Julien.M
Airbus NAME: What's That X!
Mon Sep 23, 2002 7:38 pm
Hi,
I'm wondering for quite a while what does the (X) in 330, 340 names means?
ie: Birdy Airlines has 3 A330-301 (330 serie 300 with GE engines): OO-SFM, -SFN, -SFO.
But what does the X means in A330-300 (X)??
HL7553 A330-323 from Korean Air is a 330 serie 300 with PW engines and the X??
By the way does anyone know where to find a list where you can find detailed explanation of the last digit of Airbus names? (ie: the "1" in A330-301)?
thanks you by advance!
Regards.
Julien  Smile/happy/getting dizzy
tsentsan
RE: Airbus NAME: What's That X!
Mon Sep 23, 2002 8:44 pm
eXtended Range.
Thats what it means on the A340-313X.... not sure about the 330.
NO URLS in signature
Rick767
Mon Sep 23, 2002 8:51 pm
Same meaning on the A330 I think. The last 3 digits of the Airbus codes refer to the engine type fitted to the aircraft I think.
For example:
A320-211 is an A320-200 with GE CFM56-5A1 Engines
A320-212 is an A320-200 with GE CFM56-5A3 Engines
A320-232 is an A320-200 with IAE V2527-A5 Engines
etc....
The A340-313 has CFM56-5C4 Engines
Minuteman
Mon Sep 23, 2002 10:03 pm
I might be wrong on this one, but I always thought the last three digits for Airbus were:
First Digit: series number ("100", "200")
Second Digit: Engine Manufacturer (1=CFM, 3=IAE)
Third Digit: Flight Control Software Revision Number
I'd appreciate it if someone could correct me on this.
justplanesmart
Tue Sep 24, 2002 10:27 am
Minuteman, you are mistaken, and Rick767 has the correct explanation. the second digit is the engine manufacturer (0=GE, 1=CFM, 2=P&W, 3=IAE, 4=RR, and I do not recall what is the one for the joint Pratt/GE engine for the A380). The third digit is the specific engine variant for that aircraft, so the A330-321 has the PW4164, the A330-322 has the PW4168, and the A330-323 has the PW4168A.
"So many planes; so little time..."
bio15
Fri Sep 27, 2002 10:13 am
Hi, can anyone tell me if Boeing's codes work the same way?
Minuteman
Fri Sep 27, 2002 10:40 am
Sure enough... its another engine code, thanks.
As for a list of detailed meanings, I was provided this page.
9V-SVA
Fri Sep 27, 2002 4:33 pm
The first digit is the model number, the second digit the engine version(1 for CFM, 2 for PW, 3 for IAE and 4 for RR), and the last digit stands for the engine variant(eg PW4168,PW4172,RR Trent 772B etc...)
For example, an A340 can have the following codes:
A340-211
A340-311
A340-312
A340-313
A340-313E
A340-541
A340-642
9V-SVA
9V-SVA | B772ER
SailorOrion
Mon Sep 30, 2002 9:49 pm
The GP7XXX on the A380 has the code '6'. Initial models are
A380-841 (RR Trent 900)
A380-861 (GP 7200)
A380-843F (RR Trent 900)
A380-863F (GP 7200)
SailorOrion
larspl
Thu Oct 03, 2002 1:20 am
-->bio15
boeing code's work diferent:
model type customer
737 - 8 K2
(K2 is boeingcode for transavia airlines [the netherlands])
on www.bird.ch/bharms you should be able to find the other codes i think...
facebook.com/ddaclassicairlines
Users browsing this forum: boeing767322er and 1 guest
