wardialer
Horsepower On The MD520N Notar
Wed May 08, 2002 4:12 pm
I have been investigating the horsepowers of the MD520N Notar helicopter and it said that those Allison 250-C20R engines have a 450 shp and continuous shp of 375. What is the difference between the horsepowers of a Cessna or other prop aircraft compared to the Notar? And what is shaft horsepower compared to just horsepower?
EssentialPowr
RE: Horsepower On The MD520N Notar
Thu May 09, 2002 1:38 am
Horsepower is simply work/time. In metric units,
work = force*distance = Newton Meters (called a Joule)
power = work/time = Joule/sec = Watt.
So, watts and horsepower are Power terms.
Horespower can easily be converted to watts, similar to temperature in F being converted to C.
There is no difference in horsepower whether it's measured at a shaft, pulley, crank, flywheel, or any other mechanical output.
wardialer
Thu May 09, 2002 10:18 am
For example: If the MD520N NOTAR helicopter has a shaft hp of 450 and a Cessna 182 has a hp of ( the same) 450 does that mean that they have the same equal power as in cruise and take-off power?
EssentialPowr
Thu May 09, 2002 11:23 am
If both powerplants produce 450 hp in the takeoff regime, or cruise regime, per your example, then they are identical.
Obviously, a 182 w/ 450 hp is certainly not typical...
wardialer
Thu May 09, 2002 3:21 pm
On this one website about the NOTAR, the engine specs stated that shp was 450. But it also stated that a continuous shp 350 was also applied. What is the difference between the two?
B737-112
Thu May 09, 2002 4:34 pm
Does FS98 really need the information to be that accurate? Just fly the NOTAR in those damn circles and be happy!  Big thumbs up
FredT
Thu May 09, 2002 7:59 pm
Max continuous horse power is just that - the horsepower the engine can output for an unlimited time withouth taking damage. Maximum horsepower comes with a time limit.
Fred
wardialer
Mon May 13, 2002 2:59 am
Hey B737-112, you dont know anything. OK.
B737-112
Mon May 13, 2002 4:49 am
Oh but Wardialer, I do. I'm the one that sold you the computer and monitor you are using now and I helped you install FS98 and FSEditor so you can alter the horsepower and all. Then you called me up for information about downloading the NOTAR so you can put it to Flight Sim.
To set the record straight for everybody else my original post was just an inside joke between friends like all friends do but instead he's mad and has not talked to me since I posted that first post. As you guys can tell I was not slamming him at all, it was simply a joke which he didn't understand. Learn to understand humor Wardialer.
wardialer
Fri May 17, 2002 12:57 pm
B737-112,
Just answer the question. It really shows that your not even into the technical stuff Uh. I'm just educating myself and your not.
 Smile
B737-112
Fri May 17, 2002 4:34 pm
It took you 5 days to come up with a response like that, sure was quick thinking!
Wardialer, why are you so embarrased about playing Flight Sim, there's a whole forum just for you guys. I think it's cool, why take offense to it? I don't see the issue.
wardialer
Fri May 17, 2002 5:11 pm
B737-112,
I think your in the wrong topic because obviously you can't come up with a good answer. Oh, I know why, because you don't seem interested in one of the worlds greatest choppers ever invented. Trust me, there are other things in a chopper than flying in circles. Did you even know that? HA HA HA
FredT
Fri May 17, 2002 7:11 pm
May I suggest that you two take it to email, phone or the street before further embarassing yourselves in public, not to mention clogging up the forum with whatever issues you have with each other?
Fred
wardialer
Sat May 18, 2002 2:09 am
Thank You for your suggestion.
Users browsing this forum: sunrisevalley and 3 guests
