Mr.BA
Controlling The Throttles Manually On Classic B747
Mon Jun 03, 2002 1:42 am
Hi everyone,
Those who have piloted the classic B747s before, would like to know if the aircraft is difficult to handle when on manual control of the throttles since the engines produce different thrust each?
alvin
Boeing747 万岁!
Tuffty
RE: Controlling The Throttles Manually On Classic B747
Mon Jun 03, 2002 3:56 am
Though im not a pilot ive been told by some flight engeneers who served on the 200's that they would stager the throttles to get all of the engines to have te same power out put. however i dont think that this was what you were asking and i to am interested to know if they were awkward to fly with the throttle stagger taken out, say at a change of throttle possition on approach.
regds tuffty  Smile
mandala499
Mon Jun 03, 2002 4:00 pm
if it staggers, won't they just rudder trim or aileron trim the plane ?
Mandala499
Mr.BA
Mon Jun 03, 2002 7:12 pm
Rudder trim? The B747 has four engines though. How is it to help? Any B747 classic pilots?
Boeing747 万岁!
Panman
Mon Jun 03, 2002 7:55 pm
Mandala think about it.
Q: Why do they stagger the throttles?
A: To have the engines producing the same output more or less.
Q: What would happen if they didn't stagger the throttles?
A: Each engine would produce a different amount of thrust.
Q: What side effects if any would arise?
A: Each engine producing a different amount of thrust, each engine having a different fuel consumption.
Q: What are the benefits of staggering the throttles?
A: Like mentioned previously engines producing same amoung of thrust more or less, all gauges on the panel reading the same more or less, thus making it easier to see if there is a problem with one engine as it's corresponding gauge would be out of line with the others.
Q: What does rudder trim do then?
PanMan
mandala499
Mon Jun 03, 2002 9:14 pm
PanMan,
My question is what happens when the pilot hand throttles the plane if staggering is required... ??? how do they deal with it ? I was guessing rudder trim...
Mandala499
BR715-A1-30
Mon Jun 03, 2002 11:32 pm
Why do they have to stagger the throttles. What I mean is why do the engines produce different amounts of thrust if you dont stagger them. Why aren't they like the 717 where both throttles in the same place equals both engines at the same thrust.
Photo © Dean Barnes
Note how the throttles are staggered in this picture.
Puhdiddle
barney captain
Tue Jun 04, 2002 2:31 am
In a perfect world, they would all be in alignment. From time to time, it's not at all surprising to find a little out-of-rig situation. Typically, you just match the N1 to produce symmetrical thrust. When hand flying during an approach, I usually match fuel flow and yes, some times there is a little throttle split but it is usually easily managed.
Southeast Of Disorder
JETPILOT
Tue Jun 04, 2002 4:05 am
The amount of discrepancy of mis-rigged throttles has a limitation... I think it's one knob width from any other throttles.
When handling the throttles while manouvering as in an approach situation the throttles are moved as a group. When the engines stabilize I will look down at my EPR and make a quick adjustment.
The amount of throttle mis-rigging permited doesn't allow for large errors in engine trim.
I have written up throttles with large discrepancies beyond limitations.
During most of the flight the engines will be trimmed by the flight engineer after the captain makes the initial power adjustment. ex. cruise to climb power.
The only time they are not trimmed by the engineer are in manouvering situations.
Rudder trim in never used in this situation.
JET
air2gxs
Tue Jun 04, 2002 11:18 am
The limits we use in our MM are:
Up to 1 knob from difference, no action required
1 to 1.5 knobs defered for 5 days for trim run and correction
Over 1.5 knobs must be fixed before further flight
A throttle on a classic can be out of rig for several reasons, but the miost common we come across is a slowly wearing jet fuel control. This normally requires trimming the fuel control under controlled circumstances until the throttles match or the fuel control is replaced because the trim screw is bottomed out.
mandala499
Tue Jun 04, 2002 6:23 pm
OK.. thanks for the answers.
4 engines in staggered poses an interesting question. How about the AN225 and B52 pilots?  Smile
Mandala499
VC-10
Tue Jun 04, 2002 6:25 pm
On a JT9 another cause of throttle stagger is the Engine Vane Control going off schedule. Our Co policy was to carry out an EVC trim every year to bring the EVC back on schedule.
To expand on Air2gxs's comment, as the the JFC wears it tends to lean off the fuel.
Another cause on all engine types is bleed air leaks or internal engine damage.
exPratt
Wed Jun 05, 2002 4:10 am
No two engines will ever have the same performance. Not even two new production engines in serial number sequence will have the same performance. Most of the time, the differences in performance between engines is fairly slight so there is not much if any change in throttle position. The bigger the engine like a JT9D, the more likely it will show throttle stagger than it will on a small engine like the BR715. In addition to the items previously listed, another cause for throttle stagger is engine deterioration. As the engines age, the throttles have to pushed higher to attain a given amount of thrust. With engines of similar vintage installed, the added throttle push is not noticeable because the engines will most likely age the same and the throttles will be pushed forward similar amounts. If one of the older engines is replaced, the throttle for the newer engine will not have to be pushed as high as that on the older engine to attain the given amount of thrust, hence the throttles become staggered and difference becomes obvious. Engine deterioration can be many things: worn compressor and turbine outer air seals, bowed or burned turbine nozzles, dirty compressors. As was previously stated, there are limits on how far the throttles can be staggered. Most allow up ot one knob width before maintenance has to adjust the throttle rigging or engine trim.
bio15
Relation With Fadec
Wed Jun 05, 2002 6:52 am
The reason for 747-400 and more modern aircraft not having the need of staggered their throttles, is that they have FADEC (Full Authority Digital Engine Control) which is the fly-by-wire of engines. Depending on throttle position, the system controls the adequate fuel flow electronically. No direct mechanical links from the throttle levers. This is more reliable as to precission, and that's how the same thrust (more or less) can be generated on all four engines without the staggering.
-bio
Tuffty
Wed Jun 05, 2002 8:58 am
yeah thats right on the 400's yove got a trim plug on the fadec that denotes the max thrust rating making it an "h" or "g" rated engine. this will also allow the engines performance to be flat rated so that at ISA conditions you are given an exact thrust rating which is acurate. this alllows any differences in the engines from manufacture to be alleviated.
regds tuffty  Smile
Tue Jun 11, 2002 11:13 am
Flying a 747 (or any other 4 engine aircraft - I flew the 707s and DC8s as well) is never a problem, power adjustments are done by "feel" and, if necessary, by asking the flight engineer to adjust EPR (on the JT9s) or N1 (on the CF6s)...
As a matter of fact, I would sometimes "stagger the power" in cross-wind landings... And flying an "ILS" in real life (or in a simulator) requiring a very slight power adjustment, I would do it, using the "inboard" engines only, such as pushing "half a knob" on both "inboards" to gain an extra 2 or 3 knots on the approach (Vref) speed... never a problem... hell, we practice with outboard engines "out", even with "two engines out" on the same side... the 747 is a very easy and stable aircraft to fly...
Skipper
Mr.BA
Tue Jun 11, 2002 4:56 pm
Thanks a lot everyone for the responses. Certainly learned a few things from this thread. Thanks!
747Skipper:Does the B747 (except -400) have autoland?
Cheers!
alvin
Boeing747 万岁!
Users browsing this forum: ro1960 and 1 guest
