ajaaron
Lnav Or HDG Select On DVR8M SID?
Tue Jan 07, 2003 11:44 am
This SID requires a 180 turn to the right at 2.3 DME IWW to intercept the 082 radial to DET by DET 30.
On Boeing aircraft e.g 757/767 I have noticed that pilots take this turn in
Heading Select rather than LNAV - any reason why.
Does one not trust LNAV until its integrity is checked once airbourne for say a few minutes? In contrast to 777 and 744 - where FD is engaged in LNAV and VNAV while on ground. So is the 757/767 different, less accurate in terms of inertial reference perhaps?
If in HDG select would one select the heading to the right gradually to establish the course on the 082 inbound, (to adjust for wind) or just wind in 082.
Just a matter thats bugged me for a while.
Arnold.
cdfmxtech
RE: Lnav Or HDG Select On DVR8M SID?
Tue Jan 07, 2003 12:38 pm
Incorrect statement. LNAV & VNAV are ARMED on the ground. It is engaged when certain prereqs are met.
LNAV on the B757 and MOST Boeing requires to be within a certain range of the active waypoint in order to be engaged. I'll let one of the guys wearing stripes offer a little more.
AJ
Tue Jan 07, 2003 12:42 pm
Conducting initial turns in HDG SEL is done for a few reasons.
LNAV can be slow to sequence, which delays the turn. Airports like LHR and FRA have noise sensors and the airline can be fined for flightpath deviations. The other is map updating. If it has been a while since the IRSs were aligned the map can be significantly out by takeoff unless the aircraft is fitted with GPS. LNAV is not selected until the map has updated once airborne.
411A
Tue Jan 07, 2003 12:53 pm
Indeed, AJ has hit the mark.
At many airports that are extreamly noise sensitive, HDG SEL can offer superior navigation...provided the pilot(s) keep a close eye for deviation from the desired flight path.
Can you imagine...these DP's (old term SID) can actually be done with plain old VOR/NDB.
However, some that CANNOT be are so noted, and may generally require RNP 0.030...quite accurate.
CX Flyboy
Tue Jan 07, 2003 1:10 pm
In the 777, LNAV engages as 50ft radio altitude if within 2.5nms of the active leg. (You've seriously taken off in the wrong place if at 50ft you are outside 2.5mns from the correct leg!). At 400ft, VNAV engages.
Rick767
Tue Jan 07, 2003 4:16 pm
We don't arm LNAV on our 757/767 a/c before departure (it is selected on the climbout if map integrity and the magenta line seem ok). I know many airlines do arm LNAV prior to takeoff though.
The initial turn on the DVR8M/LAM8M can easily be done in LNAV, but is quite a tight one at the best of times (especially at high weight on the 763) and HDG SEL gets us round the corner a bit quicker than LNAV (which can lag a bit as has been mentioned).
Since we really need to keep Flap 5 in for this first turn it can be easier to go HDG SEL and FL CH @ Vref + 40 until the turn is complete when we can go into LNAV and VNAV and start accelerating and cleanup the aircraft.
Like 411A says, (most of) these procedures were designed to work with simple VOR/DME and NDB equipment, and it doesn't harm from time to time to try out a SID (they are still called that in the UK  Big grin) using raw data without all this MAP stuff  Wow!
ajaaron
Wed Jan 08, 2003 1:19 am
Wow - thanks for the responses, very helpful.
I get the impression then that the older 757/767 updates IRS position once airborne (assuming no GPS system in use), while the 744 updates when the TO/GA switches are pressed on t/o when still on the ground. [its neat to see the runway align with the white triangle!]. Is this also the case with 777 that on pressing TO/GA for take off the updating position takes place?
Do Airbus a/c also work in the same way in respect of taking tight turns or is their LNAV mode or whatever the equivelant is more better than Boeing.
Thank you for your responses.
Arnold.
AAR90
Wed Jan 08, 2003 2:21 am
Ajaaron,
Careful you don't get tangled in the different names of different navigation positions. Once in motion, the 757/767 IRS position is never updated. The FMS calculated position is updated by outside sources --primarily DMEs & if equipped GPS. Depending upon the airline's certification the 757/767 may not be legal to fly LNAV during departures. OTOH, 777 and 744 are newer designs that probably have newer certifications permitting LNAV engagement on departures. i.e. AA's 738 is legal to fly LNAV at all times except ILS approaches.
cdfmxtech
Wed Jan 08, 2003 2:22 am
*This info can differ from airline to airline.
But this is how the one's I work operate:
The B757/B767/B777 update their positions once their respective takeoff modes are initiated via MCP...if GPS Nav is OFF. If GPS nav is ON, the updates are inhibited.
Sat Jan 18, 2003 6:21 am
Talking about B777 we prefer to TO with the HDG selected instead of LNAV because the HDG responds more quickly than LNAV.
We use LNAV during TO only when we have to perform A FMS departure that require the use of GPS or IRS.
Users browsing this forum: bbschraube, edgaren, Natflyer and 1 guest
