UPS763
767/757 Cockpit Differences
Fri Sep 20, 2002 6:03 am
Hi all,
Is there any difference between the 752 and 762/3 cockpit? I might be wrong, but dont pilots share a type rating on both aircraft? Are the flight decks exactly the same?
Also with regards to Continental's 762s and Hawaiian's 763s, I believe Continental aircraft have the similar 777 flightdeck, are Hawaiian's 767s equipped the same way?
Thanks for everyone's help in advance.
Matt
victech
RE: 767/757 Cockpit Differences
Fri Sep 20, 2002 6:16 am
One difference is that one steps up to enter the 767's flightdeck and steps down to enter the 757's flightdeck...
exnonrev
Fri Sep 20, 2002 6:57 am
With the exception of a few switches on the aft center console, Continental's 762s and 752s have completely identical cockpits. The 753 has some slight differences in a few switch panels, but their locations are the same as the 752/762.
CAL's 767-400s (like all 764s) have the 777-style layout. They all have a common type rating.
242
Fri Sep 20, 2002 7:15 am
There are slight differences throughout the flight decks, it really depends on the operator. The only major difference I can think of, besides the already mentioned aft pedistal cargo fire switches/ lights, is the hydraulics panel on the lower left overhead.
An interesting note, when I was attending a 757 fam class, there was a cockpit mock up of a 752 on one wall and a 763 on the other. No one, including me, noticed the differences between the two until the instructor pointed them out.
cdfmxtech
Fri Sep 20, 2002 9:34 am
No, they don't.
The B767-200s have a panel for Fuel Jettison. B757s don't. The B7672 has a very different maintenance panel (P61) than the B757. The Hydraulic control panel is a little different. Anti-Ice panel is different to allow an added system.
There are a couple more if I really think hard, but I'm hungry!!
Pilot1113
Fri Sep 20, 2002 12:57 pm
I keep tripping on those damn steps! It's really embarrassing when I visit the cockpit and try to act all professional and then take a header into the cockpit. I also manage to hit my head on the overhead panel, which also adds to my embarassment.
- Neil Harrison
AAR90
Sat Sep 21, 2002 1:58 am
Neil, Boeing designed the cockpit door so you wouldn't embarrass yourself. Pull the door open = gives you time to see the step down. Push the door and your foot hits the step up before you trip.  Big thumbs up
HAL
Sat Sep 21, 2002 9:10 am
Hawaiian's 763's (and CO's 762's) have the original style cockpits. The only 767's with the 777 style displays are the 767-400's. There hasn't been any aircraft of the -200 or -300 series fitted (or retrofitted) with the new cockpit.
HAL
One smooth landing is skill. Two in a row is luck. Three in a row and someone is lying.
Pilot1113
Sun Sep 22, 2002 3:24 pm
Keep that in mind next time!  Big thumbs up How much for the tip?  Big grin
- Neil Harrison
Users browsing this forum: rjsampson, WholaLottaLove and 2 guests
