modesto2
777 Engine Start
Sun Apr 27, 2003 1:18 am
I read a book titled "Flying the Big Jets" by Stanley Stewart. He mentions that PW-powered 777's can execute a simultaneous autostart while GE-powered 777's (I think) must start one engine at a time. Can anyone shed some light on this matter and explain these procedures? Thanks.
ANA777Master
RE: 777 Engine Start
Sun Apr 27, 2003 5:16 am
This is quite true. The GE engines must be started after the other is at idle.
jgo
Sun Apr 27, 2003 5:43 am
Interesting, is there a particular reason?
- Jarrad
DC10Tony
Sun Apr 27, 2003 12:00 pm
I've never worked with a 777, but every other plane I've worked with never started both engines at the same time. One would start, spool up to idle speed and the capt. would start the other one.
CX Flyboy
Sun Apr 27, 2003 12:25 pm
Maybe the GE engines are so big that all the APU air is needed to turn one engine to start it?
We can start both of ours together (Rolls Royce). We simply put both engine starters to start, put the fuel switches to run, and the engine takes care of itself. At max motoring and EGT below 95 degrees, the fuel will automatically start running and the engine starts. If problems are encountered such as a hung start, hot start, no light-off within the time limit, no N1 turning etc.., the start is suspended. For certain start suspensions, the engine will wait the appropriate time, then attempt a restart for a second time. If unsuccessful, it then stops and the pilot gets to do something. It really is a foolproof system.
ba299
Sun Apr 27, 2003 6:54 pm
As always cxflybox are correct.
Here in BA we have both type of engine on our 777. On the RR equipped aircraft we can start both engine at the same time. With the GE we have to start one engine and than other due to the huge need of air to start the GE engine.
avioniker
Mon Apr 28, 2003 11:59 am
Back in the 80's, before the APU's were derated for economy and life, we used to start two engines on the KC-10's at the same time. Then we'd start #2 on the way to the runway. Those were GE CF6-50's. There were no problems or prohibitions that I knew of. That's the way we were taught by the DAC and AA folks doing our training.
muddydawg
Mon Apr 28, 2003 4:44 pm
Off topic but still cool. I have seen on many occasions C-17's start #1 engine off of the apu, deploy #1 T/R, advance the throttle to boost manifold pressure and start the other three engines at the same time. When we run for maintenance we aren't allowed to do anything special like that. The computer tracks that and if anything went wrong they would have our @$$es.
sudden
Mon Apr 28, 2003 8:30 pm
Ba299.......
welcome to A.net.
It's nice that more females join the "party".
What are you flying, and from the left or right seat?
Aim for the sky.
Sudden
When in doubt, flat out!
ba299
Mon Apr 28, 2003 9:48 pm
I just finished the training on the right seat for the 777. And my favorite are the 777 with the RR engines.
sudden
Mon Apr 28, 2003 10:15 pm
Then I add a congrats.  Smile
Aim for the sky.
Sudden
CX Flyboy
Mon Apr 28, 2003 10:42 pm
Congratulations Ba299,
I have not been on the 777 for that long either (about 9 months) and I do believe that it is one of the best aircraft in the world. I love almost everything about it apart from it's handling of VNAV descents, and putting away those bloody sunshades in the compartment on the right!
sudden
Tue Apr 29, 2003 5:07 pm
The sunshades was a good one. Big grin
Are you sure you read the manual in detail, you might have missed something.  Big thumbs up
Aim for the sky.
Sudden
CX Flyboy
Tue Apr 29, 2003 7:56 pm
The reason VNAV is so bad is because in the software load on our planes, the data used is GE90 data. The GE90 is a lot bigger than the Trent800s we use and therefore the characteristics are different. VNAV calculates a descent line from top of descent to the ground, including any descent speed/altitude restrictions you have programmed into the descent. At high altitudes, in idle thrust, the GE90s creat more drag than the Trents, and therefore, their VNAV Path can be steeper and they can still maintain the standard 300kts in descent.
If we fly the same steep VNAV path, the aircraft often cannot hold that 300kts as our little (Sort of!) engines don't provide as much drag, so the aircraft slowly accelerates. Some pilots will fix this by occassionally pulling the speedbrake to slow the aircraft back down when needed. Others will choose FLCH mode and disregard the VNAV path.
The problem is reversed at lower levels. As we descend and the air gets thicker, the GE90s at idle start producing a lot more idle thrust than our Trents, and therefore, their path is designed to be more shallow at lower levels in order for them to maintain the 300kts. When we hit this shallower section, we cannot maintain both the 300kts and idle thrust, so the aircraft will begin to slow beyond 300kts. It will drop until the aircraft autopilot gives up on tha path and changes to VNAV SPD, adding thrust to maintain the 300kts. The path then gets thrown out the window and the aircraft starts flying the speed.
It all makes for an untidy descent, especially if you pull the speedbrakes to lose energy at higher levels, then add thrust to gain energy at lower levels.
However, I can just fly FLCH and ignore that path and work out my own path. That isn't a problem. However those bloody sunshades....sometimes I have to get out of my seat and crouch on the floor in order to figure out how to put them back!!
sudden
Tue Apr 29, 2003 8:52 pm
As it is a software issue, why isn't the V-NAV programmed to fit the Trents as well?
