Rai
JFK's Canarsie VOR Approach
Wed Oct 09, 2002 4:40 am
When planes land on JFK runways 13L and 13R, why do they use the Canarsie VOR approach? How come the ILS approach is never used? I’ve only heard ATC use the ILS approach once on the JFK ATIS and have never seen it in person. Does it have to do with noise abatement or maybe JFK’s proximity to LGA? JFK is maybe 10 miles south-east, and LGA flights are routed in such a way that the traffic patterns of the two airports won’t intercept.
Also, when was this approach pattern initiated? What are your opinions of it? Pilots, what are you comments on it? Also, are there any other airports that use such an approach? I know of Kaitak’s Checkerboard and LGA’s runway 31 expressway visual approaches, but are there any others?
Someone has mentioned that this is a visual approach. I have seen them use this approach in bad and foggy weather. How is this possible if it is a visual approach?
Thanks a lot for your answers!
timz
RE: JFK's Canarsie VOR Approach
Wed Oct 09, 2002 8:04 am
Just looking at the map, seems like a 12-15 nm straight-in approach to JFK's runways 13 would be a large pain for both LGA and EWR.
H. Simpson
Wed Oct 09, 2002 8:05 am
ILS 13L is never used is probably due to other (LGA, EWR) airports coordination. Imagine if you use ILS 13L, LGA has to use 13 for landing and EWR has to be forced to use 4L/R. I only heard ILS 13L was used once during a heavy fog and the visibility down to about 1/18 mile.
Being born in Hong Kong (IGS 13) and live right under expressway visual approach path. Visual approach always fascinates me a lot!  Nuts
Also Rai, which visual approach are you talking about in the last sentence? KaiTak's? If so, during heavy fog or typhoon (hurricane) 13 is not used unless the wind is really damn strong. The alternative is ILS 31 at KaiTak.
jcxp15
Wed Oct 09, 2002 8:30 am
He was talking about the LGA RWY 13 Visual (The expressway visual) approach, i believe.
As far as not using the ILS for 13L/R at JFK, like someone said, it would be a major pain for LGA and EWR traffic...
H. Simpson
Wed Oct 09, 2002 8:54 am
what do you mean by "someone" I'm right here yo!
anyway, i guess someone mean LGA RWY 31 and not 13
david b.
Wed Oct 09, 2002 9:12 am
Is this the right approach?
Teenage-know-it-alls should be shot on sight
Canarsie Approaches -
xxx
There are 2 approaches which you name the "Canarsie Approach" - One is a standard "instrument" VOR approach, with a MAP missed approach point located on the 041 degree radial, at the 2.6 DME point, the minimums (ceiling and visibility) are 800 feet MDA and 2.5 miles visibility, for both 13 L and R...
xxx
The other one is a "visual" approach - actually called "Parkway Visual" which is flown visually, but actually following the same ground track, that is the 041 degree radial, this approach requires 2,500 feet ceiling and 3 miles visibility...
As far as I am concerned, it is just a regular "visual approach" with a RH base leg - but the approach is published to guide the airplanes away from the "noise sensitive (residential) areas"...
xxx
To keep the neighbors happy, I fly the approach (a 747) with 20 flaps, and call the gear down and flaps 25 when starting the right turn for finals, this reducing the power required from the engines...
(s) Skipper
jcxp15
Wed Oct 09, 2002 10:26 am
H. Simpson:
Yea.. oops.. meant 31 vis at LGA, although there is the River Vis. RWY 13 as well...
B747Skipper:
Have you ever heard of a controller vectoring a plane to the right of Canarsie, (closer to JFK) to land on 13L? I was near JFK one sunny day, when they were using the Canarsie approach, when I saw this AA 757 or 767 flying a lot lower and a lot closer to JFK than the rest of the planes, and it made a steep steep almost 90 degree turn to the right and landed.. reminded me a lot like the pictures I've seen of Kai Tak. There was a plane fairly close behind it, but on the regular Canarsie path. I found this very cool, and always wondered what it would have been like to be on that plane...
H. Simpson
Wed Oct 09, 2002 11:03 am
Jcxp15, there's a lot of cool action from the CRI VOR App, one day I was standing at the spot for 13R and a aeromexico Md-82 just poped out from nowhere and make a 130 degree turn from around 2.6 DME and landed on 13R.
13R's landing is pretty amazing to watch, sadly not many planes land on 13R though
Rai
Wed Oct 09, 2002 11:24 am
Thanks for the responses so far, guys!
Homer and David: Are you guys from Queens? I'm from Jackson Heights. I live right under the landing path of LGA's runway 4 (they're landing over my house right now!). We should all get together for a spotting session one day. So far, Mirrodie, BigPhilNYC and myself have done a session at LGA. It was great fun. And David, do you really live that close to JFK?
