N79969
GE Engines On The MD-11
Fri May 10, 2002 11:22 pm
Does anyone know the purpose of the nozzles at the end of CF6 engines on MD-11? They don't appear on PW powered MD-11 nor do they appear on CF6-powered 747 or 767. They reappear on the A300/310/330 that are powered by CF6.
Also they appear on all engines available on the 777. I have wondered what determines when these exhaust nozzles are used or whether they inside the cowling or actually stick out.
JETPILOT
RE: GE Engines On The MD-11
Fri May 10, 2002 11:25 pm
Pics would help....
JET
N79969
Sat May 11, 2002 12:04 am
I'm talking about the black nozzle that extends from the tailpipe.
The PW-powered MD-11:
http://www.airliners.net/open.file/229240/M/
The GE-powered MD-11:
http://www.airliners.net/open.file/219881/M/
http://www.airliners.net/open.file/008755/M/
On the Airbus models (they're present):
http://www.airliners.net/open.file/225495/L/
http://www.airliners.net/open.file/212586/L/
On the Boeing (note the absence on these GE powered aircraft):
http://www.airliners.net/open.file/230764/L/
http://www.airliners.net/open.file/224243/L/
rmm
Sat May 11, 2002 12:29 am
Photo © Gregg Stansbery
Photo © Jonathan Derden
Photo © Jose Luiz Junior
Photo © Michael F. McLaughlin
Photo © Joe Pries
Photo © Jason Taperell
Photo © Peter Unmuth - Vienna Aviation Photography
N79969
Sat May 11, 2002 12:35 am
Thanks RMM, I could not do that on my machine for some reason.
rmm
Sat May 11, 2002 12:36 am
From memory the exhaust nozzles are furnished by the airframe manufacturer, not the engine maker.
"On the Boeing (note the absence on these GE powered aircraft)"
Have a look at a 737-300+ nozzle.
"On the Airbus models (they're present)"
Have a look at a GE powered A320.
This seems to be a weird science, although no doubt there is some kind of reasoning behind it.
Rmm
N79969
Sat May 11, 2002 1:09 am
...and they are absent again on the A340-200/300. Any weird scientists on this forum?
LMP737
Sun May 12, 2002 4:05 pm
The nozzle you are reffering to is known as the exhaust plug. It's purpose is to form a convergent-divergent duct along with the exhasut nozzle to aid in the production of thrust.
THe PW 4460 on the MD-11 does have an exhaust plug, you just can't see it from the ground. The same goes for CF6 powered 747 and 767's. Other engines such as the RB-211 and V2500 fall into this category also.
Hope this bit of info helped.
