BR715-A1-30
What Is The Sound Of BR715 During Start-up?
Sat Jul 06, 2002 2:06 am
Right before the Fan starts turning on the BR715, it makes a low-pitched whine sound, and then the whole rear cabin vibrates until it gets started. What is that low-pitched whine sound before the fan starts turning. Just another reason to like ROLLS-ROYCE
Puhdiddle
wilcharl
RE: What Is The Sound Of BR715 During Start-up?
Sat Jul 06, 2002 2:53 am
are you obcessed with this engine.... it is a great little motor, but it had alot of headaches at first with the FADEC and uncommanded shutdowns. she takes alota air to get her going too... a standard MA1A air cart will not blow her over, you have to use a Y coupler and two of them. there is a very noticible oepning of the start valve/air wusshing (is that a technical term) in to the engine during start, then the engine vibrates until it smooths out.. the start sequence is incredably long on the 715 complared to the old JT-8D... I miss FL alot at times, but Im in a much better place, and looking back I realzied that FL and the 717 was not the greatest thing since sliced bread like I once thought....
BR715-A1-30
Sat Jul 06, 2002 5:06 am
I am obsessed with this engine. She sounds so SWEEEEEEEEEEEEET!!!!!!
The MA1A Air Cart is used for engine inductions arent they. I know the JT8Ds have quite a few of those happening now. I have only seen 1 717 get it, and they only used one of the carts.
Puhdiddle
wilcharl
Sat Jul 06, 2002 5:16 am
the MA-1A is a pneumatic ground cart oftne called an Airstart... its udsed when the APU is inopperative.. basicly a little gas turbine in there that provides bleed air... the new Stewart & Stephensons carts are diesels and put out enough air that only one is required and it can also be used to run air conditioning on the gournd... it has a very sexy sound... worth requesting bac by the engine now that FL assigns seats in advance.. on take off it has the sawmill sound of a high bypass CF-6 or RB-211
BR715-A1-30
Sat Jul 06, 2002 6:39 am
WilCharl, I always sit in seat 27A on my flights on the 717... I love that Sawmill sound. It continues until we get to at least 15,000 feet. The BR715 is a cute engine with great sounds.
Puhdiddle
777236ER
Sat Jul 06, 2002 6:43 am
Girls are cute. Engines are....um....engines?
KFRG
Sat Jul 06, 2002 1:19 pm
The whining sound during start-up you hear is most likely the way the air is flowing by the injectors in the burner-cans. That sound is heard on a few others engines as well.
-Tommy
LMP737
Sat Jul 06, 2002 4:35 pm
During testing of the 717 it was actually uncomfortable to be around the BR715 when it started. The fix was to change the spray pattern of the combustor.
BR715-A1-30
Sun Jul 07, 2002 5:25 am
The BR715 doesn't have Burner Cans. It has a single Annular combustor ring. That is why it isn't as smoky as older jets. Only older jet engines have the burner cans which cause them to be so smoky. (Black Smoke that is)
Puhdiddle
wilcharl
Sun Jul 07, 2002 6:33 am
correct me if im wrong JT8 guys but the JT8-D has a can-annular combuster... (i slept alot in turbines class)
I guess the -715 is a cute engine.... its nice and thick in the right places just like a beautiful black woman
i always thoguth the cutest engine was the rolls royce spey with hushkits on the BAC-111
B1C17L1011
Mon Jul 08, 2002 7:20 am
I think the sound of the BR715 on start-up is very similar to the sound that the old RB211-22B's on the original L1011 made during start up. I fairly recently got to hear an ATA L1011 start her engines one by one. The sound was absolutely great!
B1C17L1011
Tue Jul 09, 2002 11:33 am
On another note, is the BR715 a twin or a triple spool engine?
Leftypilot79
Tue Jul 09, 2002 2:05 pm
Heres a snipet from RR website on the BR700 series engine.
The BR700 family meets the power requirements of regional aircraft with between 80 and 130 seats and those of ultra long-range business jets.
Both engine family members use the highly efficient BR700 engine core, suitable for high cyclic operation for thrusts between 14,000lb and 23,000lb. This core incorporates a ten-stage HP compressor, a low-emission annular combustor with 20 fuel burners and a two-stage shrouded high-pressure turbine. All stages are optimised to keep noise to a minimum.
The BR710’s low-pressure system features a 48-inch diameter fan driven by a two-stage low-pressure turbine and the BR700 core. The engine made its first run in 1994, right on schedule. Its first flight – powering the new Gulfstream V – was in November 1995. Certification was in August 1996, again right on schedule. The first flight of the Bombardier Global Express took place in October 1996 followed by BR710 engine certification in January 1997.
The BR715 features a 58-inch fan and a two-stage booster driven by a three-stage low-pressure turbine. Its selection to power the Boeing 717 is due to its combination of high performance, environmental friendliness, low cost of ownership and low risk derivative technology approach.
Technical details: Two-shaft, high-bypass-ratio engines. Both BR700 engine family members incorporate the BR700 core engine, with a ten-stage HP compressor, a single low emissions annular combustor with 20 burners and a two-stage shrouded HP turbine. Different thrust levels of the two engines are realised by adapting the LP systems. In the case of the BR710 the 48-inch diameter fan is driven by a two-stage LP turbine, while the BR715 features a 58-inch diameter fan and a two-stage booster driven by a three-stage LP turbine.>
Heres the website also.
http://www.rolls-royce.com/civil/products/turbofans/br700/Default.htm
BR715-A1-30
Sat Jul 13, 2002 6:44 am
Actually I meant to say the Low Pitched Whine is a Low Pitched HUM sound. Until the fuel is turned on. It sounds great nevertheless
Puhdiddle
Users browsing this forum: CV990A, heavymetal, PHLapproach and 1 guest