Homer: 13R landings are used fairly often in the mornings and mid afternoons by DL and airlines using T1 when departure traffic isn't as intense. They choose this to cut down on the time it takes to taxi to the gate. And I was talking about the Canarsie VOR approach. Skipper said that it is generally done visually.
Skipper: I seriously doubt that noise abatement has anything to do with the Canarsie approach. Like I just said above, I live right under the approach path of LGA's runway 4. This is a primarily residential area and they often switch to this runway for landings after 10:30PM. Landings can last until 2AM. So, if they really cared about noise abatement, then they'd use the LDA approach runway 22, where they land over Flushing Bay.
Wed Oct 09, 2002 11:30 am
Landing on 13R from the 2.6 point is a little "tight" at times, by chance, there is a long runway to balance faulty judgements on glide paths... I much prefer 13L for landing, when visibility is somewhat "marginal" - I know exactly where the runway "is" thanks to landmarks well known - to me...
xxx
Never personally came "in" as described "inside" Canarsie, even though I am an old JFK dog... I was JFK based with PanAm for many years... nowadays it is a thrill for me to go back to my former "home" where I hardly recognize anything on the ground, including PanAm's Worldport... That Delta emblem brings tears to my eyes... 11 years already since DEC 1991... Know that three former PanAmigo pilots commited suicide in the few months after the end... By chance the Argentines adopted me, I have a new home, and will never will forget that... The Delta and United interviews in 1992 were an insult to me...
xxx
Sorry to write like this - PanAm was my family...  Smile/happy/getting dizzy
(s) Skipper
Rai
Wed Oct 09, 2002 11:34 am
Arrrgh!!  Angry That's why they should use the ILS approach!
H. Simpson
Wed Oct 09, 2002 12:09 pm
Hey Rai, I live in Forest Hills, contact me on AIM: Continental77720 and may be we can get together for spotting!
btw, Rwy 4 had been quite busy for landing for these couple days, any idea why? I missed a lot of action due to those damn SATs..
Jeff G
Wed Oct 09, 2002 6:52 pm
Arrrgh!! That's why they should use the ILS approach!
The minimums on the "Canarsie" VOR approach are relatively high, and within those minimums, this is a safe procedure. The ILS requires a long final approach segment stretching far into Queens toward LGA, and isn't necessary unless the visibility or ceiling is too low, the winds are too strong and out of limits for either 22L/R, 4L/R and 31L/R. Airline pilots are big boys; they can handle a turn or two on final.
timz
Thu Oct 10, 2002 10:01 am
Okay, suppose they were flying an ILS to 13L at JFK.
At 16.34 nm from the threshold you would pass above the final for 22L at EWR (at a point 6.29 nm from the EWR threshold). Is that a problem? Maybe not.
At 11.8 nm from the threshold you're over the middle of the Hudson. Arrivals to LGA runway 22 usually cruise north up the Hudson at 4000 ft, right? So they'd have to go elsewhere.
At 10.44 nm from the threshold you pass the Empire State Bldg, 0.12 nm left of your ground track. Charted elevation 1515 ft. Problem there? Maybe not.
At about 7.18 nm you would pass above the final for runway 4 at LGA (at a point about 3.55 nm from the LGA threshold). But LGA probably wouldn't be landing 4, so no problem there?
H. Simpson
Thu Oct 10, 2002 11:27 am
Timz, you don't understand how busy the skies of New York can get...
jcxp15
Fri Oct 11, 2002 6:36 am
Timz:
You also have departing traffic. Plus, they're not going to let a plane fly at the alt of the Empire State Building... it'd probably have to be at least 1000' above that, esp in bad weather...
So you'd need to be at least 5000' up to avoid LGA traffic (you could drop LGA traffic to like 3000' or 3500'), then at least 2500' above Midtown Manhattan.
If LGA is using 4 or Expressway visual 31, then the Hudson is no problem, but then you'd have to be still be at least 2500' over the ESB, and probably exceed that altitude to clear LGA traffic.
timz
Just For The Record...
Sat Oct 12, 2002 2:02 am
...I assume there's some reason the ILS to JFK 13L would be a pain for LGA and EWR. The point of my last post is that it's not immediately obvious which traffic would conflict.
If EWR is landing 22L their arrivals will be at maybe 2000 ft when they pass beneath the JFK arrivals which will be at maybe 5000 ft at that point. EWR departures off 22R are no problem.
If LGA is landing 22 and departing 13 the arrivals will have to cruise up the Hudson at 5000-6000 ft instead of their present 4000. Maybe this is a problem, but can anyone say how, exactly?
If LGA is departing 13 maybe they'd have to climb straight out instead of the customary initial right turn; aside from noise this is no problem?
