Sabena 690
Flight Recorder / Black Boxes
Thu Nov 21, 2002 5:25 pm
Hi guys,
Please have a look at this picture:
Photo © Frederic Backaert
Above on your right you can see the flight recorder. Is this one of the two black boxes? If yes, can you see the other black box somewhere there?
Thanks and regards,
Frederic
744rules
RE: Flight Recorder / Black Boxes
Thu Nov 21, 2002 5:45 pm
Frederic,
I think this is just the switch to activate the cvr/cdr. If I recall well, cvr/cdr are positioned in the rear of the a/c, as statistics shows that this parts have the least damage in case if a crash. On a 737-400 it is located in the aft lower hold.
Thu Nov 21, 2002 5:52 pm
Bonjour Frederic -
xxx
What you see there is indeed the "flight recorder" in a DC9...
Actually it is merely the panel to "program" it...
Print the day/date, flight number etc...
xxx
You say correctly there are 2 "black boxes"...
One is a flight recorder, the other one a voice recorder...
By the way, with a name black boxes they are generally bright orange color.
xxx
The flight recorder operate any time the airplane is powered by its engine generators (not APU or External Power) probably... It collects basic numbers about airplane speed, altitude, acceleration, vertical speed, flight controls...
xxx
The voice recorder is operated from the first check list until the completion of the flight. It can be erased voluntarily, maybe with APU or External Power connected, or maybe the parking brake set (I dont know the DC9, again)... A voice recorder only keeps the last 30 minutes of cockpit noises (voices) and radio communications, everything older than 30 minutes is erased by new recording (continuous loop metal tape)...
xxx
I dont know where the "orange" black boxes are located in a DC9, electronics compartment or in the tail, in the 747, the "black box" is in the tail near L-5 door...
xxx
Voila, Frederic  Wink/being sarcastic
(s) Skipper
Sabena 690
Thu Nov 21, 2002 8:00 pm
Thanks a lot, guys!
Voila, I learnt again something new today Big grin
Frederic
AAR90
Fri Nov 22, 2002 1:12 am
Wow, never saw one with all that stuff. AA airplanes have just a test switch for Flight Recorders. Flight Recorder activation is automatic and usually beings with first engine generator being brought on-line. It is as previously mentioned, just the control head for the flight recorder. The actual "black box" is located in the DC-9's tail cone area behind the pressure bulkhead/door.
The Voice Recorder control head is located to the left and up (back) of the Flight Recorder panel. You can easily see the Cockpit Area Microphone sticking out. It has a test button and gauge to see if it is working and an erase button to supposedly (I'm told it doesn't work very well) clear the tape. The actual "black box" is also located in the DC-9's tail cone area.
dc10hound
Fri Nov 22, 2002 3:42 am
With bands of silver reflective tape.
Undoubtedly true on all aircraft I'm familiar with. However, comma:  Big grin
A300:
The flight recorder is powered anytime the Ground Control switch on the overhead panel is selected to ON.
DC10 (AAL):
The flight recorder is not powered (And the RECORDER and Master Caution lights on the FE's annunciator light panel are illuminated) when the parking brake is set.
The recorder is powered when the flight recorder switch on the FE's panel is selected to OVERRIDE.
I don't know where the "orange" black boxes are located in a DC9, electronics compartment or in the tail, in the 747, the "black box" is in the tail near L-5 door...
All commercial aircraft I've worked on have the recorders installed in "the most survivable location": the tail or aft part of the airplane.
"Eagles soar. But weasels never get sucked into jet intakes.."
airplay
Fri Nov 22, 2002 11:33 am
As with anything "aviation" flight recorders are found in several different configurations.
The latests systems often consist of combination CVR/FDR units. Some airworthiness authorities require dual installations in this case.
The average recording length these days is 1 or 2 hours for CVR and 54 hours for FDR. New installations no longer use any type of tape or metal recording medium. They use solid state digital memory. Modern installations record at least 88 distinct parameters and if the aircraft contains databusses, they record even more. I have seen a VARIG installation that recorded 500 parameters.
The required parameters varies from country to country.
Modern CVR installations must also record continuous audio from the flightcrew's boom microphones in most cases which was not required before.
