masseybrown
JP-8 Fuel
Wed Mar 19, 2003 4:06 pm
Is there any regular commercial use for JP-8? Over-the-pole flights?
L-188
RE: JP-8 Fuel
Wed Mar 19, 2003 4:14 pm
JP8 is military Kerosene.
That was the replacement for JP4 and Diesel. We burned it in all of our helicopters and in all of our trucks.
I would say it is pretty close to Jet A.
I would go so far as to say that if you get fueled at a miltary airport that is what you are burning. At least at Army Airfields.
L-188
RE: JP-8 Fuel
Wed Mar 19, 2003 4:20 pm
Oh I want to add that the JP4 I mentioned is pretty close to civillian Jet B, which is cut with gasoline to lower it's freeze point.
Jet A -50 is Jet A fuel cut with other chemicals to lower it's freeze point.
PPGMD
RE: JP-8 Fuel
Wed Mar 19, 2003 10:46 pm
I should mention that JP-8 isn't compatable with all jet engines. Jerry Mercer found that out the hard way, when he was flying the BD-5J for Budwiser Aerobatic Team, after a preformance at a military airfield they refueled his plane with JP-8. Well he made it upto alititude before his engine went out on him.
At worst, you screw up and die.
masseybrown
RE: JP-8 Fuel
Thu Mar 20, 2003 1:55 am
Thanks, L-188 (L-188 used to be/maybe still is my favorite plane) I know the specs and what JP-8 is for.
We're trying to put together a fuel "menu" for a fixed base that will support occasional transiting military customers as well as everyday commercial business. We know there will be a rare call for JP-8 from the military people - I just wonder if we would EVER get a commercial request for it. And if so, what would be the circumstances?
TIA for any help.
mikeclod
RE: JP-8 Fuel
Thu Mar 20, 2003 2:24 am
When I worked at an FBO in BOI, we were constantly fueling military transient flights, Air Force training flights, and National Guard aircraft. We just put Jet-A w/prist(fsii) in most of them. And this wasn't just one or two types, but quite a few different ones. We would do F-18s, F-16, F-15, Av-8b, C-130, C-9, C-12, Ah-64, Uh-60, Ch-47, A-10, T-37/8, we even did a Kc-135 once. They didn't seem to worry about it. The only precaution to take when mixing two different types of fuel is to fuel the AC slower. This is supposed to lower the amount of static created from the fuel mixing in the tank. For quite awhile, we fueled all the airlines' ground equipment with Jet-A too. They all ran fine, just a little more exhaust than with diesel.
Mikeclod
avioniker
RE: JP-8 Fuel
Thu Mar 20, 2003 2:40 am
Another difference is that JP-4 is Naptha based while virtually all others (JP-7 a noteworthy exception) are kerosene based. JP-8 also has floability additives in addition to Fuel System Icing Inhibitors which will cause transfer pumps and anything else with a neoprene seal to leak like a seive.
When the Air Force bought the KC-10's they all flew on JP-4 originally and in the states. When USAFE changed over to JP-8. We'd go to Europe on deployments and within a week, any marginal seals were leaking like crazy. We'd bring the planes "home" to get them fixed and if we took fuel at any stateside location enroute (JP-4 or JP-5 didn't matter) the leaks would be all gone by the time troubleshooting could begin.
One more thing; The Navy used JP-5 which provided a measure of fire safety over JP-4 on the ships. When JP-4 mixes with 5 there's a chemical reaction which lowers the flash point to below that of either fuel. We used to get very angry communications from Carrier Air Bosses if they found JP-4 in any of their planes.
avioniker
RE: JP-8 Fuel
Thu Mar 20, 2003 2:49 am
You shouldn't ever get a commercial request for JP-8. That's a military designation and formula.
L-188
RE: JP-8 Fuel
Thu Mar 20, 2003 3:28 am
Any time we got anything military, P-1 C-130, C-9, C-12, C-21's mostly that where tranfering through PACD, quite often on their way to Hickam, they always got Jet A. We didn't sell any JP fuels.
In the situation that you are discribing I would just stock Jet A. Every Aircraft including military aircraft has an approved fuels list in their ops or flight manuals. I want to say that there is nothing the flight crew has to do to go from Jet A to JP8 but don't hold me to that. It isn't like burning Avgas in a turbine engine where there are hour limits and additives to be added to allow it to be used in lue of jet fuel.
masseybrown
RE: JP-8 Fuel
Thu Mar 20, 2003 5:30 am
Thanks, guys. Very helpful.
Users browsing this forum: SAAFNAV, Starlionblue and 23 guests
