doug_or
O2 For 10% Of Pax- Why?
Sun Jun 01, 2003 6:48 am
I've been studying for the ATP written, and some of the part 121 FARs strike me as a little strange. they make refrence to aircraft being required to have O2 for 10% of the passengers in certain situations. Am i correctly reading this to mean that O2 only needs to provided to 1 in 10 passengers?!? if so, why bother?
thanks,
Doug
PDX/LAF/IND
When in doubt, one B pump off
mjzair
RE: O2 For 10% Of Pax- Why?
Sun Jun 01, 2003 10:59 am
I am studying for the JAA ATPL, and the text refers to a 10% rule, this states that the total number of oxygen dispensers has to exceed the number of cabin attendent and passanger seats by 10%.
Could this be what you are refering to?
doug_or
Mon Jun 02, 2003 6:51 am
from FAR 121.327
(1) For flights of more than 30 minutes duration at cabin pressure altitudes above 8,000 feet up to and including 14,000 feet, enough oxygen for 30 minutes for 10 percent of the passengers.
(2) For flights at cabin pressure altitudes above 14,000 feet up to and including 15,000 feet, enough oxygen for that part of the flight at those altitudes for 30 percent of the passengers
Minuteman
Mon Jun 02, 2003 10:07 am
Weird...
121.327 is in reference to reciprocating engine aircraft, but 121.329 has the same requirements for turbine engine aircraft.
The third part of the both rules states:
(3) For flights at cabin pressure altitudes above 15,000 feet, enough oxygen for each passenger carried during the entire flight at those altitudes.
I wouldn't have believed the 10% and 30% rules without the third, 100% part.
flyf15
Mon Jun 02, 2003 12:43 pm
I can't say I've read deeply into this, but I'd assume they mean for planned flights at these cabin pressure altitudes -- ie: not emergency oxygen. Makes sense, below 14000ft I could see about 10% of the pax needing to breathe oxygen. Below 15000ft, I could see about 30% needing it. And above 15000, I could see enough needing it that it should be carried for all.
Mon Jun 02, 2003 7:43 pm
When the US FAR 121 mentions 10% or 30%... it means the amount of oxygen required for the physiological requirements of the total amount of passengers... at low cabin altitude, 10% of the physiological needs for the total amount of passengers would be sufficient... at higher altitudes, it is based on 30%, and above FL 150, it is for everyone...
xxx
Just for your information, do not think that "passenger oxygen masks" are of much help at high flight levels in case of loss of pressurization... it is doubtful that such masks could sustain physiological human requirements above say some 25,000 feet... These flimsy masks are just good enough to give oxygen for passengers in an emergency descent, most emergency descents procedures mention descents to 14,000 feet...
xxx
We have charts with flight time and number of passengers for minimum oxygen requirements in the aircraft operating manual...
xxx
Happy contrails -
(s) Skipper
doug_or
Mon Jun 02, 2003 10:15 pm
Skipper to the rescue agian!
thanks
Mon Jun 02, 2003 10:23 pm
Dear Doug...
Read your 121 regulations, for oxygen, it deals (fine print) "Oxygen for SUSTENANCE" or "Oxygen for emergency descent" (if I remember well), quite different requirement... excuse this old fart, I am in a hotel, dont have my 121 regs handy...
Happy contrails  Smile
(s) Skipper
MxCtrlr
Mon Jun 02, 2003 11:26 pm
Also remember, if your aircraft has gotten into a situation where O2 is required, there is also most likely, an emergency descent in play. The likelihood that you will require oxygen for a full 30 minutes is remote at best. More like 10 minutes (and, in some of the emergency descents I've been on, more like 5 minutes). Plus, some of the passengers just sit and stare at the mask when they drop. The F/A's have to put them on the pax for them!
MxCtrlr  Smile/happy/getting dizzy
Freight Dogs Anonymous - O.O.T.S.K.  Smokin cool
DAMN! This SUCKS! I just had to go to the next higher age bracket in my profile! :-(
VIflyer
Tue Jun 03, 2003 3:19 am
The 10% rule does bring up some interesting questions though. With the company work for the only A/C that doesn't have a mask for every pax is the ATR's, If I remeber correctly the 42 has 5 masks, 72 had 5 under each F/A's jumpseat (two F/A's on the 72) so a total of 10, and the 72-212A had overhead drop down masks from the overhead but it was triggered by the FO's side of the cockpit and there was only a total of 18-15 (I think, it's been a while since I did a ATR trip). But the question that always comes up in training is who gets the masks. Usually answer is that it's the F/A's judgement but the standing joke is who ever is willing to give cash, cars, and rolexs to the F/A. But honestly it's sort of a non-issue because we don't fly high enough, long enough on the ATR that getting below 10,000 will be a problem (average FL is in the neighborhood of FL120 to about FL180). By the time the F/A breaks out the mask, distrubutes them, and the pax put them on, i'm pretty sure the crew would have us well below 10,000. The highest i've been on the ATR is FL 250 but that was one flight (over a 3 year period) and by the time we got to FL 250 it was almost time to begin the decent.
