sudden
Checklists.
Tue Apr 08, 2003 8:39 pm
On my way to work this morning I was looking at T/O's from Schiphol as they passed rather low over me on my way to work.
A question was raised in my head.  Wow! !  Smile
How many checklists are done during a flight? I could come up with 3, pre-flight, T/O, landing. Is there more checks done?
Does it maybe differ from carrier to carrier and from A/C types?
Any info appreciated.
Aim for the sky.
Sudden  Smile
When in doubt, flat out!
Rick767
RE: Checklists.
Tue Apr 08, 2003 9:56 pm
This will of course vary from aircraft to aircraft, and to some extent from airline to airline.
My airline uses the following checklists from the moment we are ready to push back to the shutdown at the destination gate:
Before Start Checklist
After Start Checklist
Before Take-off Checklist
After Take-off Checklist
Descent Checklist
Approach Checklist
Landing Checklist
After Landing Checklist
Shutdown Checklist
So, in general, more than you thought!
AAR90
RE: Checklists.
Tue Apr 08, 2003 10:15 pm
AA's 737 fleet Normal Procedures checklists [with subsections listed]:
a) Before Starting Engines
-10 minutes prior to departure
-Prior to engine start/pushback
-When cleared to start engines
b) After Starting Engines
c) Taxi
-single engine taxi (if required)
d) Before Takeoff (mechanical checklist built into cockpit)
e) After Takeoff - Climb
f) Cruise
g) Descent
h) Before Landing (mechanical checklist built into cockpit)
i) After Landing - Taxi
- when clear of runway
- two minutes prior to gate arrival
- single engine taxi
j) Parking
- overnight terminations
-after all pax have deplanned
sudden
RE: Checklists.
Tue Apr 08, 2003 11:31 pm
Hm....
that was way more then I knew!
What does it meen with "mechanical checklist built into cockpit"?
Aim for the sky.
Sudden
m717
RE: Checklists.
Wed Apr 09, 2003 1:40 am
I figured I'd add the ones my airline uses in the 717.
Before Start
Before Taxi
Before Takeoff
Climb
In-Range
Landing
After Landing
Parking
Terminating
CPH-R
RE: Checklists.
Wed Apr 09, 2003 2:34 am
AFAIK, the 777 has an small screen just above the FMC, which can be used to display a checklist. Some of the items will then be checked by the aircraft it self, and some of them will have to be confirmed by the NFP.
XFSUgimpLB41X
RE: Checklists.
Wed Apr 09, 2003 3:25 am
Northwest configures their normal ops checklist in the following manner for all aircraft- remember various flow patterns are completed to configure the airplane before this, these are checklists, not do lists.
Safety
Preflight
Before Start
Before Taxi
Taxi
All Engines
Before Takeoff
Climb
Descent
Approach
Landing
After Landing
Parking
Securing
[Edited 2003-04-08 20:57:45]
Chicks dig winglets.
Rick767
RE: Checklists.
Wed Apr 09, 2003 5:31 am
"remember various flow patterns are completed to configure the airplane before this, these are checklists, not do lists"
That is very correct. It is really important to differentiate between the procedure and the checklist. This is something GA pilots on single pilot aircraft will perhaps be less accustomed to.
Our SOPs detail this "operational philosophy" as such:
"The philosophy is that normal procedures are accomplished by recall and that their action is confirmed by checklist. It is not necessary to call for a checklist to initiate a procedure.
For example, the Before Take-off procedure can be commenced by the non-handling pilot as the aircraft approaches the runway with a clearance to "Line Up" or "Take-off". He or she does not need to wait for the handling pilot to call for the procedure or checklist to carry out the actions. In this case at a suitable time prior to takeoff the handling pilot will call for the "Before Take-off checklist" and confirm that all the actions have been carried out.
Likewise after landing the non-handling pilot will accomplish the "After Landing Procedure" by recall once the aircraft has vacated the runway and any necessary R/T calls have been made. It is not necessary for the handling pilot to call for the procedure or to signal for it by moving the speedbrake level, or by any other means."
