AM
IAH Runway Configurations
Mon Dec 16, 2002 11:33 am
What are the most common runway configurations at Houston Intercontinental? Depending on winds of course, which runways are used for takeoffs and which for landings?
Also, with runway 15R/33L now 10000ft long, do they use it for landings or is it used for parallel takeoffs with 15L/33R?
Thanks a lot in advance.
AM
"... for there you have been and there you will long to return."
ramper@iah
RE: IAH Runway Configurations
Mon Dec 16, 2002 1:57 pm
About 80% of the time, runway 26 is used for arrivals from the north and west, and runway 27 is used for arrivals from the south and east. 15L and 15R are almost always used for all departures with runway 26 used sometimes for westerly departures. Usually when the tailwind component reaches about 8 knots, they'll use 8 and 9 for arrivals, sometimes still using 15L and 15R for departures. Runway 9 is never used for departures.
Markus
Tue Dec 17, 2002 5:27 pm
Ramper@iah,
All the info from above is correct except for your last sentence. I've departed on RWY 9 twice in the many (100+) times flying out of IAH. Both times we were Eastbound (GSP on an ERJ-145LR the other to CHS on an MD-82 back in 1999). These are the only times I EVER departed off 9. Interestingly, both flights were delayed because of extremely strong storms. The ERJ flight was especially bad due to the ever present level 3 and 4 storms in the area that closed the airport for a few hours. I was returning from GSC training a couple weeks after 9/11. Though rare...the runways is used for departures.
To correct the statement....RWY. 27 is NEVER used for departures due to the cargo area off the end of the runway centerline. Landing on Rwy. 9 is fun if you have a window seat since you fly directly over the cargo area.
Markus
Work smart
Not hard
erj-145mech
Tue Dec 17, 2002 9:02 pm
I've departed twice on RWY 9, once on an EMB-120, once on an ATR-42, on Co-Ex to ILE. Both times were a 9PM departure.
Dave
TYS
ramper@iah
Wed Dec 18, 2002 5:48 am
Markus,
Thanks for the correction. I indeed meant to say "runway 27 is never used for takeoffs." Too bad this board doesn't have an edit feature.
Has anyone ever landed on 15L or 15R? I've never seen it.
AM
Wed Dec 18, 2002 2:24 pm
Thanks everyone. I've only been in IAH 2 times, my landings were on 27 and 9 (that's right, landing on 9 is interesting, you get to see 15s/33s and the cargo area just before touchdown), and both takeoffs were on 15L, followed by an immediate right turn heading southwest.
Do they ever use runways 33L/R at all?
erj-145mech
Wed Dec 18, 2002 4:22 pm
ramper@iah, I've landed on 14L, 14R, and on 14STOL several times. Of course, this was about 18-20 years ago. I flew my C-150 down from CXO to get some parts from Qualitron. I guess you can see that back then it was RWY 14, before they sucked so much oil out from beneath that IAH started to screw itself into the earth and changed the heading. RWY 14 STOL was a marked section of taxiway A from about where the FEDEX/mail ramp is now to just before Qualitron. It was there mostly for the Metro Twin Otters coming up from Clear Lake to land on. When Metro went away, so did 14STOL.
Dave
TYS
ramper@iah
Thu Dec 19, 2002 7:36 am
"Do they ever use runways 33L/R at all?"
Yes, but only when the wind direction and velocity give them no other choice. It takes forever to taxi down there.
desertjets
Thu Dec 19, 2002 12:01 pm
I've departed on 33R once... arrivals on 26 and 27. It was during a period of thunderstorms in the area. And the taxi from Terminal D was about 15-20 minutes.
