JZucker
Spoilers On Takeoff?
Sat May 11, 2002 9:26 am
I recently noticed that on take off in a 737, the spoilers seemed to deploy at varying degrees after rotation for a few hundred feet into the climb. Is this a function of the 73's trim?
avt007
RE: Spoilers On Takeoff?
Sat May 11, 2002 11:04 am
I'd suspect you were seeing the roll spoilers deflect as the crew or autopilot put in small roll corrections to stay level.
theairbusguy
Sat May 11, 2002 5:23 pm
it's normal , some spoilers (roll spoilers) are operating with the ailerons.
POSITIVE RATE
Sat May 11, 2002 6:05 pm
yes what you saw were roll spoilers. They operate with and sometimes without the ailerons depending on the IAS.
Blackbird
Mon May 13, 2002 6:21 pm
On the 737, like many aircraft, have flight spoilers that can be used to assist roll-control by deploying asymetrically. Asymetrical deflection helps kill-off lift on that wing, thus lowering it at a more rapid rate than the ailerons could alone. On the 737, once the yoke is turned past 7 degrees the flight spoilers begin to raise asymetrically (the spoilers are not up on the other side).
-Kamarov
Users browsing this forum: AF322, akiss20, Teganuma, tupperjets and 31 guests
