dan2002
What Is "cross Check"
Sun Mar 02, 2003 8:16 am
At the end of flights the FA's do a "cross check" what is this done for.?
thanks
dan2002
A guy asks 'What's Punk?'. I kick over a trash can and its punk. He knocks over a trash can and its trendy.
BR715-A1-30
RE: What Is "cross Check"
Sun Mar 02, 2003 8:22 am
Cross Check means basically to go over the cabin to make sure all of the seat backs and tray tables are up, and that the passengers are buckled up, and to make sure all luggage is stowed, and that all electronic items are off. Basically Cross Check is Checking to make sure the plane is ready for takeoff/landing ETC.
Puhdiddle
DeltaMD11
Sun Mar 02, 2003 8:25 am
I thought cross checking was the call for all flight attendants to man their doors, and make sure that they are properly closed and armed.
Bryan
Too often we ... enjoy the comfort of opinion without the discomfort of thought. - John Fitzgerald Kennedy
Olympic A-340
Sun Mar 02, 2003 8:29 am
I always thought that crosscheck meant that one crewmember checked another crewmember's actions to verify proper placement of controls or whatever. For instance, "Cabin crew arm your doors for departure and crosscheck" would mean that one F/A would arm his or her door, and the opposite F/A across the cabin would check that the door was indeed armed.
jhooper
Well I thought it meant for each FAto check whether or not the OTHER FA did their job correctly.
(Never mind, Olympic A-340 beat me to it)
[Edited 2003-03-02 00:55:51]
Last year 1,944 New Yorkers saw something and said something.
DeltaMD11
Sun Mar 02, 2003 8:33 am
Well,
I'm glad that we have reached an overall concensus here. I guess theres your answer.
flyboy80
Sun Mar 02, 2003 11:05 am
You'll hear, "flight attendants arm your doors and cross check" usually checking to make sure doors are armed. ALthough it depends which airline, different airlines use it differently
wilcharl
Sun Mar 02, 2003 12:22 pm
...Cross Check means basically to go over the cabin to make sure all of the seat backs and tray tables are up, and that the passengers are buckled up, and to make sure all luggage is stowed, and that all electronic items are off. Basically Cross Check is Checking to make sure the plane is ready for takeoff/landing ETC.
UHHHHH NOOO!
A cross check is exactly what it says. one person does it and the other cross checks it..
For example flight attendents prepare all doors for departure cross check and all call" The FA verifies the girt bar is in place, and the other one cross checks it... cross checks are used throughout aviation. in the cockpit, the altimiters, radios and other key things are checked and crosschecked... its a method of verifying that key items are done and done properly when running a checklist.... get it right guys...
airplay
Tue Mar 04, 2003 7:54 am
I think it's a reminder for the passengers to check that they have their rosaries. They're going to need them if the pilots are as ill equipped to define a simple command as the arm-chair flight attendants on this thread are...
 Smile
wilcharl
Tue Mar 04, 2003 9:03 am
Airplay good response i was begining to question the seriousness of this forum
airlinelover
Thu Mar 06, 2003 6:41 am
DeltaMD11 is correct..
To "Cross Check" is to verify that the emergency exit door is armed/disarmed and your cross check partners (I.E L1 and R1) door is armed/disarmed correctly..
Chris
Lets do some sexy math. We add you, subtract your clothes, divide your legs and multiply
backfire
Thu Mar 06, 2003 8:41 am
Cross-check (transitive verb): To check by a second or alternative method.
Amazing things dictionaries...
aa61hvy
Thu Mar 06, 2003 11:33 am
"Flight Attendants please prepare for arrival and crosscheck"  Smile/happy/getting dizzy
Go big or go home
USAFHummer
Thu Mar 06, 2003 1:30 pm
An illegal move in ice hockey...can any hockey buffs clarify  Big grin
Greg
Leezyjet
Fri Mar 07, 2003 5:15 am
Just to enhance what has been said :-
If 2 crew members are working on opposite doors (L1 and R1), they will BOTH cross to the opposite door and check that their partner has armed/disarmed the door properly - hence Cross check. (Although in realty they will just look across).
Also used in the f/deck too when checking instrument settings and readouts etc. They (for example) use it on take off to verify both ASI's are reading the same speed - One will call out (say for example) "80 Knots", and the other will check his ASI and reply "Cross Check" implying that his too reads 80 Knots.
 Smile
"She Rolls, 45 knots, 90, 135, nose comes up to 20 degrees, she's airborne - She flies, Concorde Flies"
Users browsing this forum: bombayduck, VIflyer, VTBDflyer and 1 guest