Bruce
Sun Dec 22, 2002 1:58 pm
Once back in 1999, I was on a flight that took off using 9. And we made a sharp right turn after departure. This is it:
Photo © Bruce Leibowitz
Now since we are on the subject of IAH runways I have a question based on my visit there this week. For flights that are going northeast (like to Europe), why do they use 15R and not 15L? Tower instructed them to turn right heading 360 after departure and from the viewing area you could watch them circle in the sky, some starting the turn right over your head. I would think that if you depart 15L then you're travelling less distance, which would be preferable especially on a long haul where you're at max fuel load.
To answer AM, yes they do use 33L/33R. i was at the viewing area on thursday morning when the change happened. The wind that day changed direction to like 290, and all of a sudden I saw a NW Airbus taxi down there and as soon as the queue for 15L/15R cleared then they started using 33 for the rest of the day. I'm going to be uploading pics of it. I also witnessed takeoffs from 8.
EssentialPowr
Thu Jan 02, 2003 1:59 am
If the concrete is there, eventually the runway will be used for an arrival or departure. On 30Dec, IAH was configured w/ departures of 15L and arrivals on 15R due to southerly winds of 20kts gusting to 35 w/ low level windshear.
Markus, the cargo area doesn't prevent departures off 27 in any way (did you just make that up??). Before IAH was configured "all south" on the 30th, several a/c departed from 27. Runway configs dictate airport facility layout, not vice versa.
cheers
jhooper
Thu Jan 02, 2003 6:09 am
I was out there yesterday and they were using 33R for departures.
Bruce, we're talking about a few feet here, right? Does it really make that much difference?
By the way, here is an airport diagram:
http://www.aopa.org/images/asf/taxi/05461AD.pdf
Last year 1,944 New Yorkers saw something and said something.
Bruce
Thu Jan 02, 2003 11:20 am
No, it is more than a few feet. Try miles. if you take off rwy 15L then you turn left to your desired heading which is probably 040 for europe-bound jets.
When you takeoff rwy 15R you turn RIGHT, west, and then 360, north, and then northeast. These turns are wide - covering several miles.
But I'd go with the theory that the heavies dont climb as fast and they need to be above a certain altitude in order to cross the 27/26 approach path so they go the other way.
EssentialPowr
Thu Jan 02, 2003 2:18 pm
Turning to the "desired heading" for an eastbound departure off 15L doesn't happen very often.
If IAH is in standard VFR config (departures off 15L/R, arrivals on 26/27), north and east bound 15R departures come right to a 360 hdg, and north and east bound departures off 15L come to a 120 hdg. About half the time, instead of 120 off 15L, a left turn to 360 will be issued. All departures get an initial alt of 4000 MSL.
Arrivals cross the final approach fixes for 26/27 at or below 2000 MSL (VFR) and line up around 20 miles to the east; both downwinds are flown at 6000 MSL.
Therefore, the east bound departure traffic will stay at or near the 360 or 120 hdgs headings to ensure separation from the arrivals.
cheers
N102DA
Mon Jan 06, 2003 3:45 am
I flew out of IAH last Thursday (Jan 2) on a 737-700 back to ATL. We departed on 33R and after a steep initial climb, made an immediate right turn after takeoff. We turned towards a southeasterly heading and actually flew over the arriving aircraft for 26 and 27. Quite interesting to fly over aircraft landing in the opposite direction. We then turned to the east as we passed Lake Houston. Interesting to note that most arrivals to 26 turn onto base right over the lake. One of the more interesting departures I've had in a while. And yes, the taxi from gate C-18 took forever!
N102DA
DiscoverCSG
Tue Mar 18, 2008 3:17 pm
I see there's a GDP in effect for IAH due to weather/thunderstorms.
Are they stuck with only the 15's in use because of the wind? If so, what's the arrival capacity?
ThePinnacleKid
Tue Mar 18, 2008 5:09 pm
Quoting Ramper@iah (Reply 1):
It is (conveniently) normally 10 knots of the tailwind component... which happens to be the structural limit for quite a few of the aircraft that frequently use IAH.... =)
as a IAH based f/o... I see the following:
IAH tends to put RIICE arrivals on 26R (slow days or with a gap 26L), ROKIT & DAISETTA tend to go to 26L, and STROS & GLAND arrivals will tend to go to 27... granted on rare occaision I've flown RIICE and landed on 27, STROS and went to 26L, etc... but the first stuff is standard IAH usage....
