Cessnapimp
777 Engine Diameter
Sat Oct 05, 2002 3:30 am
Hello everyone,
Could anybody refer me to proof (website preferred) that the cowl diameter on the 777 is as wide as a 737- 200 fuselage. It would be much appreciated!!!
Grégoire
mb339
RE: 777 Engine Diameter
Sat Oct 05, 2002 3:53 am
http://www.airliners.net/discussions/photo_requests/read.main/6495/
On the above link there was an interesting comparison between a B737's fuselage and GE90. I tried to see the photos but it appeared not more available.
Anyway, for some technical data, try to check:
http://www.geae.com/lrgcom/ge90/serv_models_ge90.html
http://www.boeing.com/commercial/flash.html
bye
wilax
Sat Oct 05, 2002 12:46 pm
The GE90 is way big, but the PW and RR engines look smaller in diameter and they look alike too.
boeingnut
Sun Oct 06, 2002 1:57 am
Excuse me, but what does God need with a starship?
bio15
Sun Oct 06, 2002 8:18 am
"The 112-inch PW4000 also is our largest commercial engine, its diameter nearly as wide as the fuselage of a Boeing 737."
-Alfredo
DC10Tony
Sun Oct 06, 2002 9:53 pm
The 737's interior cabin width is 11'7", so that means the exterior fuselage diameter is about 12.5' right?
If the GE90 has a 10' fan diameter, and the cowling is a little bigger, then the 777 engine isn't as big as a 737 fuselage.
I'm just comparing numbers, I've never been up close to a 777 engine in person to see its size.
Whiskeyflyer
Mon Oct 07, 2002 6:47 pm
PW4084, 4090, 4098 fit in the following envelope:
Diameter 119 inches length 191.7 inches
(Source Aviation Week Aerospace Source Book 2002)
CCA
Mon Oct 07, 2002 10:32 pm
The GE 90 Fan is 123" so add to that the thickness of the containment ring (remember this has to contain a blade separation so it's not thin) plus the fact the EEC and Oil tank are mounted on the outside under the fan cowls so I would guess adding at least another 12-18" to either side to reach the fan cowl.
That's 147-159" (12'3"-13'3") diameter that's getting very close to the 737 fuse as DC10Tony said.
P1 in A330, A340, A346, B742, B744, B748.
Users browsing this forum: Armadillo1, OKCDCA and 11 guests
