air2gxs
POP Quiz 10/31
Thu Oct 31, 2002 11:03 am
You're called to the flight deck B747 Classic. Capt's HSI showing the compass flag. You do all the normal, easy things, no help. Normal easy defined as: HSI, Compass coupler, INS and tried fiddling with the INS/Radio switch. Again, No help.
No significant history in the navigation system. What catches your eye is that this aircraft had a #2 & #3 electrical systems fail due to a split breaker meltdown and to make matters worse the #2 engines experienced an IFSD enroute to your station. All thise pesky problems have been fixed.
A little far fetched but we have had the compass problem gere and at previous lives. The second part is the set-up and hint.
cdfmxtech
RE: POP Quiz 10/31
Thu Oct 31, 2002 12:49 pm
I wish I had some significant time on the B747, because this sounds like a good one.
PPGMD
RE: POP Quiz 10/31
Thu Oct 31, 2002 2:25 pm
Sorry couldn't resist.
At worst, you screw up and die.
RE: POP Quiz 10/31
Thu Oct 31, 2002 2:43 pm
Dear Air2gxs -
xxx
Since you checked all other possible avenues for that captain's compass flag, the only reason, then, would be Standby IGN on #1 or #2... move the IGN selector back to NORMAL...
(s) Skipper
air2gxs
RE: POP Quiz 10/31
Thu Oct 31, 2002 3:19 pm
Skipper,
You da man.
Due to load shedding issue, it was determined by some un-named avionics/electrical engineer that if you move the standby ignition switch to either standby position, the system sheds the captain's HSI.
Doesn't make sense to me either.
RE: POP Quiz 10/31
Thu Oct 31, 2002 3:57 pm
Do you think it makes sense to me...?
Worse is - I am supposed to explain why - to trainees... -
I call it "Renton classified PFM..."
xxx
Do I get my piece of candy...  Wink/being sarcastic
(s) Skipper
Users browsing this forum: David L, iflyabunch and 21 guests
