deuce2recon
CFM56-7B24, -7B26, -7B27 Engines
Sat Jan 04, 2003 9:04 pm
Can anyone tell me where I could find detailed information for fuel burn data on this engine? I've looked at CFM's site and also the technical specs at Boeing's and I can't find what I am looking for.
keesje
RE: CFM56-7B24, -7B26, -7B27 Engines
Sun Jan 05, 2003 2:44 am
sorry can't help you
I heard Southwest is starting a drastic GE kit cfm56 upgrade.
Is this a good idea, are more airlines considering this mod ?
AAR90
Sun Jan 05, 2003 5:12 am
Check your listed email account for a zip file.
tiago1991
Sat Sep 14, 2013 6:31 am
I was looking for some detailed information about fuel data like: fuel flows, fuel burn in time, etc
I was looking at the site of cfm and boeing aswell, but then I searched here and found this topic.
Can anyone please help me to get some detailed information for the cfm56-7b22K/24K/26K/27K?
jetmech
Sat Sep 14, 2013 2:19 pm
Quoting tiago1991 (Reply 3):
A good start maybe to look up the FAA and EASA type certificate data sheets for the engines of interest;
http://rgl.faa.gov/Regulatory_and_Gu..._Library/rgMakeModel.nsf/MainFrame
http://www.easa.europa.eu/certification/type-certificates/engines.php
A few examples to get you started may include;
http://rgl.faa.gov/Regulatory_and_Gu...74246/$FILE/E00056EN%20Rev%209.pdf
http://rgl.faa.gov/Regulatory_and_Gu...32041/$FILE/E00055EN%20Rev%209.pdf
http://www.easa.europa.eu/certificat...-7B_series_engines-04-17122012.pdf
These documents tend to give a variety of detailed information that is not found elsewhere. The following should help with fuel flow data;
http://books.google.com.au/books?id=...&q=GE%2090%20Elodie%20roux&f=false
http://www.stanford.edu/~cantwell/AA...urse_Material/GE90_Engine_Data.pdf
IIRC, there may also be more detailed data on fuel flows if you look on the EPA website or search for studies and documents to do with emissions testing.
Regards, JetMech
[Edited 2013-09-14 07:23:33]
tiago1991
Sat Sep 14, 2013 4:39 pm
Thank you very much for your quick answer!
I've another question.
Is there detailed info about the fuel flow, per weights, miles nm, minutes etc like performance data
For example:
For a Boeing 737-700 from DAL - cfm56-7b26
Klm B738 - KLM -cfm56-7b24, etc
jetmech
Sat Sep 14, 2013 5:09 pm
Quoting tiago1991 (Reply 5):
The only thing close to that which I can think of are the specific payload-range charts from Boeing;
http://www.boeing.com/assets/pdf/commercial/airports/acaps/737sec3.pdf
Actual hard numbers such as specific fuel flows, distances and sector times for the various CFM56-7B subtypes would most probably be proprietry data held by airlines.
Search through the Civil Aviation forum, as there have been many threads revolving around the in-depth analysis of various aircraft / engine / route combinations. Your best bet for the 737 would be to search specifically for 737MAX or A320NEO threads. If you find a 737NG thread, I'm sure you could reverse calculate a set of numbers that are reasonably close to the actual quantities you want.
Regards, JetMech
Grisee08
Sun Sep 15, 2013 8:28 am
Quoting Keesje (Reply 1):
I heard this about 10 years ago for the -300/500 series to bring them up to -7B22 standards. I assume this never occurred.
You're Losing The Game!
ferpe
Wed Sep 18, 2013 4:30 am
The most reliable public fuel burn data is the ICAO emmision databank:
http://easa.europa.eu/environment/edb/aircraft-engine-emissions.php
This gives the fuel burn figures for uninstalled engines (ie test stand config, you should add about 3% for installation losses) for flying around an airport, thus not cruise data unfourtunately. For cruise TSFC and thrust this web site is the best I have found, most of the data is reliable:
http://www.jet-engine.net/
The one for the CFM 56-5C is bogus, should be about 0.58-0.59
[Edited 2013-09-17 21:35:29]
Non French in France
Aircellist
Wed Sep 18, 2013 4:38 am
A ten-years-old thread still active?
I thought Keesje was back…
"When I find out I was wrong, I change my mind. What do you do?" -attributed to John Maynard Keynes
Users browsing this forum: Yahoo [Bot] and 1 guest
