Trent_800
Are Hovercraft Engines Used On Any Plane
Mon Aug 05, 2002 9:38 pm
Ive just watched "Big Stuff" on Channel 5 (UK) and the worlds largest hovercraft was on it, operating from the UK to France and back. It has 4 Props on it, each powerd by a Rolls Royce engine. Now the Narrator didnt say weather or not they were Gas turbine, Deisel or petrol engines. If they were Gas turbine (I.E. Massive turbo props) are the engines used on any aircraft?
Whiskeyflyer
RE: Are Hovercraft Engines Used On Any Plane
Mon Aug 05, 2002 9:57 pm
I did not see the programme but the marine version of the RR Proteus gas turbine was used on the SRN4 hovercrafts. The aviation version of the engine was used on the Bristol Britannia aircraft.
Other versions of the engine where used for emergency electric power backup systems (appartently one was on top of the Natwest tower in London, I don't know if its still there).
pmk
Mon Aug 05, 2002 10:36 pm
The question should be: Are aircraft engines used on Hovercraft? The answer is yes.
Peter
Trent_800
Tue Aug 06, 2002 1:31 am
PMK, I was refering to a certain model of hovercraft. And all i wanted to know was the Model of aircraft that used the engines.
jetdoctor
Tue Aug 06, 2002 2:28 pm
Don't quote me on this, but I think the hovercraft in question is powered by 4 Rolls Royce Darts. If that is true, there are many aircraft powered by the Dart. HS-748, F-27, and YS-11 to name a few.
RT
Break ground, and head into the wind. Don't break wind and head into the ground.
Tue Aug 06, 2002 6:42 pm
The Proteus was used on the Bristol Britannia.
Users browsing this forum: Dalmd88 and 4 guests
