates. LGA flight were minimal flts with light fuel loads.
Treat others as you expect to be treated!
jhooper
Mon May 06, 2002 10:30 am
Kinda of a side note here, but why don't they just extend the runway at LGA to a more reasonable length, say 9000ft? I'm not too familiar with the airport, but I believe the runways are build on piers, right? So couldn't those piers be extended?
TWAL1011
Mon May 06, 2002 2:05 pm
Jhooper, thanks for the vid. It's been a few years since I've heard that sound!
762er
Mon May 24, 2004 9:20 am
Imagine the takeoff roll for a flight to atlanta. That was about 50 some seconds of roll.
QantasA332
Mon May 24, 2004 10:46 am
A good, pretty intuitive equation for calculating the approximate takeoff distance of an aircraft flying into a headwind is:
Takeoff distance = distance for zero wind X [(Vo - Vw) / Vo]²
...where Vo is the takeoff velocity with zero wind and Vw is the velocity of the headwind. Unfortunately, I only have takeoff distance figures for the 320 and L1011 at sea level, so I can't get you exactly what you want...
QantasA332
dairbus
Mon May 24, 2004 11:50 am
The longest take-off roll I can remember was on a Delta L-1011 operating DL17 DFW-HNL. We seemed to roll forever before finally rotating and lifting off.
"I love mankind. It's people I can't stand." - Charles Shultz
JetRanger2000
Mon May 24, 2004 1:14 pm
Wow, that was a pretty long takeoff roll!
I was waiting for them to turn the JATO  Smile
VS346
Mon May 24, 2004 2:52 pm
What a nice sound to hear again.
Only flew the DL L1011 once, never felt safer on a plane. Really felt like it was built like a damn tank.
VS346
Virgin-Atlantic: More experience than our name suggests
ATA L1011
Tue May 25, 2004 7:54 am
DAirbus yes FLT 17 took alot of runway to get off as a matter of fact it was the flt/plane to watch if you wanted a long takeoff/slow climb if you were a spotter at DFW 2001 and earlier. It took a bit longer than the MD-11's bound for Tokyo or the 777's for Europe adn DC-10's bound for HNL. One of the last days it operated that flt it used just about all of 17R to lift.
SUPRAZACHAIR
Tue May 25, 2004 6:23 pm
Well looking at a diagram of HNL, and guess-timating the location of rotation/ takeoff, it looks to be around 8000ft.
411A
Wed May 26, 2004 2:17 am
L1011-500, 1000msl, temp 13C, 5 knot headwind, 510,000 pounds (max weight), flaps 14, runway gradient zero, balanced field---
Ground run during takeoff, 8800 feet
Runway required, 10,900.
V1 151 Vr 160 V2 171
vikkyvik
Wed May 26, 2004 7:10 am
JHooper, by counting the shoulder markings on the runway (which I'm pretty sure are spaced at 100 feet), I got just about 8,000 feet. Had to estimate though when a taxiway got in the way. I believe that runway is around 12,000 feet (that's what I remember, and also the shoulder markings switched direction at about 6,000 feet).
~Vik
Users browsing this forum: Woodreau and 1 guest