We do have some checklists which require the more GA-style "read-and-do" method, like items from the QRH for handling non-normal procedures. In this case it is common for us to complete some items by recall (so called "memory items") then continue the diagnosis by checklist in a read-and-do fashion.
AAR90
RE: Checklists.
Wed Apr 09, 2003 5:38 am
I believe AA is one of the few (if only) airlines that installs a mechanical checklist into the cockpit panel of all of its aircraft. Only the most important items --the Before Takeoff & Before Landing checklists-- are contained on this mechanical device. No matter what you forget to do anywhere/anytime, if you accomplish these checklists the plane will safely takeoff, fly and land [you might not know where you're going, but it will operate safely]  Wink/being sarcastic
The old B727 & DC10 checklist was a simple device with the two checklist items listed vertically side-by-side; Takeoff checklist on the left, Landing checklist on the right. A black bar slid in a track so that the bar would always cover either the Takeoff item or Landing item in its respective slot. The Flight Engineer "ran" the checklists and I can not recall a single flight during my one year as FE where the Captain did not glance over his right shoulder just prior to Takeoff roll or at ~500'agl to verify checklist completion.
The newer planes (MD80 & later) have lighted items (again in pairs of Takeoff & Landing checklists) so that when an item is completed a pilot flips its respective switch and the item name goes blank and a blue light illuminates indicating item completion. When all items are complete the mechanical checklist shows (one or) two rows of blue lights only [no words visible].
The B757/767 Mechanical Checklist is located just to the right of the Landing Gear Handle.
Photo © Mauricio Acosta
The MD80/90 Mechanical Checklist is located to the left of the ACARS panel on the center pedistal.
Photo © Ben Wang
The nicest feature of using the mechanical checklists is that one can perform the items out of sequence (if permitted) and have a quick, easy and reliable method of determining what has not been completed. I too have taken up the habit of glancing at the mechanical checklist to ensure all items are complete prior to takeoff roll or final phase of approach/landing. The mechanical checklists have ensured I have never taken-off or landed with an improperly configured aircraft [at least not yet] during the past 15+ years.  Big thumbs up
RE: Checklists.
Wed Apr 09, 2003 10:40 am
Obviously - observing a checklist is a MUST as a tool to safety...
xxx
A recommendation, based on years of experience as line pilot and instructor - Any time you line-up a jet for takeoff, here are the "3 KILLERS" that you may have (shall we say) "disregarded" for various reasons...
1. TRIM SET
2. FLAPS (L.E. and T.E.) SET
3. SPOILERS (or speedbrakes) SET
Twice in my career, I lined-up an airplane with "checklists completed" - yet the flaps were... UP - (because we taxied in ice and snow) - if the takeoff warning horn did not operate, could have meant a disaster...
xxx
The "3 KILLERS" check works for any type of jet transport aircraft... you may forget your lights, your cabin warning, your ignition... and other items, but chances it will not prevent you to get in the air... while the 3 KILLERS will...
xxx
Fly safe - happy contrails  Smile
(s) Skipper
RE: Checklists.
Wed Apr 09, 2003 1:27 pm
Just for grins, I've cut and pasted the checklists for the Gulfstream G200.