just my 2 cent
I reject your reality and subsitute my own
Tue Jun 03, 2003 10:27 am
Airplanes flying below FL250 (or so certificated) do not require oxygen system. Further, on ANY flight under US FAR 121, a briefing to passengers about oxygen is NOT required if flying below FL 250...
xxx
Most air carriers make an oxygen briefing no matter what altitude, because the cabin attendants have a "standardized" briefing for all flights... sometimes they include an "overwater" briefing, even if flying only in the Sahara...
xxx
The more the briefings, the less the interest of passengers... unfortunately. Briefings should be short and clear to keep their interest...
xxx
(s) Skipper
FrequentFlyKid
Tue Jun 03, 2003 11:26 pm
Correct me if I am wrong, but my understand of the oxygen masks was to sustain the life of a passenger, not to necessarily keep them conscious. I know that's a little off-topic, but I've always wondered that.
Tue Jun 03, 2003 11:52 pm
You are quite correct, the passengers O2 masks are basically worthless, they just will help keep them "alive" (and scared) during the 2 to 3 minutes emergency descent to 14 or 15,000 feet... be aware also that transport category airplane are certificated to their maximum flight level so that they can maintain a cabin altitude equal to or better than 8,000 feet.
xxx
Pilots masks, although a little more efficient, can do OK to about 30 to 32,000 feet (they are not "pressure systems" like you have in fighters), higher than that, again, they will assist pilots for the emergency descent... just that... a lot of pilots flying high altitude airplanes should be reminded of that fact...
xxx
With USA airlines (121) when a pilot leaves his station, the other pilot is required to wear his mask... good point... not many foreign airlines do require this... However many foreign countries require actual "pressure chamber O2" physiological training, for pilots operating aircraft above FL 250... in the USA, "just watching a video" about it, is... sufficient...
xxx
It is considered that "unpressurized airplanes" can be flown without oxygen to about 10 to 12,000 feet (USA insists for lightplane pilots not to fly higher than 10,000 feet without oxygen)... I have a Bolivian pilot friend who lives in LaPaz, and flies a Cessna 185... he does not wear oxygen unless exceeding 15 or 16,000 feet - but is body is accustomed to that altitude. La Paz airport is 13,500 feet high...
xxx
I go to the pressure chamber every 2 years for recurrent training... one thing I have learned, if I have to get the death penalty, this would be my choice for execution... you feel good, very good, and then... nothing...
xxx
(s) Skipper
b727
Wed Jun 04, 2003 2:55 am
When the airmasks drop, how would you find a mask for an infant or child that is sitting on your lap? Is their an extra mask every other seat etc...
B727
Glenn
doug_or
Wed Jun 04, 2003 4:01 am
Well Glenn, I know at least on you namesake there are 4 masks per row, to allow for seated infants and O2 for FAs that may need to assist pax
Wed Jun 04, 2003 4:57 am
Dear Glenn -
xxx
Like Doug mentioned, per row of "3 seat units" there are 4 masks... the larger "center aisle units" (wide bodies) of 4 or 5 seats have 5 or 6 masks...
xxx
No matter what - as a parent, how much you love your child, take YOUR mask first THEN give the child the mask... if you do the opposite, you may faint, his mask will fall, he will faint too... so, first SAVE YOURSELF (in ANY emergency) so you can help others...
xxx
(s) Skipper
Wed Jun 04, 2003 7:28 am
This thread reminds me of the famous Southwest Airlines cabin safety briefing...
"Welcome aboard Southwest Flight 124 to Orlando. To operate your seatbelt, insert the metal tab into the buckle, and pull tight. It works just like every other seatbelt and if you don't know how to operate one, you probably shouldn't be out in public unsupervised. In the event of a sudden loss of cabin pressure, oxygen masks will descend from the ceiling. Stop screaming, grab the mask, and pull it over your face. If you have a small child traveling with you, secure your mask before assisting with theirs. If you are traveling with two small children, decide now which one you love more...  Big grin
b727
Fri Jun 06, 2003 3:50 am
Thanks B747Skipper.
I was wondering how that works, and I will be traveling with my daughter soon,
B727
glenn
Users browsing this forum: Bing [Bot], BoeingGuy, SuseJ772 and 14 guests