Might be a very novis question, but anyway.
Aim for the sky.
Sudden
ba299
Tue Apr 29, 2003 9:24 pm
We have the same problem on the older 777 with RR engines. On the newest we don't have this trouble. Under all the other point the aircraft are perfect more easy to fly than the airbus A320.
CX Flyboy
Tue Apr 29, 2003 11:39 pm
Ba299,
Do you have the same problem with the sunshades, or is it just me?  Smile
Sudden,
It is indeed a simple software update that would fix it, but Boeing charge a lot of money for these updates per aircraft and Cathay isn't willing to pay it as it isn't really a big problem. I assume our new 777s due next year will have the new software as standard.
sudden
Thu May 01, 2003 6:22 pm
Can't they update the sunshades as well, or is that maybe a to costfull update as well!? Big grin
Aim for the sky.
Sudden
CX Flyboy
Thu May 01, 2003 8:37 pm
They probably won't update it even if it's free....just to piss FOs off!
Rick767
Thu May 01, 2003 8:41 pm
"They probably won't update it even if it's free....just to piss FOs off!"
Best become a Captain then! How many years do you have to go?
CX Flyboy
Fri May 02, 2003 12:09 am
Rick767,
Quite a while yet. Before this SARS thing, probably 6-7 years, but now, probably 9 or even 10. I can only hope that things pick up soon and we continue to expand. How about yourself?
BA777
Fri May 02, 2003 1:25 am
Wow, three cool pilots in this discussion, it's my lucky day  Smile
CX Flyboy: "The reason VNAV is so bad is because in the software load on our planes, the data used is GE90 data. The GE90 is a lot bigger than the Trent800s we use and therefore the characteristics are different."
Surely that could be dangerous, what was Boeing's excuse to that, do fellow 777 pilots complain about it a lot??
Ba229,
How long have you been a pilot(ess) for, what plane did you start out on? Was it the 320?
Also, I'm guessing that you're LHR based when you say RR 772s, do you regularly operate out of Gatwick to the Caribbean or PHX?
Henry (777 Freak)
Rick767
Fri May 02, 2003 1:33 am
"Quite a while yet. Before this SARS thing, probably 6-7 years, but now, probably 9 or even 10. I can only hope that things pick up soon and we continue to expand. How about yourself?"
About 6-7 years, depending on expansion and retirements. Next f/o on the list for upgrade has been with the airline 9.5 years and I am at 3.5  Sad
Bit annoying with Easyjet and Ryanair pilots getting command after 3 years or so due to rapid expansion, a guy I trained with in 1998 now commands a 737NG for FR! Not worth moving now though, BY is a happy bunch all-round despite the moaners!
Hope the SARS thing clears up quick for you out there, must have had a huge impact.
ba299
Fri May 02, 2003 3:28 am
Yes I have the same problem with the sunshades.
My first a/c as a professional pilot was the B727-200 for the DHL.
Normally the RR777 operate from LHR. The GE777 operate from LGW and LHR, a few time for some strange reason, such as a/c change, you can see the RR777 in LGW but it is rarely.
BA777
Fri May 02, 2003 4:51 am
BA299,
Cool, the oldie 727 lol. What a contrast to the 777 eh?
Yeh, a mix of RR & GE from LHR, 99% GE from LGW also, but the occasional RR, like i said. How many hours do you fly a month, and is it say fly out on a Sunday, stay over Monday or Tuesday as well then fly back??
Henry
sudden
Fri May 02, 2003 4:54 pm
Cx flyboy...
how does your paxload look like now?
Are you even canc. flight, or have some flight been removed totally from your schedule for now?
Aim for the sky.
Sudden
CX Flyboy
Sat May 03, 2003 4:02 am
Henry,
It's not really dangerous, just more of an annoyance. In VNAV PTH, the aircraft is trying to fly the predetermined descant path, AND maintain the 300kts. When the aircraft accelerates up to 319kts, it gives up the path and goes into VNAV SPD. The speedbug rebugs at 314kts, and the aircraft now concentrates on flying the 314kts and not flying the path. There is no danger at all. However normally we don't let it get to that stage. We would either control the speed with speedbrake or just use a different mode for descent.
Rick767, Sudden,
SARS has affected things badly here. We have cancelled 50% of flights and load factor last monday was 29% when it should be at 80%. We should be carrying 30,000pax a day but we have 6000. We have stored 20% of the fleet now, with the 777s being hard hit. We have had 50% of our fleet stored. The 777s are simply too big to fly around Asia and the A330s are more efficient. On the 777 we will be lucky to get away with 20-30hrs a month, and on the whole we may get a weeks no-paid leave every month for the forseeable future, although probably not redundancies. The cadet courses due to graduate in the next few months have been told there is no job waiting for them at the end.
Command time here had dropped to 8.5 years, but was due to increase anyway, with lots of young Captains now, and fewer old ones. I had been guessing 11 years, but now this may push it back a further couple. Very bad.