Jetguy
GULFSTREAM G200 CHECKLIST
ABBREVIATED PROCEDURES
INITIAL PREFLIGHT
CABIN INSPECTION. . . . . . . . . . . . . . . . COMPLETE
SWITCHES & CB’s . .. . . . . . . . . . . . . . . . . . . .SET
LANDING GEAR SELECTOR . . . . . . . . . . . . . . .DOWN
FUEL LOAD. . . . . . . . . . . . . . . . . . . . . . . . .CHECK
EXTERIOR INSPECTION. . . . . . . . . . . . . .. COMPLETE
COCKPIT PREFLIGHT
BATTERY MASTER SWITCH. . . . . . . . . .OVERRIDE
EMERGENCY BATTERY SWITCH. . . . . .OVERRIDE
BATTERY VOLTAGES (3). . . . . . . . . . . . . . . .CHECK
EMERGENCY BATTERY SWITCH. . . . . . . . . . . .OFF
EXTERNAL POWER OR APU. . . . . . . . . CHECK/ON
AVIONICS SWITCHES. . . . . . . . . . . . . . . . . . . . . .ON
FMS’s. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ON
IND TEST SWITCH. . . . . . . . . . . . . . DCU A / DCU B
VMO/MMO SWITCH. . . . . . . . . . . . . . . . .ADC 1 / ADC 2
WINDSHIELD HEAT. . . . . . . . . . . . . . . . . . . . . .TEST
DE-ICE TEST. . . . . . . . . . . . . . . . . . . . . . . . . . . TEST
ENGINE VIBRATION TEST. . . . . . . . . . . . . . . . TEST
STBY GYRO. . . . . . . . . . . . UNCAGE / TEST / CAGE
FUEL WING INTERCONNECT. . . . . . . . . . . . CYCLE
ANTISKID SWITCH. . . . . . . . . . . . . . . . . . . . OFF/ON
ENGINE FIRE/BLEED AIR. . . . . . . . . . . . . . . . . TEST
COMPASS/DG SWITCHES. . . . . . . . . . . . . . . SLAVE
DITCH BUTTON. . . . . . . . . . . . . . . . . . . . . . . . . . OFF
DUMP BUTTON. . . . . . . . . . . . . . . . . . . . . . . . . . OFF
PRESSURIZATION MODE SELECTOR. . . . . . AUTO
DESTINATION FIELD ELEVATION. . . . . . . . . . . SET
REFUEL OFF BUTTON. . . . . . . . . . . . . . . . . . . . OFF
APR BUTTON. . . . . . . . . . . . . . . . . . . . . . . . . . . .OFF
ENGINE SYNC. . . . . . . . . . . . . . . . . . . . . . . . . . . OFF
RUDDER BIAS. . . . . . . . . . . . . . . . . . . . . . . . . . . OFF
STICK PUSHER. . . . . . . . . . . . . . . . . . . . . . . . . . .ON
FUEL CUTOFF BUTTONS. . . . . . . . . . . . . .CUT OFF
FLIGHT/GROUND AIRBRAKES. . . . .RETRACT/OFF
THRUST LEVERS. . . . . . . . . . . . . . . . . . . . . . . . IDLE
AUX HYDRAULIC PUMP. . . . . . . . . . . . . . . . . .AUTO
STALL TEST. . . . . . . . . . . . . . . . . . . . . . . . . . . .TEST
AUTOPILOT MODES/TRIM. . . . . . . . . . . . . . .CHECK
TRIMS (4). . . . . . . . . . . . . . . . . . . . . . . . .CHECK/SET
AUX HYDRAULIC PUMP. . . . . . . . . . . . . . . . . . . OFF
CABIN & COCKPIT MANUAL BUTTON. . . . . . . .OFF CABIN & COCKPIT TEMP SELECTOR. . . . . . . . SET
BAGGAGE PRESS BUTTON. . . . . . . AS REQUIRED
FMS’s. . . . . . . . . . . . . . . . . . . . . . . . . . . . .PROGRAM
O2 SHUTOFF SWITCH. . . . . . . . . . . . . . . . . . . . . ON
PASSENGER O2 PANEL SWITCHES. . . . . . . . . SET
CREW O2 MASKS. . . . . . . . . . . . . . . . . . . . . .CHECK
CVR. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .TEST
ATIS. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . COPY
