BR715-A1-30
Why One Thrust Reverser On This Plane
Fri Mar 14, 2003 8:58 am
Photo © Art Brett
If you look closely at this picture, the #2 Engine Thrust Reverser is open, but the #1 T.R. is closed. Why is this?
Puhdiddle
LMP737
RE: Why One Thrust Reverser On This Plane
Fri Mar 14, 2003 9:12 am
It's quite possible that the aircraft was having problems with the #1 T/R and it was placarded inop. In other words it was de-activated. Commercial aircraft can have one inop reverser as long as the other one is fully functional. Airports with short runways such as SNA it is required that both are operational.
ConcordeBoy
Fri Mar 14, 2003 12:31 pm
Dont some regional jets not utilize R/T at all..... I've heard tell that BA's ERJs dont even come equipped with T/R-capable engines. How accurate is that?
FDXmech
Fri Mar 14, 2003 2:14 pm
Could be. The F28 doesn't have any.
Fri Mar 14, 2003 3:28 pm
This question is for LMP737...
I was taught and am under the impression that thrust reversers were NEVER included in calculating the runway requirements for either takeoff or landing. Your comment about SNA was news to me. Can you clarify.
Jetguy
jwenting
Fri Mar 14, 2003 5:15 pm
Another possibility is crosswind compensation.
If there's a bad crosswind, using only a single T/R would cause asymetric thrust which can help keep the aircraft on centerline.
I wish I were flying
T prop
Fri Mar 14, 2003 5:22 pm
One possible reason for this is a lightly loaded airplane can get moving pretty quick. If you don't want to be on the brakes constantly, open a reverser and let one engine push the airplane.
T prop.
L-188
Fri Mar 14, 2003 5:34 pm
We had a metro that had to taxi in with some beta on the upwind engine due to the winds we have been suffering up here.
But I have seen some G-V's taxi out and when in the run-up area pop one reverser and then close it and then do the same to the other side.
Some sort of preflight check???
[Edited 2003-03-14 09:35:04]
paulc
Fri Mar 14, 2003 7:39 pm
BA regional EMB145's do not come equipped with reversers which had lead to some problems in the wet at my local airport ie insufficient runway length to stop when wet. They often divert to Bournemouth where the runway is longer.
As for the CRJ in the photo - T.prop is probably right - you do not want taxi speeds to get to high and it saves brake/tyre wear by not having to 'ride' them.
English First, British Second, european Never!
Fri Mar 14, 2003 11:08 pm
I'll buy the "taxi speed limiter" scenario. It's a quite common practice. The preflight check scenario is also a possibility, but the required checks are usually done on both engines simultaneously. However, I know of no reason why they must be done at the same time.
Thrust reversers are NEVER included in calculating the runway requirements for either takeoff or landing. Thrust reversers don't stop airplanes, brakes stop airplanes. That's the reason why they can be deactivated and the aircraft still dispatched - with no performance penalties. If I'm flying with a pilot who hasn't learned that basic lesson I won't let him touch the T/Rs at all. I've seen pilots nearly run off the runway while piddling around with the reversers. Many aircraft have minimum speeds at which the reversers can be deployed with anything more than idle reverse power. Get the airplane on the ground, get on the brakes while deploying the T/Rs. Under certain conditions, T/Rs can be very destabilizing and should not be deployed - they will only aggravate weather vaning tendencies. The braking effect of thrust reversers are never included in calculating the runway required for landing. Their effect is only used as a "pad" or "cushion".
Jetguy
m717
Fri Mar 14, 2003 11:41 pm
I will agree with the others who say that landing distances/runway required performance calculations are never predicated on the use of reverse thrust. Inoperative components that DO affect these calculations include brakes/anti-skid and spoilers. But not thrust reversers.
Also, the use of a single thrust reverser to compensate for crosswind is not a good idea or an accepted technique.
