ConcordeBoy
Modifications To A32x For Dual Tandem?
Tue Jul 29, 2003 7:34 am
What sort of modifications did Airbus have to make to IC's A32x in order to allow for the dual tandem bogies?
Photo © Propfreak
What are the disadvantages?
Ever been done with the 737?
emiratesa345
RE: Modifications To A32x For Dual Tandem?
Tue Jul 29, 2003 7:52 am
Very interesting! I'm curious to know myself. Maybe it allows for a heavier load? One obvious modification would be the enlargement of the wheel well.
EmiratesA345  Smile/happy/getting dizzy
You and I were meant to fly, Air Canada!
doug_or
Tue Jul 29, 2003 8:42 am
It doesn't allow a heavier load on the airplane, but allows the same load to be distributed more lightly on runways. Many runway/taxiways will have load limitation based on the number of tires on the trucks.
When in doubt, one B pump off
ConcordeBoy
Tue Jul 29, 2003 9:20 am
But that falls into my original questioning... did the wheel well even need enlargement? If not, then why not have it as an option on all A32x... which would give them [something of a] advantage over the 737 and its apparently limited wheel storage
emiratesa345
Tue Jul 29, 2003 10:49 am
Of course it would need enlarging. You would now need to fit 4 wheels instead of 2. You must remember that this is also extra weight that the aircraft must carry.
avt007
Tue Jul 29, 2003 11:56 am
You also have twice the brakes and tires to maintain, and more spares would be required.
JBirdAV8r
Tue Jul 29, 2003 4:09 pm
As I recall, it was/is an option on all A32x.