TAKEOFF DATA. . . . . . . . . . . . . . . . . . . . .COMPUTE
VOR LOG. . . . . . . . . . . . . . . . . . . . . . . . . . CURRENT
AVIONICS SWITCHES. . . . . . . . . . . . AS REQUIRED
EXTERNAL POWER SWITCH. . . . . . AS REQUIRED
BATTERY SWITCH. . . . . . . . . . . . . . .AS REQUIRED
EXTERNAL POWER. . . . . . . . . . . . . . DISCONNECT
STARTING ENGINES
INTERIOR / EXTERIOR LIGHTS. . . . . . . . AS REQ’D
APU. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .START
APU GENERATOR. . . . . . . . . . . CHECKED/ON LINE
CABIN AIR. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . APU
FMS’s. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ON/SET
V SPEED BUGS. . . . . . . . . . . . . . . . . . . . . . . . . . SET
GALLEY SWITCHES. . . . . . . . . . . . . . . . . .AS REQ’D
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
FUEL CUTOFF BUTTONS. . . . . .ON & LIGHTS OUT
R/H ENGINE. . . . . . . . . . . . . . . . . . . . . . . . . . .START
ENGINE INSTRUMENTS. . . . . . . . . . . . . . . NORMAL
L/H ENGINE. . . . . . . . . . . . . . . . . . . . . . . . . . . START
BEFORE TAXI
BATTERY MASTER SWITCH. . . . . . . . . . . . . . . . .ON
EMERGENCY BATTERY. . . . . . . . . . . . . . . . . . . . ON
EMERGENCY LIGHTS. . . . . . . . . . . . . .CHECK/ARM
NOSEWHEEL STEERING. . . . . . . . . . . . . CONNECT
HYDRAULIC PRESSURES. . . . . . . . . . . . . NORMAL
SLATS & FLAPS. . . . . . . . . . . . . . . . . . . . . . . . . .SET
AIR BRAKES. . . . . . . . . . . . . . . . . . . . . . . . . . CYCLE
PASSENGER BRIEFING . . . . . . . . . . . . .COMPLETE
CABIN DOOR MESSAGE. . . . . . . . . . . . . . . . . . .OUT
PARKING BRAKE. . . . . . . . . . . . . . . . . . . . . . . . .OFF
TAXI
BRAKES/STEERING. . . . . . . . . . . . . . . . . CHECKED
THRUST REVERSERS. . . . . . . . . . . . . .ARM/CYCLE
RUDDER BIAS. . . . . . . . . . . . . . . CHECKED/ARMED
APR. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .ARMED
FLIGHT CONTROLS. . . . . . . . . . . . . . . . . . . .CHECK
FLIGHT INSTRUMENTS. . . . . . . . . . . . .CHECK/SET
FLIGHT DIRECTOR/NAVAIDS. . . . . . . . . . . . . . .SET
TRIMS (3). . . . . . . . . . . . . . . . . . . . . . . . . . . . VERIFY
SLATS/FLAPS. . . . . . . . . . . . . . . . . . . . . . . . .VERIFY
AIRBRAKES. . . . . . . . . . . . . . . . . . . . . . . . .STOWED
ANTISKID LIGHTS. . . . . . . . . . . . . . . . . . . . . . . . OUT
STANDBY GYRO. . . . . . . . . . . . . . . . . . . .UNCAGED
EICAS MESSAGES. . . . . . . . . . . . . . . . . . . NORMAL
CABIN AIR. . . . . . . . . . . . . . . . . . . . . . . . . . . . . BOTH
ENGINE A/I. . . . . . . . . . . . . . . . . . . . . . . . . . . CHECK
PROBE HEATS. . . . . . . . . . . . . . . . . . . . . . . . . AUTO
BAGGAGE HEAT. . . . . . . . . . . . . . . . . . . . . TEST/ON
CREW BRIEFING . . . . . . . . . . . . . . . .COMPLETE
APU. . . . . . . . . . . . . . . . . . . . . . . . . AS NECESSARY
HI FLOW SWITCH. . . . . . . . . . . . . . . . . . . . . . . . OFF
TAKEOFF