411A
Sat Mar 15, 2003 2:10 am
'Never' applies to FAA certification, however those familiar with the United Kingdom certification requirements will recognise that 'never' does not apply to some aircraft on the UK register, ie: wet runway performance. Different strokes for different folks.
Sat Mar 15, 2003 4:06 am
Oops, my bad.
There are two words that you should use very cautiously when it comes to aviation - "Always" and "Never".
Jetguy
[Edited 2003-03-14 20:07:23]
sllevin
Sat Mar 15, 2003 5:53 am
It's pretty common for CRJ's to taxi on a single engine, because, with both engines running, you're on the brakes quite a bit. So if you were already taxiing one one engine and still got a touch fast, you'd only have one T/R deployed. It certainly appears if the aircraft in this shot is on a taxiway and not a runway.
Steve
avioniker
Sat Mar 15, 2003 6:25 am
Jetguy,
Don't feel too bad. Your choice of words wasn't that far off.
One more scenerio: A couple of my "buds" from Mesa told me that it has happened that maintenance has requested the engine be shut down with the T/R deployed (after landing) to prevent windmilling.
Any Mesa guys out there??
LMP737
Sun Mar 16, 2003 1:40 am
Jetguy:
The MEL for the 757 as an example states that one T/R maybe inop. However it stipulates that the aircraft not be flown into an airport with a runway less than 7100ft. Since SNA's runway is 5600 one would not be able, technically, to land a 757 there.
If I were a 757 pilot flying into SNA with a plane full of passengers I would want both T/R's functional.
fr8tdog
Sat Mar 22, 2003 3:27 am
Most likely it is during taxi, that this event is occurring.
My airlines Ops specs specifically say that this is a "no-no" during normal taxiing, fearing Fod ingestion.
It also is common that a TR is MEL'd out due to a maintenance issue.
Under normal landing operations, TR reduction is started at 80kts then should be stowed at no less than 50kts, to reduce the chances of Fodding an engine.
Again this is the OPS procedures at my airline.
Fr8t.
Jan Mogren
Sat Mar 22, 2003 11:28 pm
Most likely just Idle reverse, which I think should not be any greater risk of having FOD? You don't want any reverse so to speak, you just want the engine to stop pushing you faster.
/JM
AeroPresentation - Airline DVD's filmed in High Definition
Night_Flight
Mon Mar 24, 2003 11:14 am
I flew on a CRJ-200 our of ORD last night and I the #2 engine was not started until we had taxied closer to the runway. Is this a common practice on CRJ's , DC'9s, Citations????????
-Night_Flight-
Remember when sex was safe and flying was dangerous?
fallingeese
Mon Mar 24, 2003 11:38 am
Night_Flight - it is sometimes a common practice to save money, some carriers such as Westjet will taxi on one engine, fuel is money, and especially in these hard times, little measures save cash.
Mark McWhirter...Contrails Photography
BR715-A1-30
Tue Mar 25, 2003 3:07 am
Of the 12 flights with AirTran I have taken, we only taxied on one engine once. The pilot started #1, and when we got to the runway we had to hold short because of incoming traffic, and that is when the pilot took the liberty to start #2.
IIRC, Valujet used to do Single-Engine Taxis all the time.
[Edited 2003-03-24 19:08:22]
Puhdiddle
fr8tdog
Tue Mar 25, 2003 6:47 am
Night-flight,
Single engine taxi is dependent on several factors.
If I am faced with a long ground stop or if # 10 or 15 for departure, I may consider shutting an engine down for fuel conservation. Especially if I have a longer flight.
Weather has a huge effect on slowing departures down, some pilots may elect to shut an engine down to decrease fuel consumption, allowing them a greater chance of departing without having to refuel and start at the back of the taxi line again.
avt007
Tue Mar 25, 2003 7:25 am
A certain Dash 7 operator was reputed to taxi on 2 engines, and on one occasion, attempted to takeoff the same way. As the tale goes, SOPs were changed after that. Another good aviation tale..........
Users browsing this forum: Afstand, cumulushumilis, N415XJ, Newark777 and 2 guests