I just mentioned the ESB for completeness; since JFK 13L approaches would ordinarily be at least 3000 ft at that point I assume its no problem, but if somebody knows better let's hear it.
I assume they couldn't land on LGA runway 4 while JFK was landing 13L, but how big a problem is that? If they wanted to use 4 at LGA they'd probably be using 4R at JFK anyway.
Rai
Sat Oct 12, 2002 2:43 am
Homer: I'm up any time for some spotting! My e-mail address is in my profile. Yeah, they've been using 4 for landings for the past two weeks! That's never happened before. It's usually a 2-3 day cycle for 22, 4 and 31 landings. But not lately...anyone know why?
I'll comment on a few points made thus far. The 4's are hardly ever used at JFK anymore. It has to do with their refitting (getting them ready for the A380's). They're being used right now, but that's because visibility is really, really poor today. Most likely, they'll switch to the 31's this afternoon, regardless of the weather.
As far as the LGA 13 climb, the initial turn has absolutely nothing to do with noise abatement, as it is directed over a very heavily populated area (Flushing). I couldn't explain why they make that initial right turn. Occasionally, they do the straight climb off 13, but that's only in very special circumstances, like during the U.S. Open. I should also note that when the 22's are being used at JFK, LGA 13 departures make a complete circle upon take-off.
Also, 22 landings depend on the take-off runway. If 13 is being used, then planes will cruise up the Hudson. If 31 is the departing runway, then they'll cruise up Queens, up to the Bronx, before turning to the final approach.
timz
A Clarification, Hopefully
Sat Oct 12, 2002 3:19 am
"when the 22's are being used at JFK, LGA 13 departures make a complete circle upon takeoff."
Most 13 departures make the initial right turn to a 180 heading (which I assume is intended to take them over Flushing Meadow Park). I guess some flights to Boston might make several right turns and eventually end up heading NE, and some flights to Florida might make a series of left turns and eventually (maybe five minutes later) end up heading south-- but I don't guess anybody ever makes a 360-degree turn, either direction, "upon takeoff", do they?
timz
Sat Oct 12, 2002 6:30 am
Back to JFK: I have the chart for the Canarsie approach to 13L/13R dated 12/68. No idea how long it existed before that.
Rai
Sat Oct 12, 2002 9:01 am
Visibity in the NYC area is very, very bad now. They're using ILS runways 13L for landings! Damn! Too bad I'm not there to see it!
jcxp15
Sat Oct 12, 2002 10:22 am
Timz:
Actually, most departures out of LGA use the Whitestone or Flushing climbs, which involve a a turn to the left, rather than right... The Flushing climb, turns right to 180 degrees first until at 2.5DME from LGA, and then makes the right turn.
You can verify this info with BigPhilNYC, as he lives in College Point, and observes this almost daily.
Also, you're JFK ILS 13L argument is flawed... If you use the ILS 13L at JFK, you are no longer able to use the Expressway visual for LGA (which is used very often), as well as the ILS RWY4 (as previously stated). Also, the planes landing on RWY22 do not always run up the Hudson. A lot of them fly over Queens, over LGA, left or right into the Bronx, and then a 180 degree turn to RWY22. I would imagine they are still fairly high up while over the ILS RWY13L path at JFK, but it still adds a complication. Also, I don't know too many people who want to have heavy aircraft flying over Midtown Manhattan, especially close to the ESB, every 2 minutes... If something were to go wrong on the approach, God forbid, you could end up having a huge mess in Midtown, as well as near the ESB. With two planes already taking down two buildings, I don't think people would be too comfortable seeing them that close to the ESB.
In short, could the ILS to RWY 13L at JFK be done? The answer is yes (and I would love them to do it, b/c that would mean those hvy planes flying right over me, and I would have a clear shot of them all the way to the RWY)... will it happen? probably not too often..
Rai:
You said they were using the ILS RWY13L at JFK? Did you mean the 31L/R? If not, do you know how far away the planes start on the ILS?
jcxp15
Sat Oct 12, 2002 10:33 am
Rai:
You are in fact correct.. they are using the approach to ILS RWY13L at JFK..
Also, they are using the ILS/DME RWY13 approach at LGA... This definately does not happen very often...
Now as for the JFK 13L, how far "deep" into the ILS will the planes fly? I cannot hear any flying over me right now, which either means they're too high (or most likely they're not flying over me) and I'm in Midtown Manhattan, near the ESB... Anyone have the proper routing for the ILS RWY 13L at JFK.. Do they turn at TELEX to line up?
That brings on another point.. What is the approach route to the ILS/DME RWY13 approach at LGA? They must take the planes way into NJ, and then turn them to line up with LGA RWY13...
Users browsing this forum: 26point2 and 1 guest
