UAL Bagsmasher
DC-9 A&P Help Needed
Tue Dec 17, 2002 1:38 pm
I need help from a DC-9 classic A&P. I need help identifying some DC-9 parts I found at an old crash site. A few parts have numbers on them. These numbers may be partial, as the pieces are bent and cracked and have faded.
Part #1: 5910537 aluminum sheet metal
Part #2: 9467-509 A aluminum sheet metal
Part #3: 5915112-13 aluminum sheet metal
Part #4: 449416 B Underneath that is written 3788; silver in color; squashed; was cylindrical; has grooves.
Part #5: metal rod with threaded ends. One end of rod near threads has written: 1/2...16...A.I.M. Writing appears around the rod/tube.
I found many more pieces, but none with part numbers.
I'll e-mail pictures if that would help identification. Thanks.
UAL Bagsmasher
RE: DC-9 A&P Help Needed
Tue Dec 17, 2002 1:59 pm
One more piece I forgot to add is a rather skinny pice of aluminum with two fasteners through it. It contains a circle with the following writing inside it : X 638
PPGMD
Tue Dec 17, 2002 2:20 pm
Is it a current investigation? You should turn all the pieces to the NTSB if you haven't already.
At worst, you screw up and die.
UAL Bagsmasher
RE: Ppgmd
Tue Dec 17, 2002 3:01 pm
No, the investigation was concluded years ago.
747Teach
Tue Dec 17, 2002 9:39 pm
UAL Bagsmasher: The first number appears to be from a n emergency exit door frame. The third number may be from a heat exchanger clamp. The fourth number may be an oil transfer tube. Hard to say for sure due to the various types of DC-9's, and the possibility of partial numbers. Regards,
UAL Bagsmasher
RE: 747Teach
Wed Dec 18, 2002 2:18 am
Thanks a lot! Just out of curiosity, where did you look up the part #'s?
Fokker Lover
Thu Dec 19, 2002 7:04 am
UAL Bagsmasher
I would have to say that 747TEACH went to a DC-9 IPC (illustrated parts catalog). In the front of the first book there is something known as the numerical index. All part numbers are listed in numerical order. It then tells you which chapter,section, drawing number, page number, and finally which item number your part is shown as. That is IF your part is listed. You'd be surprised how many aren't listed.
10,000 years ago we would have eaten you. Today, we drag you along and allow you to pollute the gene pool.
OPNLguy
Thu Dec 19, 2002 7:10 am
Just out of curiosity, which DC-9 crash site did you visit? MKE?
BTW, hope you folks all hang in up there...
UAL Bagsmasher
RE: OPNLguy
Thu Dec 19, 2002 9:13 am
Hey thanks for the kind words. Nah, I visited the Allegheny DC-9 vs. Cherokee site in Indiana from 1969. Is there anything left of the YX DC-9 in MKE?
747Teach
Fri Dec 20, 2002 10:29 pm
UALbagsmasher:
Our IPC is online, so its just a matter of typing in the numbers. The reply comes with a short description. Tried some of your other numbers, and other combinations, and couldn't get anything to work. The number inside the circle could be an inspection stamp. Regards,
Users browsing this forum: GoSharks, grozzy and 7 guests
