Mr Spaceman
B-1B Bomber Shock Wave Vapour?
Thu Jul 18, 2002 2:57 am
Hi guys.
In the info section of photo below, the photographer states that this USAF B-1B Bomber is making a high speed pass very near the sound barrier. Obviously, if this B-1B did break the sound barrier, the photographer (and everyone else in the neighberhood) would have known it.
My question is: How much faster would this B-1B have to be going to break the sound barrier and create a sonic boom? If it is already causing a shock wave that's forming a cloud of vapour, then wouldn't it be very close? (as in only a few mph short of the speed required).
Photo © Gregg Stansbery
Chris  Smile
Mr Spaceman
RE: B-1B Bomber Shock Wave Vapour?
Fri Jul 19, 2002 12:35 am
Hi guys.
Well, I guess this question is GOING, Going, going, almost gone!
Chris  Smile
nikes
Fri Jul 19, 2002 1:34 am
- I believe that parts of the aircraft are already "locally" supersonic. This is due to acceleration of air over the lifting surfaces that pushes the local air to supersonic velocity. I would est. that aircraft speed in the .6 to .9 range.
Nikes
peterba69
Fri Jul 19, 2002 1:53 am
I saw this same effect on a Blue Angel F/A-18 in SFO about 5 yrs. ago, and the guy was about 100' above the water. The announcer said he was doing 750 mph. At sea level, on a Standard Day, the speed of sound is 766, so the explanation of locally supersonic is correct.
Mr Spaceman
Fri Jul 19, 2002 2:01 am
Thanks for your replies gentlemen.
I figured that if the B-1B in the photo wasn't breaking the sound barrier, than the transition from subsonic to supersonic flight must have been very close.
COOL photo!
Chris  Smile
peterba69
Fri Jul 19, 2002 2:12 am
Here's a link to some cool shots in SFO, check the rest of this guys site as well:http://www.airshowaction.com/flw98/flw98.html
captjetblast
See The Video At...
Fri Jul 19, 2002 2:52 am
http://www.wilk4.com/misc/soundbreak.htm#video
Mr Spaceman
Fri Jul 19, 2002 2:57 am
This should help your link Capjetblast.
http://www.wilk4.com/misc/soundbreak.htm#video.com
Chris  Smile
captjetblast
Another One
Fri Jul 19, 2002 3:05 am
http://faculty.rmwc.edu/tmichalik/movies/F-18.MPEG
Mr Spaceman
Sat Jul 20, 2002 2:12 am
Hello Captjetblast.
I suspect that your links are not working because you're forgeting to add the .com and the two arows < > before and after the address. That's all I've been adding to get your links to work.
OK, lets check out this site. Thanks for the link.
http://faculty.rmwc.edu/tmichalik/movies/F-18.MPEG.com
Well, it appears that the link is not active.
Chris  Smile
Accidentally
Sat Jul 20, 2002 11:22 am
Indianapolis, IN
Users browsing this forum: GalaxyFlyer and 20 guests