For departures... the preferred is 15L/R... but they will switch to 33L/R when winds dictate... as others have said... the other runways sometimes used for departure include 26L (in low usage hours), 9 (when weather dictates), and on rare occasion 26R will be a departure runway for the guys off the cargo ramp (The huge one on the east side of the field that is between 26L and 26R... )
"Sonny, did we land? or were we shot down?"
rkmcswain
Mon Mar 24, 2008 12:23 am
I posted about 33 takeoffs a while back and then experienced one last year. It occurred after a front hit town and there was a north wind present (typical winds in Houston are from the S or SW).
I once lived in the flight path of a 15 landing and saw one almost every morning about 4:30. Cargo I'm assuming.
atct
Mon Mar 24, 2008 8:09 pm
Quoting Ramper@iah (Reply 4):
Actually ive seen this 4 times in the past year and a half ive worked here. (when the wind is strong out of the west, we'll go "Straight West" which means land 26L/R and depart 27)
ATCT
Trikes are for kids!
IAHFLYR
Sat Mar 29, 2008 4:11 am
I love all this...one day I might even answer the question but let us just say for now that IAH hardly even lands into the wind and weird configurations from the landing west on all 3 and departing the 15's happens!! When it does watch out!  Smile
More later.............much more later I hope.
modesto2
Sun Mar 30, 2008 4:31 am
Quoting IAHFLYR (Reply 19):
So true! Standard arrivals have a quartering tailwind. If not, something's wrong!
IAHFLYR
Sun Mar 30, 2008 3:29 pm
Quoting Rkmcswain (Reply 17):
 checkmark
Quoting AM (Reply 5):
Try and avoid landing 33R, it is about the worst configuration as you get about 3 aircraft on final outside the final approach fix and you're into the airspace HOU Tower uses for their departures in a north flow. So something has to give, which is usually HOU ends up taking their traffic out west or southeast first before they get turned northbound. Ugly ops.
Quite the contrary...Runway 9 is often used for departures as others have mentioned especially when landing 8L/R.....you even find Runway 9 used when landing 26R/L for eastbound traffic, they get a quick turn to the southeast first then when outside the downwind turned toward BPT.
Quoting Markus (Reply 2):
Quoting Essentialpowr (Reply 10):
Yeah Markus, did you make that up or what?  Smile Runway 27 is used for departures as others have eluded to as well....however, it is not common to see that but it is used! I personally have used it a few years ago when an aircraft is on the southeast ramp of Terminal C/E in a northwest wind, much closer taxi to Runway 27 than 33R/L. Have also been a passenger in a B739 to RSW that used Runway 27 for departure in the last year.
Quoting AM (Thread starter):
Most common is and best arrival rate is landing Runways 26L/R and 27, departing 15L/R with the occasional Runway 26R departure, and try to remain in that flow as long as possible. The joke around IAH is if the wind is out of the west, IAH has to be landing east!
Runway 15R was used all day for weather/winds around the middle of March this year....wind was something like 150 at 25 gust to 40 all day long.
Quoting Bruce (Reply 12):
A good theory but it also applies to all departures. You must have separation above the guys on final to Runways 26L/R and 27, some of the tower folks will give the left turn off 15L, most prefer to use the right turn off 15R. I prefer to just get them out and if it requires a left turn and a right turn to diverging headings then do it.  eek
Quoting Erj-145mech (Reply 6):
Ah the STOL 14....what a fun operation that was. Sometimes a BE20 would use it as well as a guy in BPT and his BE50 for landing. Had a C500 line up on it for take-off one day thinking it was 14L...lol....sure was narrow for a 150' wide runway.
flymeariver
Thu Oct 31, 2013 3:19 pm
Hello all,
Stormy morning here in Houston, and IAH has been landing 26L and 26R with departures only from 27 all morning... 15s and 33s not being used at all. Seems like an odd configuration, any reason for this?
