tsufang@CI
Why No Wing Let On 744 Domestic?
Thu Oct 31, 2002 3:24 pm
i've visit the boeing site to see the information about commercial airplane data
one interesting different between 744 and 744 domestic version that's no wing let on domestic version
why?as i know wing let is to reduce the effect of lift reduction cause by wing span too wide and large then the pressure under the wing large than the pressure on upper surface of the wing and on the most outboard position on the wing produce a down wash force let the lift reduce
and the wing let just like a wall to against this situation occur
so how do u think about no wing let on 744 domestic version?thanks
PPGMD
RE: Why No Wing Let On 744 Domestic?
Thu Oct 31, 2002 3:54 pm
:bangs head on desk: read the Why no Winglets in 717 thread that was a while back.
At worst, you screw up and die.
Thu Oct 31, 2002 4:37 pm
Dear Tsufang@ci -
xxx
PPGMD did mention it - for the 717, and I remember there had been about the same type of explanations about 747-400D a few months in the past as well...
xxx
The 747-446D (JAL) and 747-481D (ANA) are optimized for typical 90 to 120 minutes-long sectors, so they spend very little time in cruise, which is the only time winglets can be justified for economy...
xxx
I heard (or read) that - in addition, the 400D do not have the extra tank in the tail - and I also learned that if the airplane, at a later time, is used on longer sectors, the winglets can be installed... I think I read something about 2 of ANA's airplanes, retrofitted with winglets to operate on longer sectors.
xxx
Happy contrails  Smile
(s) Skipper
ybacpa
Fri Nov 01, 2002 12:11 am
Without getting too technical, B747Skipper has it correct- the winglets only improve performance during extended cruise. By removing them they have slightly better takeoff performance.
And yes, this is retrofitable- either the addition of winglets, or, conversly, the removal of winglets to convert the plane to a -400D.
The fuel tank I understand is technically still possible to order with a 400D, but due to the short distances the airlines intend to operate them, this is not justified, and are therefore not ordered. I'm not sure what happens, though, if an airline converts a -400 to a -400D.
SkyTeam: The alliance for third rate airlines finally getting their act together!
CCA
Fri Nov 01, 2002 4:06 am
It costs fuel to have the additional weight of winglets but the reduction in drag from the winglet saves fuel, so there is a balance point at which the winglet starts saving fuel over the amount it costs to carry them and this point is about 2 hours into the flight so 400D's flights of less than 2 hours save fuel due to the fact of they aren't paying for the weight of the winglets.
Now I just checked the MEL and a missing winglet causes an increase of 2.5% in fuel burn now that isn't entirely the benefit of the winglet as the end of the wing is a little untidy without the winglet which will cause some drag.
Now the stabilizer is a normal 400 stabilizer except it has none of the plumbing for the fuel tank. As an example on this -400F you can see the two blank plates on the underside of the stabilizer towards the tip on the pick below. Freighters don't usually have the stabilizer fuel option like the 400Ds
Photo © Chris Banyai-Riepl
P1 in A330, A340, A346, B742, B744, B748.
SSTjumbo
Sun Nov 03, 2002 2:01 pm
I always thought this was why:
Basically, you have two winglets adding significant mass and not providing the aerodynamic benefits to rebuke the negative benefits of the winglets on short range flights, to put it in a nutshell for you. Please refer to the above picture for some sort of analogy Big grin Big grin Big grin.
Mike
I don't know, so this is my signature.
N503JB
Tue Nov 12, 2002 12:39 am
Photo © Ryan Chow
This photos I was taken in Kai Tak. What's about the happen like this? Will improve performance or TOW will reduce?
Thanks~!
HKIA Ramp Spotters
bio15
Thu Nov 14, 2002 5:18 am
Are winglets a MEL??
AJ
Thu Nov 14, 2002 7:10 am
Winglet's are an MEL, normally requiring entry on the configuration deviation list.
I would imagine the lack of winglets on a Jumbo at Haneda has saved many a grazed paint job!
Photo © Philippe Gindrat
