cricri
A Tube In The Engine, What Is It?
Tue Apr 22, 2003 10:22 pm
Coming along this pic (click for large version), i was asking myself what the little tube you can see inside (top right) is ? Fire extinguisher?
http://www.airliners.net/open.file/323591/L/
Thanks for your help.
erj-145mech
RE: A Tube In The Engine, What Is It?
Tue Apr 22, 2003 10:33 pm
Its a probe to measure the air pressure going into the engine.
Sat Apr 26, 2003 8:18 am
Cher Cricri -
xxx
This probe is called "Pt-2" and measures the ambient pressure of the air in the inlet area of the engine... It works in concert with a probe, or probes which you would find in the exhaust of that engine, called "Pt-7" which measure the pressure in the turbine discharge area...
xxx
These probes are tied to a "power gage" for the engine, called EPR, exhaust pressure ratio, a primary means to set power (takeoff or cruise) on many jet engines...
xxx
In example, if the pressure is 1.50 measured at Pt-5 and the pressure at Pt-2 is 1.0, the EPR gage would indicate "1.5"...
xxx
Bonne soiree  Smile
(s) Skipper
Users browsing this forum: No registered users and 18 guests
