Arsenal@LHR
Engineering Consoles On 777's
Sun Sep 08, 2002 6:06 am
An interesting piece of equipment on the 777's that i never knew existed. What is the 'Engineering console used for? And do other aircrafts have this device?
Photo © Siegfried Huss
Rdgs
Arsenal@LHR
In Arsene we trust!!
Mr.BA
RE: Engineering Consoles On 777's
Sun Sep 08, 2002 12:36 pm
Only the B777 have this device. It's called the maintenance panel. It's a system used to check if everything is working correctly such as GPS, radios.. etc.
Boeing747 万岁!
cdfmxtech
Sun Sep 08, 2002 1:36 pm
That is what is called the MAT (Maintenance Access Terminal). Just about all maintenance tests are done from this panel. I understand that the B747-400 also has a MAT, so this is not new technology.
Arsenal@LHR
Sun Sep 08, 2002 10:01 pm
OK, thanks for the replies. Really. i thought it looked like something out of the USS enterprise! Big grin
But since the 777 is a new breed of an airliner, i suppose it's no suprise. Never knew 744 had it also/
JohnM
Mon Sep 09, 2002 11:31 am
The good ol C-5 has a similar system. It has changed quite a bit over the years, I imagine the 777 system is MUCH improved over what the C-5 has. The C-5 has MADARS (malfunction analysis detection and recording system). Pretty much hated by all that touch the system!
jsuen
Mon Sep 09, 2002 5:32 pm
The A330/340 has the Central Maintanence System and the 320s have the Centralized Fault Display System. It works pretty much the same way, integrating fault and test access, but its accessed through the pilots' MCDUs.
Arsenal@LHR
Mon Sep 09, 2002 10:45 pm
Anyone know what sort of power source it runs on, a microprocessor or a chip of some kind? The graphics on the screen look familiar.
victech
Tue Sep 10, 2002 5:16 am
The 777's primary computers are custom-programmed in ADA and run on Intel, AMD and Motorola microprocessors (for redundancy and attackproofing).
