jgore
Why 100 Kts IAS On This 737 Autopilot?
Sun Dec 01, 2002 2:53 am
Please take a look at this picture.
Photo © Joe Corrigan
Why would pilots set 100 kts ias in their autopilot since they land or takeoff about 130-145 kts ?.
Is this somehow useful in any phase of flight ?  Confused
Thanks in advance
Jgore  Smile
T prop
RE: Why 100 Kts IAS On This 737 Autopilot?
Sun Dec 01, 2002 4:40 am
The airplane is on the ground with both engines shut off, I imagine the autopliot is not needed in this situation.
T prop.
cdfmxtech
Sun Dec 01, 2002 4:43 am
First of all, if those guys are inflight, they are in major trouble!! Big thumbs up
That flightdeck is not prepared for flight.They are on the ground and nothing is setup.
Anyway, inflight the mode control panel would not let you set a speed below the alpha floor limit. I think it is something like 1.3 times the stall speed.
jgore
Sun Dec 01, 2002 5:42 am
Well, I know is not necesary when the airplane is grouded. But I doubt pilots or any mantenience guy were playing with the knob leaving the counter in 100.
Jgore  Smile
FBU 4EVER!
Sun Dec 01, 2002 7:10 am
It's most likely a default value.At least that's how it reads on our MD-80/90 readouts when a powerchange has occurred and no pilot-selected value has been entered.
You may well set 100 kts in the readout window during flight,however,the Flight Management System will prevent the plane from decellerating below Alpha (min speed for present configuration) and the Flight Management Annunciator will show ALFA SPD and control speed to applicable value.
But things can (will) go wrong,and no pilot in their right mind would set such a low speed in the readout.
"Luck and superstition wins all the time"!
cdfmxtech
Sun Dec 01, 2002 8:35 am
FBU is correct. That is the default value on the IAS/MACH window when pwr is applied
airplay
Sun Dec 01, 2002 10:04 am
Although it is probably not the case here, as evidenced by the well informed posts above, there is always the possibility that one of the segments on the speed display is burnt out. In other words, maybe 180 is set but 100 is displayed because the center segment of the "8" is missing.
AAR90
Sun Dec 01, 2002 10:28 am
I suspect the -700 has the same MCP as the -800.
From my AA 737-800 OpMan:
"IAS/MACH Display... Displays 100 knots when power is first applied."
GE
Sun Dec 01, 2002 11:19 am
It's the same for the A319/320/321.
100 knots is displayed on the Flight Control Unit when first powered up.
Russell J.
jgore
Sun Dec 01, 2002 2:40 pm
Ohhhh guys, you've made it very clear enough. Thank you very much.
Jgore  Smile
Rick767
Mon Dec 02, 2002 4:39 am
Just to confirm, 100 knots is the minimum "default" value which appears in the 757/767 MCP Speed Window as well when the juice starts flowing.
CX Flyboy
Mon Dec 02, 2002 5:50 pm
Not quite related, but after landing, we always set the parking bay number as a reminder in the altitude window, so if bay 1 we set 100. Bay 10 we set 1000. It not a company requirement and it not written anywhere, but more something that we just do! just a reminder as sometimes the taxying can be complicated at some airports so you don't want to forget the bay number!
wardialer
Thu Dec 05, 2002 2:40 pm
Well take a look. The PFD display is almost displayed in black, meaning that they have just turned on the APU system. Like on the MD-11, when everything is first set up, the autopilot console will automatically will show a reading of the standard IAS as 250 knots. Or it could just be in a test mode. But again on the MD-11, it will say as "Fail" on the PFD.
Users browsing this forum: keesje and 21 guests
