LZ-TLT
Townend(sp?) Engine Cowling
Sat Aug 17, 2002 7:19 pm
Doing some research on 20's and 30's aircraft I noticed a variety of aircraft with radial engines being fitted with the so-called Townend(or Townsend) engine cowling. Could somebody explain what the reason and the benefits of using such a cowling were?
L-188
RE: Townend(sp?) Engine Cowling
Sat Aug 17, 2002 7:58 pm
Wasn't that the equivlent to the NACA cowling?
Just shooting from the hip here folks.
FBU 4EVER!
Sat Aug 17, 2002 10:35 pm
The Townend Ring was a British design that appeared just after the First World War and was extensively used on British A/c until the early -30's.I'm not sure but I think NACA developed this design into the NACA Cowling which had a somewhat longer chord and better airflow characteristics on the inside to aid cylinder cooling.
"Luck and superstition wins all the time"!
LZ-TLT
Sat Aug 17, 2002 10:54 pm
FBU 4EVER,
So the benefits of the Townend Ring were better airflow for engine cooling?
lapa_saab340
Mon Aug 19, 2002 5:26 am
The Junkers Ju-52 is a good example with both Townend and NACA cowlings (Center engine had the Townend ring, and the two wing engines the NACA cowls)
FBU 4EVER!
Tue Aug 20, 2002 6:29 am
Yes,LZ-TLT,the result was better cooling.By tapering the aft opening,the air that was heated and expanded around the engine had to accellerate through the cowling,thus increasing cooling efficiency.
The P-51 Mustang received a 15 mph speed increase by the radiator cooling air.Sort of jet effect,really.Whether this was the case with Townend/NACA cowlings too,I don't know.
Users browsing this forum: MileHFL400, Starlionblue and 8 guests