EXTERNAL LIGHTS. . . . . . . . . . . . . . AS REQUIRED
IGNITIONS. . . . . . . . . . . . . . . . . . . . . .AS REQUIRED
TRANSPONDER. . . . . . . . . . . . . . . . . . . . . . . . . . ALT
THRUST REVERSERS. . . . . . . . . . . . . . . . . .ARMED
RUDDER BIAS. . . . . . . . . . . . . . . . . . . . . . . . ARMED
N1 POWER SETTING. . . . . . . . . . . . . . . . . . .REVIEW
AFTER TAKEOFF
LANDING GEAR. . . . . . . . . . . . . . . . . . . . . . . . . . . UP
THRUST REVERSERS. . . . . . . . . . . . . . . . . . . . .OFF
YAW DAMPER. . . . . . . . . . . . . . . . . . . . . . . . . . . . ON
FLAPS/SLATS. . . . . . . . . . . . . . . . . . . . . . . . . . . . .UP
EXTERIOR LIGHTS. . . . . . . . . . . . . . .AS REQUIRED
CLIMB
CLIMB POWER. . . . . . . . . . . . . . . . . . . . . . . . . . .SET
ENGINE INSTRUMENTS. . . . . . . . . . . . . . . . CHECK
PRESSURIZATION. . . . . . . . . . . . . . . . . . .MONITOR
APR. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .OFF
ENGINE SYNC. . . . . . . . . . . . . . . . . . . . . . . . . . . .ON
CABIN AIR. . . . . . . . . . . . . . . . . . . . . . VERIFY BOTH
APU. . . . . . . . . . . . . . . SHUTDOWN/DOOR CLOSED
FL100
SEAT BELT SIGN. . . . . . . . . . . . . . . . AS REQUIRED
FL180 / TRANSITION ALTITUDE
ALTIMETERS (3). . . . . . . . . . . . . . . . . . . . SET 29.92”
PULSE LIGHTS. . . . . . . . . . . . . . . . . . . . . . . . . . .OFF
WINDSHIELD HEAT. . . . . . . . . . . . . . . . . . . . . . LOW
DESCENT
ATIS/LANDING DATA. . . . . . . . . . . . . . . . . . .OBTAIN
VREF. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . SET
DESTINATION FIELD ELEVATION. . . . VERIFY SET
FUEL BALANCE/QUANTITY. . . . . . . . . . . . . .CHECK
CREW BRIEFING. . . . . . . . . . . . . . . . . . .COMPLETE
SAFETY GATES. . . . . . . . . . . . . . . . . . . . . . . . . . SET
FL180 / TRANSITION LEVEL
WINDSHIELD HEAT. . . . . . . . . . . . . . AS REQUIRED
LANDING LIGHTS. . . . . . . . . . . . . . . . . . . . . . PULSE
ALTIMETERS. . . . . . . . . . . . . . . . . . . . . . . . . . . . SET
FBO. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .NOTIFY
BEFORE LANDING
SEAT BELT SIGN. . . . . . . . . . . . . . . . . . . . . . . . . .ON
PAX BRIEFING. . . . . . . . . . . . . . . . . . . . .COMPLETE
CABIN AREA. . . . . . . . . . . . . . . . . . . . . . . SECURED
NAVAIDS. . . . . . . . . . . . . . . . . . . . . SET/IDENTIFIED
SLATS/FLAPS. . . . . . . . . . . .SELECTED/INDICATED
LANDING GEAR. . . . . . . . . . . . . . . DOWN/3 GREEN
HYDRAULIC PRESSURES (2). . . . . . . . . . .NORMAL
GROUND AIRBRAKES. . . . . . . . . . . . . . . . . . . . . .ON
THRUST REVERSERS. . . . . . . . . . . . . . . . . . . . . .ON
TAXI/LANDING LIGHTS. . . . . . . . . . . . . . . . . . . . .ON
FLAPS 40°. . . . . . . . . . . . . . .SELECTED/INDICATED
YAW DAMPER. . . . . . . . . . . . . . . . . . .DISENGAGED
FINAL LANDING CHECK
HYDRAULIC PRESSURE (2). . . . . . . . . . . .NORMAL
FLAPS. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .SET 40°
