lmml 14/32
Recycling The Flight Director
Sun Jun 30, 2002 11:24 pm
Why and when is it necessary to periodically recycle the flight director?
RE: Recycling The Flight Director
Sun Jun 30, 2002 11:41 pm
Huh???
Sounds like an avionics problem to me.
lmml 14/32
Sun Jun 30, 2002 11:52 pm
To tell you the truth I have only seen this happen once in recent years. I was in the cockpit of a B733, glass cockpit, and one of the pilots decided to recycle both FD's as we were turning base (the pilot toggled the small switch on the MCP). I remember with the old B720's pilots used to do this quite often. Even several times in one flight. But I have never seen this happen on modern aircraft. I am now more curious than before.
Photo © Philipp Brumann
Mon Jul 01, 2002 12:53 am
I've been flying F/D equipped aircraft for nearly 25 years and EFIS equipped aircraft for 15 years and I'm not sure what you're talking about. (Obviously, I never had to do it.) We do have a button which we can press it clear the V-Bars from the display when they aren't wanted, but its use is purely a pilot preference issue. Is this what you're talking about?
lmml 14/32
Mon Jul 01, 2002 1:58 am
In the case of the B733 it is not a V-bar. There are cross hairs. But it's the same thing.
Rick767
Mon Jul 01, 2002 2:09 am
Sometimes the thing just goes wonky. Flippin the switch resets the flight director system and will do the trick 99% of the time.
Both switches must be switched off at the same time to re-cycle the system.
One thing that I just thought of is taxying out to the runway sometimes the F/D pitch command bar decides to stop indicating 8 degrees nose up, as it should in "TO" mode. The only way to clear the problem is switch both F/D switches OFF then return to ON again. This is for the 757/767 and is a known problem (documented procedure).
It's still quite rare though.
airplay
Mon Jul 01, 2002 2:19 am
I've heard of recycling a transponder (pull 1 CB) or an AHRS system (pull 2 CBs) but not a Flight Director. Not to say it can't be done though....
I wonder if you are talking about the vertical sync. Many flight director systems have a button that allows you to "reset" the vertical command to center.
Other than that the only thing I can think of is that the software in newer "digital" systems have the tendency to "go off into the weeds". The only way to get things straight again in these systems is to recycle the power or "re-rack" the black box.
Software in flight control systems including the flight director computer is typically very robust as compared to other less critical systems. The need for resetting is minimal.
lmml 14/32
Mon Jul 01, 2002 2:24 am
Both FD switches where recycled, like Rick767 said. The funny thing is that the pilots had planned for this recycling during descent. It could therefore be a known fault on that particular aircraft.
Rick767
Mon Jul 01, 2002 2:41 am
LMML,
This is not a 733 procedure that I am aware of, so yes it sounds like a known fault on that aircraft.
Users browsing this forum: No registered users and 9 guests
