flyn
Air-Tanker Crash
Tue Jun 18, 2002 7:04 pm
Reno station KOLO-TV's news crew was interviewing a man watching the skies with his own camcorder near Walker Sporting Goods Mobile Home Park when the plane came into view.
The plane came in low to the ground trailing a red flow of fire retardant above tall green pines. Both wings suddenly snapped off, with flashes of flame as they separated
I say to much G force on the wings.
ExitRow
RE: Air-Tanker Crash
Wed Jun 19, 2002 6:19 am
Video: http://www.komotv.com/stories/18951.htm
Aren't C-130s designed to take wingloads higher that those experienced by fire duty?
ExitRow
Wed Jun 19, 2002 6:21 am
JETPILOT
Wed Jun 19, 2002 10:25 am
The manner in which these wings came off indicate the plane was simply stressed and thatfatigue wasn;t to play.
As a testament to engineering..... both wings seperated at once.
Had fatigue or corrosion taken place the chances of it affecting both wings in the same place and to the exact same degree would be astronomicly improbable.
A Partenavia twin was also caught on video sometime in the early 80's with both wongs folding at the same instant during an airshow demonstration.
The pilot overstressed the airframe.
Abrupt elevator movements can easilly overstress an airframe especially if you are over VA. Over VA your going to damage the aircraft before the wing stalls.
JET
EssentialPowr
Wed Jun 19, 2002 1:13 pm
Jetpilot,
What, exactly, is fatigue?
flightsimfreak
Wed Jun 19, 2002 3:05 pm
Fatigue = stress.
filler
JETPILOT
Wed Jun 19, 2002 3:38 pm
Is that a tick question? What is fatigue?
JET
FredT
Wed Jun 19, 2002 8:24 pm
Fatigue most certainly does not equal stress. Stress is the load put on the structural members. Fatigue, in this context, is metal fatigue, or the reduction in ability to carry loads which occurs if a structural member is subjected to repeated stress above a certain threshold.
Over Va, you will overstress parts of the aircraft, most typically battery or engine mounts. That means inspection and that there is no guarantee you won't damage the aircraft. It won't break instantly though, engineering might be a precise science these days but it's still not THAT precise.
If one wing breaks off, you will have a roll moment and a loss of about half your lift. This will mean an angular acceleration around the roll axis and a downward acceleration. The downward acceleration will momentarily increase the angle of attack, and with it the aerodynamical loads, of the already highly stressed wing on the other side. Perhaps it is not all that surprising to see both wings give up together.
Fatigue, although the understanding of this phenomenon is relatively speaking rather recent, is surprisingly predictive. This means that two members, such as two wing mounts, which have been put through the same number of cycles of the same loads will be similarly weakened by metal fatigue.
Fred
LMP737
Thu Jun 20, 2002 12:33 am
It's just been reported that the aircraft had undergone repairs for cracks in the wing. LMT aircraft tend to have rigid wings. In fact the C-5, C-141 and Electra have had issues with cracks in the wings. Earlier this year the wing on a C-141 fell OFF while being refuelled.
Accidentally
Thu Jun 20, 2002 12:57 am
That C-141 wing "came off" because the tank vents were plugged. The air inside couldn't be displaced so it popped.
Indianapolis, IN
EssentialPowr
Thu Jun 20, 2002 1:36 am
Jetpilot,
Fatigue as it relates to a/c design is continued stress cycles accompanied by strain or creep, which is localized and slight elongation (for metals, technically a realignment of the grain structure) of the material, which will ultimately lead to a failure. Stress/Strain curves are basic materials science.
My point is that an apparently symmetrical wing fatigue does not in any way preclude fatigue as a cause, as crack propagation and fatigue are related. The Navy had a similar, symmetrical A6 wing failure due to fatigue years ago. The result was a restricted G limit on the a/c, which extended the airframe life until the a/c were retired or rewinged.
Does any one know if fire retardant is corrosive?
Thu Jun 20, 2002 2:09 am
I'm not positive about it being corrosive, but I don't think it is. I say that because I understand that the slurry is a combination of water and some type of fertilizer. Our hangar is adjacent to a tanker base (we have to taxi around their slurry hoses) and the ground crews make no effort to keep if off of the airplanes. (It actually makes a pretty good mess by the end of the season.) The plane that crashed was an early model C-130A operated by Hawkins & Powers. I have seen it here several time during past years. One of our pilots, a former fire pilot, knew some of the crew. The early C-130s are pretty old. Butler aircraft has one that is a year older than one of their fire fighting DC-7s. I believe that those aircraft are operated in the restricted category, so I don't know if they carry "black boxes" or not, but I really doubt if they are required to. It's hard to say what happened, but it sure looks like a combination of fatigue and overstress to me.
Thu Jun 20, 2002 2:36 am
I tend to agree with Jetguy regarding the possible causes. From the video, the crew could not have pulled more than 2g's from that maneuver so I don't think pure overstress was the case. Now, for a firefighting aircraft, the C130 must have had hundreds if not thousand of cycles of the same maneuver, putting stresses on the same points year in and out.
One thing about the causes, we will know definitively soon enough since it will be relatively easy for investigators, when looking at the broken wings to tell the differences between the break lines caused by overstress (45 degrees shear) and fatigue (rings of discolor patterns).
Nut
Notar520AC
Fri Jun 21, 2002 1:05 pm
Keep in mind, a paperclip can only be bent so many times before it snaps, however in a normal a/c I don't think that would be the case, but with the weight of the fire retardent on board the the g's being pulled leveling off from that maneuver, I would say that was a factor, not the cause.
Also, that same aircraft was involved in a bullet fire fight earlier in it's life, which was also probably a factor.
Now I'm not jumping to conclusions, but I can't think of many more things that could have caused that crash. I viewed the eye-witness video, and I have never heard nor seen anything like that EVER.
BMW - The Ultimate Driving Machine
L-188
Fri Jun 21, 2002 3:06 pm
I don't have a link to it but apparently this aircraft did have a wing crack repair about four years ago.
The news being the news, I don't know what the repair was for but it is and interesting development.
I watched H&P's PB4Y and their KC-97 doing drops on a fire at North Pole, Alaska about a month ago. I didn't think those guys where really putting that much stress on the aircraft with what they where doing.
paulc
Fri Jun 21, 2002 4:32 pm
The wings folding up on the C130 is not a new thing - as I understand it when the RAF ordered them they opted not to go for the uprated wings as offered by lockheed despite there having been a similar crash. This was done for cost reasons (about £7000 per aircraft on 66 ordered) However this changed when a test rig of the centre box wing section failed at Marshall in Cambridge much earlier than anticipated. All RAF C130s were grounded for a time while an inspection team check each one before flying them to be modified (£250,000 per plane) Military versions were fitted with G meters to allow crew to monitor this.
English First, British Second, european Never!
Users browsing this forum: citrusrsw, MrBuzzcut, prebennorholm and 2 guests