MISSED APPROACH
POWER LEVERS. . . . . . . . . . . . . . . . AS REQUIRED
FLAPS. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .20°
GROUND AIRBRAKES. . . . . . . . . . . . . . . . . . . . .OFF
ALTITUDE SELECTOR. . . . . . . . . . . . . . . . . . . . .SET
AFTER LANDING (2-ENGINE SHUTDOWN)
STOP WATCH. . . . . . . . . . . . . . . . . . . . . . . . . START
IGNITIONS. . . . . . . . . . . . . . . . . . . . . . . . . . . . .AUTO
RIGHT STBY FUEL PUMP. . . . . . . . . . . . . . . . . . .ON
LEFT STBY FUEL PUMP. . . . . . . . . . . . . . . . . . . OFF
MAIN BATTERY SWITCH. . . . . . . . . . . . .OVERRIDE
BAGGAGE HEAT. . . . . . . . . . . . . . . . . . . . . . . . . OFF
WINDSHIELD HEAT. . . . . . . . . . . . . . . . . . . . . . .OFF
ENGINE ANTI-ICE. . . . . . . . . . . . . . . . . . . . . . . . OFF
TRANSPONDER. . . . . . . . . . . . . . . . . . . . .STANDBY
EMERGENCY GYRO. . . . . . . . . . . . . . . . . . . CAGED
TRIMS (3). . . . . . . . . . . . . . . . . . . . . . . . . . . . .RESET
TRIP. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . RECORD
FMS’s. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . OFF
CLOCKS. . . . . . . . . . . . . . . . . . . . . . . . . . . . . .RESET
SHUTDOWN
PARKING BRAKE. . . . . . . . . . . . . . . . AS REQUIRED
NOSEWHEEL STEERING. . . . . . . . . . . . . . . . . . OFF
EMERGENCY BATTERY. . . . . . . . . . . . . . . . . . . OFF
EMERGENCY LIGHTS. . . . . . . . . . . . . . . . . . . . .OFF
O2 SHUTOFF SWITCH. . . . . . . . . . . . . . . . . . . . .OFF
EXT/INT LIGHTS. . . . . . . . . . . . . . . . .AS REQUIRED
FUEL CUTOFF BUTTONS. . . . . . . . . . . . . . CUTOFF
GUST LOCK. . . . . . . . . . . . . . . . . . . . AS REQUIRED
AVIONICS MASTER SWITCHES. . . . . . . . . . . . .OFF
CABIN AIR. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . RAM
APU. . . . . . . . . . . . . . . . . . . . . . . . . . . . .SHUTDOWN
INTERIOR / EXTERIOR LIGHTS. . . . . . . . . . . . . OFF
BATTERY MASTER SWITCH. . . . . . . . . . . . . . . .OFF
QMS DEBRIEFING. . . . . . . . . . . . . . . . . .COMPLETE
AFTER LANDING (1-ENGINE SHUTDOWN)
LH ENGINE START (QUICK TURN)
AUX HYD PUMP. . . . . . . . . . . . . . . . . . . . . . . . . .OFF
L/H FUEL PUMP. . . . . . . . . . . . . . . . . . . . . . . . . . .ON
L/H FUEL PUMP. . . . . . . . . . . . . . . . . . . . . . . . .AUTO
MAIN BATTERY SWITCH. . . . . . . . . . . . . . . . . . . .ON
EMERGENCY LIGHTS. . . . . . . . . . . . . . . . . . ARMED
BAGGAGE HEAT. . . . . . . . . . . . . . . . . . . . . . . . . . ON
CABIN AIR. . . . . . . . . . . . . . . . . . . . . .APU OR BOTH
TAXI (QUICK TURN)
PASSENGER BRIEF. . . . . . . . . . . . . . . . COMPLETE
FMS’s . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . SET
V SPEED BUGS. . . . . . . . . . . . . . . . . . . . . . . . . SET
TRIMS (3). . . . . . . . . . . . . . . . . . . . .SET & VERIFIED
SLATS/FLAPS. . . . . . . . . . . . . . . . . SET & VERIFIED
TAKEOFF
sudden
RE: Checklists.
