JZucker
Tough One! Lift/Drag Vs. Distance/Altitude
Tue May 14, 2002 1:18 pm
Ok guys...here is a tough one that I need to find an answer to before my final.
Why is the ratio of Lift/Drag proportional to Distance /Altitude??
I have already attempted to find a proportional relationship between Lift, Drag, and Potential and Kinetic airspeed. I failed. If anyone knows this you are amazing!
Thanks in advance. Josh
RE: Tough One! Lift/Drag Vs. Distance/Altitude
Tue May 14, 2002 3:07 pm
Not too sure if this is what you're looking for... For cruise, the answer perhaps lies the Breguet range equation? Range is maximized at flight conditions which maximize M*L/D. With a constant Mach M, that means max L/D which means constant CL which means flying at a constant W/delta which means you continue to climb in cruise as fuel is burned off (follow optimum W/delta). I believe this is your L/D and Range/altitude relationship. If this is not what you have in mind, perhaps take a look at the equations of motion for climb/descent...One can deduce the relationship...maybe. I haven't touched the aero books in years.
Nut
FredT
Tue May 14, 2002 5:29 pm
Ain't got the books with me but I'll have a shot at it anyway. Very interesting question and I have to admit I didn't really know the answer. I've always taken it as gospel - not a good thing!
In a glide, you're getting rid of altitude to compensate for the energy loss created by drag. Set up an equation for the work done by drag and by gravity.
dW = m*g*dh - dt*V*D
D = m*g*cos(ga)/(L/D), as L will then equal m*g*cos(ga)
where ga is the glide angle.
The ground distance travelled, ds is dt*V*cos(ga). As the work done on the aircraft will sum up to zero, we end up with
m*g*dh - dt*V*m*g*cos(ga)/(L/D) = 0
m*g * (dh - ds/(L/D)) = 0
divide by m*g as it can't be zero
dh = ds/(L/D)
ds/dh = L/D
Fred
FredT
Tue May 14, 2002 5:35 pm
I thought I'd clarify one step there to make it easier to follow.
m*g * (dh - dt*V*cos(ga) / (L/D) = 0
Substitute ds = dt*V*cos(ga)
Fred
erasmus
Tue May 14, 2002 6:21 pm
L= Lift
T= Thrust
D= Drag
W= Weight
a=b= Glide Angle
Dis= Distance
A= Altitude
Imagine a glider in a constant speed, constant descent angle (a=b) glide.
Then : T= D and L=L1
tan (a) = A/Dis
tan (b) = T/L1 = D/L
since a=b : therefore A/Dis =D/L
or: ALTITUDE / DISTANCE = DRAG / LIFT
Is this clear enough?
Users browsing this forum: 69bug, FAST Enterprise [Crawler] and 3 guests