ATIS was reporting wind 290 at 8 a short time ago, visibility 7, ceiling 3000 overcast.
I will also add that I've seen this done once or twice in the past as well, always in October/November, if that matters.
IAHFLYR
Mon Nov 04, 2013 6:20 am
Quoting flymeariver (Reply 22):
There could be many reasons for this configuration, weather off the departure end of the 15's or 33's that preclude airplanes flying through it, possibility of the tower not being able to protect for a missed approach/go-around from landing traffic on 26L/R with the traffic departing 33L/R, or even the fact that they started in that configuration during a high traffic time taking all departures of Runway 27 and have to finish that before they can load them up on the 15's or 33's.
It is very dynamic and I also have my one personal opinions but won't share that in a public forum!
atct
Fri Nov 08, 2013 2:34 am
Take this with a grain of salt as I haven't worked at IAH in 2 years.
With a lower ceiling / visibility, we had requirements in order to depart 33 and land 26/27 at the same time. If I remember correctly the aircraft on final to 27 had to be in sight on a 2 mile final, 26L on a 3 mile final, and 26R on a 4 mile final prior to any aircraft starting departure roll off of 33R/L. So when the rain is coming through etc and we couldnt get the arrivals in sight, in time, we would take all departures to 27, and land 26L/R. I always enjoyed working 27 departures as they did a nice fly by the tower. Sadly, I now work in a dark room without windows...I think I just found a mushroom growing out of my chair....
IAHFLYR
Fri Nov 08, 2013 6:22 am
Quoting atct (Reply 24):
Get over your bad self....LOL
Even when you were working the tower you still were not above the mushrooms.........but you did make a difference that's been lost again I'm sure!
apodino
Fri Nov 08, 2013 5:25 pm
Quoting Bruce (Reply 9):
Its pretty simple. They have to turn to a northerly heading off departure, and if they turned left there would be an instant conflict with traffic landing to the west, so they turn right to keep them away from the traffic inbound for 26/27L/R. Because they make a right turn, 15R makes much more sense to use than 15L. If you go to the Vatsim page covering Houston Center (Its for flight sim users only, not real world but the procedures are mimicked beautifully on this network), you will find a controller cheatsheet, which will give the runways and departure headings for each departure fix and runway configuration.
Of course, if there is an operational need for the longer runway, ATC will always cooperate with the request, but they may be delayed getting out.
flymeariver
Thu Feb 27, 2014 12:39 am
Today at IAH, some light showers have been around and winds have been pretty consistent out of the N or NW around 10 kts (last time I checked was 340@11) all day long.
All day, IAH has been landing 8L / 8R and departing 9 only. The 15s/33s haven't been in use. With the wind solidly from the N or NW, why wouldn't they at least use the 26s/27 (assuming the 33s are off limits due to low visibility) to have more of a headwind than a tail wind?
atct
Sun Mar 02, 2014 10:52 am
Quoting apodino (Reply 26):
I used to turn guys left to the north all the time and top the final to the 26's and 27. I wouldn't do it with a heavy (I have when needed, it gets a little tight) or 737-900's heading to Seattle, but most airplanes, no sweat. Tower applied visual separation is a wonderful tool.
atct
71Zulu
Sun Mar 02, 2014 1:08 pm
Quoting Ramper@iah (Reply 7):
Depends on how fast you taxi
http://youtu.be/J-C5leIxSos
Clickable links only please!
DiscoverCSG
Mon Jul 20, 2015 8:29 pm
Quoting 71Zulu (Reply 29):
I love that the spoiler is up while taxiing *to* the runway.
Users browsing this forum: Bing [Bot], StereoTechque and 1 guest
