lehpron
What Programs Do Avionics/comp Sys Run On?
Sun Sep 29, 2002 8:17 am
It is a combination of C/C++ or some newer versions of Fortran?
Is A++ Electronic certification or Computer certification?
opitional question: How long would the code be?
david b.
RE: What Programs Do Avionics/comp Sys Run On?
Sun Sep 29, 2002 8:40 am
Windows ME  Big thumbs up
Teenage-know-it-alls should be shot on sight
airplay
Sun Sep 29, 2002 12:16 pm
Avionics use a variety of programming means. The vast majority used for critical functions is special proprietary code on proprietary platforms. Conventional high level programming is not always appropriate.
Although operating systems like "Windows" find their way into aircraft, it's for operating non-critical functions like galley control.
RTCA DO-178 provides guidance to develop avionics software for various levels of criticality.
Ralgha
Sun Sep 29, 2002 7:12 pm
Avionics programs are probably programmed in mid-level (such as C/C++) or low-level (assembly) languages. Low-level languages have the disadvantage of being different for each chip architechture, though they are the fastest and most efficient. Mid-level languages are the same on all architectures (the compiler takes care of the architecture requirements) but are somewhat slower and less efficient than straight assembly.
High-level languages (FORTRAN, BASIC, Java) suck balls and shouldn't be used at all, even on PCs.
 Big thumbs up
Users browsing this forum: kabq737, Woodreau and 1 guest