Ba299,
Glad to see it's not just me with those sunshades. I was thinking it might have been a Cathay cheapo deal!!
BA777
Sat May 03, 2003 10:14 pm
Thans CX_flyboy,
It must be annoying, maybe it was a CX cheapo deal like the sunshades  Big grin
Do you fly the 777 or 747?
Henry
CX Flyboy
Sat May 03, 2003 11:54 pm
Hi Henry,
I fly the 777. I used to be S/O on the 744, but now FO on 777s.
Mr.BA
Sun May 04, 2003 12:22 am
Cx Flyboy,
Sorry to be a little off topic, on B777s are the fuel crossfeed supposed to be on or each engine will burn fuel from individual tanks?
Boeing747 万岁!
CX Flyboy
Sun May 04, 2003 11:42 am
Hi Mr. BA! Long time no see!
We fly with each engine using fuel from it's respective tank. Crossfeeds are only used when there is a fuel imbalance situation.
BA777
Sun May 04, 2003 9:36 pm
CX,
I take it you must be (semi) badly affected by the SARS? You were saying how Cathay had parked a lot of 777s...
Henry
CX Flyboy
Mon May 05, 2003 12:11 am
Henry,
I have done two sectors this month, and next week I get 4 sectors. After that, the rest of the month is all reserve. Just 4 sectors on two trips for the entire month. About 13 hours worth vs the usual 60-80. It is unlikely that I will be called out on reserve, but even if I am it will probably only be for one trip. At the moment the A330 has been planned for most regional flying, and if there is a lot of freight then it gets upgraded to a 777-300, but otherwise the 777s are doing a lot of sitting around.
sudden
Mon May 05, 2003 6:34 pm
Hm...
maybe they will use you as a dustbuster soon then. As your 777's will sure collect some if they are grounded.  Big grin
Well, that was probably not fun for you to read, but anyway.
Aim for the sky.
Sudden
BA777
Mon May 05, 2003 8:31 pm
CX,
Must be the best job in the world.  Smile
Henry
Tg 747-300
Mon May 05, 2003 10:00 pm
Rick767: i thought you were due to start working with EK this year. Is that still the plan, or are you going to fly for BY for some more years?
tg 747-300
intentionally left blank
Rick767
Mon May 05, 2003 10:21 pm
Tg 747-300,
I should be so lucky! That plan was subject to getting into Emirates, which I didn't manage to do. They asked me to re-apply in another couple of years when I had more experience. There are plenty of jet pilots around the world with more hours than me who apply so EK can afford to pick and choose. A couple of guys at BY with more experience did get in and have already left the airline.
The plan for now is to stay here for a couple more years at least, then review my options. By that stage it might be worth just waiting for a command at BY.
Tg 747-300
Mon May 05, 2003 11:16 pm
Is EK a very popular airline to apply for for experienced pilots. If thats the fact, why?
Maybe EK is quite liberal with nationality so that people from all over the world can work for them?
If true, do yoy know more airlines that accept pilots from foreign contryes, that don't hold a citizenship for the airlines homecontry?
tg 747-300
Rick767
Tue May 06, 2003 5:43 am
Emirates has (I understand) the largest number of nationalities in their pilots of any airline in the world. Lots of Australians and Brits (the Chief Pilot is British). Lots of other nationalities as well (South African, Bangaldeshi, etc..!)
They are a very popular company to work for due to the 100% tax free salary. Here in the UK a £40,000 salary means take home pay of £28,800 after tax  Sad
In EK the £40,000 (US$56,000) First Officer start salary is all take home pay. I would have to earn £60,000 in the UK to take that amount home with me, equivalent to about a Year 9 First Officer (almost 6 years from now for me).
Dubai is also a very cosmopolitan city and the company provide rapid career progression on an A330 or bigger, offer you an interest-free car loan, fully furnished accommodation, etc...
With year-round sunshine and several daily flights to the UK if you need to see the family (or vice-versa) it's not difficult to see why so many people want to work for them.
CX Flyboy
Tue May 06, 2003 10:38 am
I would say that Emirates now is similar to what Cathay was 15-20 years ago with very short command times (We had a 29yr old Cv880 captain at one stage!). The pay is good and the city cosmopolitan with a good mix of expats from around the world.
One thing I have heard though. Emirates is still run by Arabs, and if they personally don't like you, then unfair or not, your career will not progress very well. However, I don't know if that is true or not, and I certainly can't say I have heard much about their politics. Still, a better option than many at the moment.
ConcordeBoy
Tue May 06, 2003 2:43 pm
CX_FB,
is the VNAV problem present on any of the 773As at all? If so, that's rather odd as no one's ever mounted GE90s to that model.
CX Flyboy
Wed May 07, 2003 11:13 pm
ConcordeBoy,
The problem exists on all our 777 fleet. Not sure why, if there are no GE90 powered ones.
BA777
Thu May 08, 2003 5:46 am
Oh well, Up the Trents  Big thumbs up
Rick_767,
Could you email me again please, would like to ask a few more questions if possible (henry.lidster@btinternet.com)
TIA
Henry
Users browsing this forum: Horstroad and 2 guests