Many civial aviation authorities around the world have adopted Eurocae ED-55 and ED-56A as standards for installing, and maintaining flight recorders in aircraft. These documents (not available on the internet) contain such things as acceptable means of beginning and ending the record cycle and appropriate areas to install the units.
Note that many older aircraft still use 11 parameter FDRs that use magnetic tape which records parameters digitally.
You can check out FAR 121 and FAR 135 for required parameters in the FAA world if you're interested.
Just out of interest, the term "black box" was used by maintenance people to describe any LRU (Line Replaceable Unit) not just flight recorders. The media who were only involved or concerned about LRUs after accidents, adopted the term to mean only the flight recorders. Most (not all) civil aviation authorities require that the FDR and CVR be painted orange or yellow and be fitted with reflective tape and a placard that says something like "FLIGHT RECORDER DO NOT OPEN''.
Other "black boxes" (other than flight recorders) are still often painted black...but many are blue or other colors too!
http://members.shaw.ca/airplay1/IMG_0610.JPG
Sabena 690
Sat Nov 23, 2002 2:40 am
Guys, thanks again for your very valuable explanations!
They are much appreciated!
I also got very interesting emails about the 'black boxes'.
This is a mail I got from Chris Stoever:
The black box is always orange and in the tail, never in the cockpit! see for
picture:
http://www.dsto.defence.gov.au/corporate/history/davidwarren.html
And this is a mail I got from Bertrand Jacquet:
You can see the panel with the following label : 'Cockpit Voice Recorder'. This
panel commands one of the black boxes : the one which record voices of pilots
and noise in cockpit. One this panel, you can see (left to right) a mike which
record noises in cockpit (alarms, engines, switchs, etc...). Next, you can see
an indicator which show the empty part of the CVR memory. This black box is only
able to record between 30 minutes and 2 hours. The red Push- Button erases the
black box, and the green make a test.
The panel labelled 'Flight Recorder' permit to send specific informations to the
Flight Data Recorder (FDR), the other black box. You can inform this black box
of date, flight number, etc... The FDR record a lot of parameters : altitude,
speed, heading, autopilot status, failures, etc...
Frederic
ybacpa
Sat Nov 23, 2002 3:42 am
Building on this thread a little:
Does anyone know why there are not duplicate voice and data recorders? It seems like a number of the recent accidents have had problems with retrieving data from one or both of these units.
Also, with all the redundancy designed into modern airplanes, it strikes me as odd that this, at least to a laymen, is not redundant.
Thanks for any insight.
SkyTeam: The alliance for third rate airlines finally getting their act together!
airplay
Sat Nov 23, 2002 4:10 am
Flight recorders do not contribute directly to the safe operation of the aircraft. Thats is why they are required by FAR 25 which is a design standard. Rather, they are required by various operating standards like FAR 121 or FAR 135.
Redundancy is typically only considered if the failure of a unit contributes to a hazardous situation in operating the aircraft.
Many problems with retrieving data from flight recorders are associated with the severity of the crash, and some older designs that use recording mediums that are easily damaged.
Modern recorders are much more robust and resistant to damage.
airplay
Sat Nov 23, 2002 4:18 am
Whoops.... I meant to say they are NOT required by FAR 25.
jsuen
Sat Nov 23, 2002 4:44 am
A major problem with CVRs is that they are not properly switched off after an incident or minor accident. The NTSB is pushing for carriers to ensure the CBs are pulled when necessary. Also, new two-hour recorders should help.
CVRs and FDRs are run off aircraft power which can fail during an accident. While it is impractical to run every single aircraft measurement system off a battery, there is talk of adding backup batteries to CVRs.
Most issues with systems relate to improper maintenance. I remember an accident when a single capacitor opened on an older CVR. The end result was that it passed self tests, but did not record any information. Most recently, the lack of CVR information on the crash of a Jetstream was blamed on a failure to conduct tests after maintenance.
Trains have FDRs too, called Event Recorders. Like FDRs, the new models are solid state recorders which can monitor hundreds of parameters for several days.
Users browsing this forum: Yahoo [Bot] and 1 guest