Wed Apr 09, 2003 4:51 pm
GEEEE Jetguy,
you have any time left to fly that thing!?  Big grin
Aim for the sky.
Sudden
ben
RE: Checklists.
Wed Apr 09, 2003 5:47 pm
Most Russian/Soviet aircraft have what you call Mechanical Checklists. I was told that Russian pilots call them "Check Boards" because they are not on the instrument panel, but are handheld boards. They're stowed in the pocket behind each of the pilot's seats (on the Tu-154).
CX Flyboy
RE: Checklists.
Wed Apr 09, 2003 9:45 pm
Bloody hell Jetguy, that's one hell of a checklist!!
goboeing
RE: Checklists.
Thu Apr 10, 2003 12:02 am
...and the funny thing is for Jetguy's post, it says "Abbreviated Procedures"! However, I printed out a full 777 checklist and it took 19 pages at about 10pt font, every line used. This was of course, every single item including initialization and complete shutdown and also the walkaround inspection. Thanks Jetguy! Time for some G200 training in flight simulator now!
Nick
AmeriCam
RE: Checklists.
Thu Apr 17, 2003 5:51 am
Even some small airplanes have fairly sizeable checklists... at my Part 141 school we have standard flows, with PF/PNF (CRM) responsiblilities...
Interior Preflight (Do List)
Exterior Preflight (Do List)
Before Start (Flow)
Engine Start (Cold, Hot, Flooded, EPU) (Do List)
After Engine Start (Flow)
Before Taxi (Flow)
Taxi (Flow)
Runup (Do List)
Before Takeoff (Flow)
Climb (Flow)
Cruise (Flow)
Decent (Flow)
Before Landing (Flow)
After Landing (Flow)
Shutdown (Do List)
Postflight (Do List)
In CRM situations, the difference between a Flow and a Do List, is that during a Flow, the PF (pilot flying) will go through the memorized flow (checklist), and then the PNF (pilot not flying) will go through checklist orally challenging if the checklist was completed thoroughly, with the PF responding. The Do Lists are not to be memorized but to be done right off the checklist. I.E. Our shutdown checklist (a Do List) would sound like this...
PF - "Ready Shutdown Checklist"
PNF - "Heater Defroster"... PF - "Off"
PNF - "Radio Master"... PF - "Off"
PNF - "Throttle"... PF - "Idle"
PNF - "Magnetos"... PF - "Check"
PNF - "Mixture"... PF - "Idle Cut-off"
PNF - "Magnetos"... PF - "Off"
PNF - "All Switches"... PF - "Off"
PNF - "Shutdown Checklist Complete"
Hope this helps,
Cameron
"If you're going to crash, make it a fiery one."
jhooper
RE: Checklists.
Thu Apr 17, 2003 6:09 am
Tires..............Kicked
Fires..............Lit
Last year 1,944 New Yorkers saw something and said something.
XFSUgimpLB41X
RE: Checklists.
Fri Apr 18, 2003 2:34 am
Well.. since no one commented on Jhooper's..... that was hilarious!
avt007
RE: Checklists.
Fri Apr 18, 2003 3:01 am
Now for a maintenance standpoint- we received an engineers checklist/SOP book that would fit in a shirt pocket. For the Dash8, there is 13 external steps on the walkaround, 45 cockpit checks prior to start, 12 engine start steps, 9 pre taxi checks, and 7 engine shutdown steps. Plus all the emergency procedures, and how to do common run tasks, prop governing, etc.
It was a well written book, and basically if you screwed up while in control of the aircraft, you had no excuse. The procedures were there. Follow them, and all is well  Smile Short cut a procedure, and you might cut short your career!
Users browsing this forum: deltacle, zanl188 and 2 guests
